Question about 2wire (1000-400108-001) Router
Bandwith failing with quest 2wire 2700hg-d router use to be able to run 3 pcs on it now can hardly run one
2 Suggested Answers
Techroy
  • 52 Answers
SOURCE: bandwith failing
Check if the Firmware of the router is updated or not, if not then update the firmware first and then run the Router diagonostic tool to check the bandwidt allocation.
Posted on Mar 17, 2010
How can I boost the signal of my AT&T 2WIRE router/modem?
You can increase the range of your router but you need to purchase another wireless switch. What you have to do is buy a wireless switch and grab a computer network cord and plug it into your 2wire modem. I would advise just turning your the 2wire's wireless off. If the new router isn't strong enough you can buy directional antenna's or larger antenna's which should help with the range issue.
Unfortunately you can't purchase an antenna that you can directly attach to the 2wire.
Make sure that the switch you buy has external antennas that you can change out. If not and the range isn't strong enough then it could cause more headaches down the road.
Apr 07, 2011 | 2wire (1000-400108-001) Router
Bandwith
Bandwith is definitely better then Bandwithout.
Mar 20, 2010 | D-Link DI 514 Wireless Router (DI-514)
Mar 16, 2010 | 2wire (1000-400108-001) Router
Question - Can you have two 2wire routers in one house?
yes but you will have to change the channel in setup on the router then change witch router your computer hooks up to
Feb 17, 2010 | 2wire 2700HG-B Router (2700HGB)
How can I limit the bandwith on an individual
you cannot limit the bandwith, but you can give limited access to a particular user/computer. You would need the router manual to figure it out.
Sep 28, 2009 | SMC Barricade 7008 Router
What is 2wire error code 2
When you got this error were you running the installation wizard disc for AT&T?
Because as far as my knowledge with AT&T (Bellsouth) this error code comes out when installing the modem using the Installation Wizard CD, this comes out on a version 3 cd. The error code means
"Failed to Upload to ISP" this possibly could mean that you are not connected to the internet.
Sep 22, 2009 | 2wire 2700HG-B Router (2700HGB)
Cannot add a new laptop on my eHome wireless router
There is not a limit to the amount of devices that can hook "wirelessly" to your router, but your bandwith is limited. Internet bases phone services will eat up a large majority of your available bandwith. try limiting the bandwith of your phone service or disconnect it all together and see if you can then connect.
pls rate as "very helpful" if this assists you in your problem. ^_^
Sep 21, 2009 | Computers & Internet
What command will show the maximum bandwidth a
The command is : bandwith ?
will show you the maximum bandwith
Jun 23, 2009 | Cisco 7505 Router
Hooking up xbox live
Well, it's very possible if you are using a wireless router that your connection may not be strong enough. XBOX Live and most online gaming requires a steady. strong, high bandwith connection. A weak singnal, OR someone else using up the bandwith (i.e. someone downloading music on another computer connected to your router) can cause the problem.
If you're using a wireless connection, try moving the router and wireless game adapter closer to each other.
If you're using a hardwire connection from one of the routers outgong ports then make sure other's aren't on the internet (Or at least aren't using alot of bandwith) while XBOX Live is being used.
Please remember also that if you have a wireless network and you haven't implimented wireless secruity (i.e. WEP or WPA encryption) then your network is "Open" and anyone within range can connect and use up your bandwith,
Feb 24, 2008 | Belkin (F5D7230-4) Router (587009)
2wire (1000-400108-001) Router Logo
13 people viewed this question
Top 2wire Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a 2wire Computer and Internet Expert? Answer questions, earn points and help others
