Question about Epson PowerLite 7800p Multimedia Projector
Temperature and power LED on the Epson Powerlite 7800P are Red
The temperature and power led on the Epson Powerlite 7800P are Red. Have let projector cool then turned it back on only to have the same thing happen again in 15 to 30min. Both filters are clean.
  • 110 Answers
SOURCE: Epson PowerLite S1+
You have not set the port on the back of the projector settings.
Go into the projector menu and go into the IMAGE area. Somewhere in here you should be able to select computer.
Posted on Aug 22, 2008
zabolyx
  • 38 Answers
SOURCE: epson powerlite s4 projector is pink
I assume this is an LCD. I don't remember the s4 being a DLP projector.
This sounds like the LCD panel used for the red color has gone out. The image is made up of red, green and blue images layered upon the screen. If the red panel has gone out then there is nothing filtering out the red light in the image. This causes a nice red hue to the whole screen.
It could be a simple open and reconnect fix. I personally have never opened a projector, so I'm not going to walk you through it as I do not know how hard it would be to tinker with. It should eb a cheap fix for a true repair man though.
Posted on Apr 01, 2009
  • 105 Answers
SOURCE: Epson 83+ powerlite projector overheat
hi follow the link bellow the instructions are on page 83 \\files.support.epson.com/pdf/pl83pl/pl83plug.pdf
Posted on Jun 04, 2009
SOURCE: My Epson Powerlite 5350 has a ghost image. Any
I've got the same problem on two Epson EMP7300.
I believe (from reading about other projectors) that the ghost image can be adjusted with RS232 codes.
Does anyone know how to do this?
Posted on Feb 24, 2010
stecon3248
  • 57 Answers
SOURCE: Total factory reset Projector Epson Powerlite S5
This is an anti-theft device, you will need to contact Epson if you cannot recall your password.
Posted on Aug 15, 2010
The indicator of temperature is red, the indicator of the bulb is off and the fan after 3 o 5 minutes
PowerLite 7800p Multimedia Projector - Epson
www.epson.com/cgi-bin/Store/support/supDetail.jsp?...oid...
EpsonPowerLite 7800p Multimedia Projector. Support ... Indicator Light, Status, Description... Temperature, Red, The projector is overheating, which turns the lamp off ...
PowerLite 735c Multimedia Projector - Epson
EpsonPowerLite 735c Multimedia Projector ... Indicator Light, Status, Description ...Lamp/Temperature, Red, The projector is overheating, which turns the lamp off ...
Maintenance Indicators - ManualsLib
www.manualslib.com > ... > Notevision PG-F212X > Operation manual
The warning lights (power indicator, lamp indicator and temperature warning... ... Redon. Normal (Standby). Green on. Normal (Power on). Red blinks. Abnormal ... Sharpmultimedia projector model xg-mb67x-l operation manual (71 pages).
Dec 14, 2015 | Office Equipment & Supplies
Epson 7800P projector?
Please dont use cheap alternative Lamp Bulbs in Epson. There are issues where the cheap Bulbs draw more current and damaging the circuit board.
Apr 22, 2014 | Office Equipment & Supplies
Projector shuts off after while
If an input source isn't detected the screen will blank which looks like a shutdown. What color is the power LED? Is the lamp or temp LED lit?
Manual at: https://files.support.epson.com/pdf/pls6__/pls6__ug.pdf
Mar 16, 2014 | Epson PowerLite S6 LCD Projector
Powerlite 77c keeps shutting down
Hi Dave,
have you inspected the led indicators after shutting down .
it must flashing and indicating pattern.normally epson have 3 LED indicators.
please come with blinking pattern or google it.
i think it is bulb problem,
regards,
nuwan
Jan 13, 2014 | Epson PowerLite 77c Projector
Temperature light is on with no picture
Blinking red power and temp light is an internal failure for the projector. If under warranty the whole unit will be replaced.
Jan 11, 2013 | Epson PowerLite® 83c LCD Projector
Projector will not power up. Temperature and lamp lights are displayed red.
I'm sorry to inform you that there is an internal error in the projector. Turn the projector off and unplug it. Contact Epson for help.
Feb 27, 2011 | Epson PowerLite® 83c LCD Projector
Projector will not turn on. Lamp light displays red and temperature light displays red.
Projector lamp flashes and the temp red led lights.
Purchased our76C in Jan, 2007. It is our second unit now that has had the same symptoms. When the unit starts up, the Power light is steady green as normal for a few minutes, but no image is projected. After a few minutes the lights do as you described. Both times Epson support authorized a new unit to be shipped out immediately. They said they had no known issues about it and didn't indicate what was causing the problem. Apparently it is not just the lamp wither. Also, the lamps both had under 20 hours on them.
Jun 17, 2007 | Epson PowerLite 7500 Multimedia Projector
Epson PowerLite 7800p Multimedia Projector Logo
120 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
