Question about Vacuums
My kenmore intuition vacuum won't start
I recently moved & I just tried to use my sears intuition canister vacuum but after I plugged it in nothing happens & I also cant find my manual.
SOURCE: Kenmore vacuum manuals
I tried what reddevil6 suggested and was not able to get Sears to produce a manual. I would prefer an online manual but at this point I'm desperate enough to try anything.
Posted on Oct 05, 2008
  • 1214 Answers
SOURCE: Brush does not turn on my vaccum
If there is no suction when you disconnect the beater bar assembly near the hand hold where you grab the vacuum, then there may be either a restriction in the vacuum line between there and the vacuum section (that rolls around behind you), or the vacuum line from the handle point to the rollaround section is not properly connected. This all assumes the vacuum motor in the rollaround is running.
The beater bar section does nothing but cause dirt particles to be sucked into the vacuum system. The vacuum or suction is created in the rollaround unit.
Posted on Jan 22, 2009
  • 31 Answers
SOURCE: Smoke coming out of my Kenmore Canister Vacuum Model 22550300C
Sounds like a motor err. Could be repaired by a professional but it never be as good as a new one. Also they you might not find anyone to repair it because the replacement motor might cost more than a new vacuum /considering it's age the motor will be hard to find and that makes it more expensive to repair./
I suggest you to buy a new vacuum.
Posted on Feb 16, 2009
Milleniumboy
  • 106 Answers
SOURCE: Kenmore canister vacuum cleaner won't start
The rigidity of the Power Head/Handle is quite durable, :) but sometimes they give out. Have SEARS ...loL, sears, have Sears have a look at the head. :)
Posted on Apr 03, 2010
  • 20 Answers
SOURCE: 25512/ 25513 Progressive Canister Vacuum: HI, we have a kenmore progressive canister vacuum ...
cord bad at male prongs, or fuse near motor blown.
Posted on May 06, 2010
Sears canister vacuum rear wheel won't stay on
1) test the power cord for open, defective, or break use the VOM
2) test the fuse for open, loose wire use the VOM
3( tes the motor, for open, short, or defective, need repair.
4)test the switch, for open, or loose wires, or short.
see how to do it.
God bless you
Jul 10, 2012 | Kenmore 23612 Progressive PowerMate Bagged...
Apr 03, 2010 | Kenmore Vacuums
My canister kenmore progressive is not sucking and is sptitting carpet powder dust all over the place. could it be it needs a new hpa filter? if so where on the vacuum would it be located?
Remove the hose from the canister, and turn on the vacuum. Does it produce good air flow into the hose port?. If ok, remove the hose from the sweeper unit and plug the end into the canister. If ok, check the bottom of the sweeper head for plugging of the air passages and inspect the sweeper bar for accumulation of thread, hair, and string. If the first test produced no air flow, then open the canister and remove the bag--turn the vacuum on and check for air flow into the motor. If still nothing, then check the hepa filter which should be near the air output from the canister. Go to: searspartsdirect.com and enter the sears model number from the information plate. The machine's part drawings will appear and select the vacuum case drawing which should display the hepa filter location and also be able to order the filter from the web site. Hope this helps!
Mar 13, 2010 | Kenmore 25512/ 25513 Progressive Canister...
Need plug c45ecue
i went to sears web site and ordered cover # 8191782. (i don't know whybthey callmit a cover.)
Jan 12, 2010 | Kenmore 22812 Bagged Canister Vacuum
Prong on one side of plug broken
You will need to get in touch with a Sears repair center and replace the cord and plug (they're one unit). If you do not have a local repair center, you can order the part online at searspartsdirect
http://www.searspartsdirect.com/partsdirect/index.action?psid=26128388&sid=PSx20071217x00001a&OVMTC=Exact&site=&creative=3106724154&OVKEY=sears%20parts
Jan 01, 2010 | Kenmore 23313 Whispertone Bagged Canister...
Have suction, new bag, brush moving but does not
Solved!!!
I went to my local Sears store and the salesman there looked at my vacuum and was able to resolve the issue. There was a piece of wire that had been sucked into the machine that then blocked anything else from being vacuumed up.
Thanks for your help.
Jun 18, 2009 | Kenmore 22313 Bagged Canister Vacuum
Kenmore vacuum- no suction, brush wont turn
Sounds to me like you have a plugged vacuum. Check all the way through.
Jan 29, 2009 | Kenmore 22812 Bagged Canister Vacuum
Hot cord
likely after all these years that the motor is starting to go bad and draw more amps thasn it should. a new motor at a vac dealer is your best bet. it was likely made by panasonic, so a new panasonic is your best bet, and less $$$than the kenmore for the same vacuum. sears parts are extremely expensive
Sep 06, 2008 | Kenmore 23313 Whispertone Bagged Canister...
4.3 amp Kenmore canister vacuum power switch has failed
You did not give the complete model number, but you can go to sears.com, click on parts and put in you model number. You will get links to click on, click on the cannister one and you get a picture breakdown and a parts list, you can also order after choosing the part you need.
Aug 09, 2008 | Kenmore 22812 Bagged Canister Vacuum
Vacuums Logo
98 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
