Question about LG LDF8812 Stainless Steel Built-in Dishwasher
Water in bottom of washer and noise when trying to move water
  • Anonymous Apr 13, 2008
    yes water in bottom and makes noise
  • davidburbon Sep 19, 2008
    When the diswasher is set to rinse only it starts just fine, except three minutes into it I hear the pump turns on as it start drawing water out of the machine and a sound of a propeller is heard as if it hitting something as it turns to pump the water out. It is coming from the bottom of the machine.
  • 185 Answers
See if your drain is plugged or anything
Posted on Mar 28, 2008
Samsung dishwasher makes a loud buzzing sound when the water is filling. It pulses a couple times to start then is constant. It pulses again right before the wash cycle. Comes from the bottom left.
This is common. The noise is coming from the water pump. If it bothers you, you can try UNPLUGGING the washer or turn off the Circuit breaker first. Then you can remove the bottom kickplate on the front of the washer and clean around the pump. If there is a water filter scree, clean it out. Make sure there is nothing rubbing against the pump which could cause a buzz. Tighten all fittings and screws to eliminate vibration noise.
Aug 30, 2015 | Samsung Dishwashers
Aquarius WF745 Front Load Washer.Full of water won't drain.
The filter is located at the bottom front of washer.
Remove the kickstrip at the bottom, by levering off.
Unscrew filter anti-clockwise to remove and clean..
Be careful when removing filter, as there will be water come out.Lay the drain hose down into a bowl or similar to drain off excess water.
Please rate my solution.
Jan 30, 2010 | Hotpoint Aquarius WF210 Front Load Washer
Sides vibrate during spin causing a lot of noise and machine moves. could it be out of balance?
1- Clothes are not balance inside the tube. Try to rebalance the clothes when it happens. It usually happens when towers leaning on on side when water level selector not set appropriately. 2- Try to level the washer by adjusting the leg screws at the bottom of the washer. 3- It make a lot of noise since the whole washer moving against the floor. When it spin only the tube then it won't be like that.
Jan 02, 2010 | Kenmore HE3T Washer
Water from the cycle remains in the bottom of the washer.
Sure we can help, what are we sitting here for. And don't forget, ITS FREEE. (The weight of the washer is not the water, but concrete blocks to counter balance your clothes; so the machine does not fly off when it spins.) The draining involves several factors, giving you the most common. If you surf this site you'll find your solution. Solution is for another machine, but could be helpful for you: The filter on your pump is probably clogged with lint and stuff. You have to remove the bottom front panel, 3 screws. The panel will drop and come off. The filter cover is right in front. Get yourself a bunch of towels or a good big plastic bag to collect water. Unscrew the filter cover and twist the filter out. Clean out all the stuff and put it back in. Plz rate if helped.......
Apr 02, 2009 | Washing Machines
Kenmore washer won't agitate,drain or spin.
What you have here is a broken drive coupling
the part looks like this:
To fix it CLICK HERE
Dec 29, 2008 | Kenmore 24032\24036 Top Load Washer
Maytag washer pours water out bottom instead of filling up
Check the water pump for physical damage from the move. If the washer was laid on it's side, you may have either snapped off the pump outlet or broke the pump body. You may have broekn the body of the water inlet valve fill flume. A visual examination should provide a lot of insight as to what the problem is.
Dec 20, 2008 | Maytag Washing Machines
Washer makes noise, will not fill
turn it on and just makes a hummins noise??? not filling with water??? at very least the machine if powered correcly will fill with water, the humming if happening is hte washer trying to fill check your incoming water supply. try alo changing water temp select from cold/warm/hot.
Dec 03, 2008 | Roper RAS8244KQ Top Load Washer
Drum doesn't move or spin
kenmore tumble action washer model#417.44152400,
Washer is approximately 3 years old. Will not drain or spin. When it tries to spin, clicking noise heard inside of unit. Would a clog insie the lines disable the spin cycle ?
Oct 18, 2008 | Kenmore 43142 Front Load Washer
Maytag MAV2755AWW Washing Machine is leaking water
It sounds like you have a leaking pump. The pump is easy to replace:
#1 Use a shop vac and pull all the water out of the drain line. This will keep you from having to clean up about 1 gallon of water off of the floor.
#2 Lift the front of the machine enough for you to get under and see.the pump just inside the front of the washer.
#3 Lift the 2 retaining clips off of the pump. This will allow you to pull the pump off of the motor.
#4 Remove the 2 clamps off of the hoses.
#5 Install the new pump into the hoses, and reinstall the clamps.
#6 With the retaining clips installed into the motor housing, install the pump.
#7 Attach the retaining clips, and set the washer back on the ground.
You have now replaced the washer pump.
If you have any questions, let me know
Please rate this solution
Jan 11, 2008 | Maytag MAV2755A Top Load Washer
Washer will not drain or spin motor making clicking noise
Likely has debris in the filter.
Open the bottom access panel (3 screw on bottom front lip)
open the filter access and be ready for some water spill ,have towels.
clean and check the pump impellers for freedom of movement.
if you still have noise after this you may have to go deeper past the pump and remove the hoses as the debris can be past the pump now.
Or take the machine outside and run water up the pump using a water hose to clear it. be inventive
Oct 26, 2007 | Whirlpool GHW9100L Front Load Washer
LG LDF8812 Stainless Steel Built-in Dishwasher Logo
81 people viewed this question
Top LG Dishwashers Experts
Are you a LG Dishwasher Expert? Answer questions, earn points and help others
