Question about Dirt Devil M083405 Versa Power Stick Vac Vacuum
How do i attach the crevice tool? - Dirt Devil M083405 Versa Power Stick Vac Vacuum
5 Suggested Answers
Agent Don
  • 310 Answers
SOURCE: no power in power nozzle
http://geeksquad.fixya.com/ThreadView.aspx?prdid=19674&thid=493359
No power in power nozzle
Posted by pjs5451 on Apr 06, 2008
Vacuumed with power nozzle one day working fine took attachment off to use crevice tool reattached power nozzle and no power whatsoever.
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. Rainbow E Series Canister Wet/Dry Vacuum. The Rainbow Power Nozzle does have a reset button on the newer model on the top of the power nozzle, just push it and it should reset, or check all your pigtail connections to make sure they are connection and the cord leading to the actual Rainbow Vacuum itself. Out in left field might be that the power nozzle motor could be shorting out or not working or dead and might be in need of replacement. Check the cord for any frays or bad connections. If you have a problem please feel free to contact your local vacuum cleaner dealer in your area. So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
The Rainbow / RexAir Factory phone number is listed below:
http://rainbowvacuum.com Customer Service
1-248-643-7222 Monday thru Friday from 9:00 am to 5:00 pm EST
Thanks, Don the Vac Man
Go Ahead. Use Us.
Posted on Jun 12, 2008
SOURCE: No suction for use of crevice tools, running hot, then shut off
Obviously no suction in hose would indicate a blockage, over heating is a breaker that shuts off the machine when it over heats. There is no way to clean hose the on this model because the hose does not detach at either end, therefore I had to employ the use of the good old wire hangar. Job complete up and running, with good suction. It is amazing what a prayer to God can do.
Posted on Nov 20, 2008
  • 3 Answers
SOURCE: The attachment that holds the Dyson crevic tool
You need to replace the wand. To find the wand appropriate to your machine, visit http://www.espares.co.uk/dyson/dc04/p/1086/716/4
Posted on Sep 01, 2009
  • 61 Answers
SOURCE: how do I attach the
Just pull REALLY HARD at the bottom of the vacuum cleaner, it'll pop off.
Posted on Aug 27, 2012
Why was the bissell we bought come with not all attachments?
Should have bought a Dyson :>)
You wold think it would come with a crevice tool. Not sure of the model and whether it should have a wand. Contact them direct, we are FIXYA, not they.
https://canada.bissell.com/vacuums
Mar 23, 2018 | Bissell Vacuums
How do I use the crevice attachment
Hi there! The crevice tool can only be used when using the unit has a hand vac. Remove the handle and nozzle from unit. Attach the crevice tool by inserting into hand vac nozzle opening. To remove, gently pull apart. Hope this helps!
Sep 30, 2014 | Dirt Devil SD20000RED Versa Power AllinOne...
How to put on attachments
Hi there, it's Jack at Dyson.
DC14 includes a Stair tool, Dusting brush and a Crevice tool. These are push-fit parts and will attach either to the end of the wand when additional reach is needed, or into the hose cuff for cleaning in confined spaces.
I hope this helps, but if you need further information you're welcome to call us directly on 0800 298 0298 (UK), 1-866-693-9766 (US), 1-877-397-6622 (CA) or 1800 239 766 (AU).
Sep 03, 2014 | Dyson DC14 FS Telescope Full Kit HEPA...
Remove handle from hose electrolux
You don't have to "remove" the handle from the hose to attach other attachments, just depress the tab at the end of the hose and pull the upper wand loose then use the "adapter" to use the dusting brush or simply snap the crevice tool in place to use. If the handle won't come loose from the upper wand, then the described "tab" needs replaced as it's locking up the parts. Hope that helps!
May 17, 2014 | Electrolux Vacuums
How to attach crevice tool
Hi! Below is step-by-step instructions for attaching your crevice tool.
1. Place unit in an upright position. Push release button forward, then pull handle from unit.
2. Remove floor tool from nozzle.
3. Attach crevice tool by inserting into nozzle. To remove gently pull apart.
Hope this helps out!
Apr 26, 2014 | Dirt Devil Simpli-Stik 3-in-1 Bagless...
Cannot find filter in bag compartment
If you're looking for the exhaust filter, it is on the top of the machine under the crevice tool and dusting brush.
If you look at the rear of the machine you will see a tab on the attachment holder.
Remove the attachments on the unit
Push tab on rear of vacuum on the attachment compartment
Lift cover and your exhaust filter should be exposed and should just pop right off for replacement.
Mar 03, 2014 | Electrolux Lux 7000 Bagged Canister Vacuum
Is there a floor attachment that will fit my extention wand?
There is a Bissell Tool Dust Upholstery combo part # 2031099 or you can purchase a crevice tool part number # 2031063.
There is also a floor tool that goes to a different model, but it should fit if the diameter is the same it is part number B-2032081
You can find them here (use the search field to find the floor tool by part number)
http://www.usavacuum.com/category-s/314.htm
Feb 22, 2010 | Bissell 6594 PowerForce Bagless Upright...
The attachment that holds the Dyson crevic tool broke. What part do I order to replace it?
Aug 10, 2009 | Dyson DC14 Bagless Upright Cyclonic Vacuum
Nov 17, 2008 | GE 106766 Bagged Canister Vacuum
Dirt Devil M083405 Versa Power Stick Vac Vacuum Logo
143 people viewed this question
Top Dirt Devil Vacuums Experts
Jim Parker
Jim Parker
Tim Venetis
Are you a Dirt Devil Vacuum Expert? Answer questions, earn points and help others
