Won't play cd's clean it and will play a few
Won't play cd's clean it and will play a few tracks then quits
  • 567 Answers
Sounds like laser problem breaking down replace with new one
Posted on May 11, 2010
Cd won't play
The problem is in the laser pickup assembly, over time it becomes weak until it can no longer play. Buy a CD cleaning kit and follow instructions, this may add more life to the unit, if not! cheaper to replace the stereo than replace the assembly.
Mar 26, 2012 | Audio Players & Recorders
Cd player won't work on my CFD-560
Hello
Insert a lens cleaning disc into the system, and play it at least three times, by eject it out and reinsert in each time. If it does not help you, the laser pickup unit of your Cd player should be replaced with same type and number. OK.
Feb 03, 2012 | Audio Players & Recorders
My dvd player wont read my movies
Hello
Check its Sled Motor. Sled motor is one which get spins the disc we insert into it. If it is faulty, discs won't spin, and the set won't read anu discs, and will show no-disc display. OK.
Dec 12, 2011 | Sanyo DVW-7000 DVD Player/VCR
I have a CD and in my car it won't playback discs. It allows me to insert/read the disk, it even shows the data, track number, and position in the song but it won't play to my speakers. The AM/FM...
What i found i have had that problem in the past,This may sound stupid but it works.Spray aftershave over the cd then push the cd into the player when the aftershave is wet.This will clean out the dust inside your cd player .i can say this will do no harm.ok pippall,Hope that solves it for you m8.
Aug 24, 2011 | 2003 Toyota Corolla
Won't play a disk
In most cases when the CD does not play it is possible that the optical head is a suspect. Sometimes it might pick up ordinary audio CD but will not play other formats. This indicates that the optical head is weak and so there is no detection or scanning of the CD . If the optical is working the tracks will be read immediately but with no scanning the laser head can be defective.
The main motor will not work in some cases as unless the tracks are read the drive motor will not work with signal from the processor.
Sometimes certain cleaner disks will not be tracked to run for cleaning as it will not be read and so will reject. Hence it is ideal to manually clean the laser head eye using a cleaning swap /cotton bud with gentle pressure on the lens eye.
If there is no result then watch if the CD spins or tries to spin. If so the board seems to work unless a test is taken on the main board but the possibility of a defective optical head can be the suspected fault.
If any of the above seems otherwise we must recheck with possibilities of a malfunction of the main processor board
Jul 17, 2011 | Car Audio & Video
When I turn the system on the CD Drawer keeps going in and out repeatedly by itself. When I load a CD it won't recognize it and won't play it and keeps going in and out opening and closing by...
Hello
Check all connections, such as from player to amplifier or receiver and receiver to speaker. Check and clean contacts on RCA jacks and cables and try a different input on the amplifier or receiver.
Clean the lens. Use only a special CD lens cleaner and follow the instructions carefully.
Check the traverse assembly (the metal rod that the laser travels along and the gear that drives it) if CDs aren't recognized or won't play, frequent skipping occurs at random, CDs randomly get stuck in one spot, the player can't find tracks correctly, or cleaning the lens doesn't work. Dust and lint may be interrupting its function.
Have the laser-head assembly checked by a repair person if the traverse assembly seems intact and free of debris.Look for broken plastic parts, such as gears and clips,look for loose or broken internal connections.possibly have gears and belts replaced.
Jun 09, 2011 | Audio Players & Recorders
My cd player stops while playing and shows er on the display
Try checking for dust on the laser eye, A fine, clean and very soft artists brush will do for cleaning or perhasp the CD has a miniscule scratch on the surface. You'll know if it is a scratch as the CD will always stop in the same place. CD's and DVD's should only be wiped clean with a very clean duster in the direction of from the centre hole to the outer rtim of the disc. Never ever wipe anything across the whole surface from one side to the other or wipe in a circular motion. There a quite a few products on the market that will help you keep you discs clean. Just google CD (or DVD) cleaner. CD's and DVD's are quite forgiving in how badly scratched they can be and still play. It only takes a small scratch or dent that can only be seen under magnification to deflect the laser beam off track.
Mar 15, 2011 | Memorex MD6451R Personal CD Player
52 people viewed this question
 Grubhead
Grubhead
