Question about Acer NSK8458AN Keyboard
The question mark is over the number 6 and shows as A triangle. The backwards slash shows as an A with A mark over it. What is going on.
  • 68 Answers
Go to the two letters in the taskbar[EN] remove all keyboards and add new ones and it will be fixed
Posted on May 10, 2010
2 Suggested Answers
  • 43 Answers
SOURCE: tHE QUESTION MARK IS OVER THE NUMBER 6 AND SHOWS
Change the Language satting of the keyborad ok it will working fine.
Same time other langeage Select it give other out put.using bios,
Posted on Mar 17, 2010
Cam timing without special tools
Turn motor till mark on crankshaft pulley or fly wheel mark lines up with TDC mark on housing. with a 4 cylinder motor turn cam shaft till valves on number 4 cylinder are rocking, there should be a mark on the cam gear to line up with a mark on the housing, that it, the same for a 6 cylinder motor , number 6 cylinder valves rocking.
Jul 09, 2015 | Cars & Trucks
I disconnected the spark plugs from the distributor cap and now i cant remember how to connect the plugs back up.
the firing order is 1-8-4-3-6-5-7-2. there should be alot of websites that show diagrams of this
Jun 13, 2011 | 1987 Oldsmobile Cutlass Supreme
Where is the "When thats done, you can make sure
The number "6" that he refers to only applies to the EDI distributor. If you have the HEI distributor, you won't have the number 6 to worry about.With the EDI, or Enhanced Distributor Ignition, the distributor can't be rotated to adjust the timing. The number 6 molded into the housing is basically a timing mark and the rotor must be installed so it lines up with that number.
Dec 27, 2010 | 1994 GMC Safari
I was changing plugs&wires,and i forgot to mark the wires/so i need the firing order of the plug wires.or i need a picture of the motor that shows the number of the plugs
(2) (4) (6)
ENGINE
(1) (3) (5)
Coil Packs
6
Hope this helps
Nov 23, 2010 | 1995 Oldsmobile Cutlass Supreme
On an 03 accord 3.0L you line the crank notch with the mark on the block the number on cylinder side you like the number one on the cam pulley with the mark on the back plate but on the number 4 cylinder...
the cam mark is on the compression stroke of the number one piston must hand turn until pressure builds in number one use a long wooden rod like a dowel and make sure the dowel is longer then your stroke so it does not fall within the cylinder head.keep turning it until it begins to fall again then find the very top of the cylinder by moving it backwards a hair then reinstall timing chain or belt.
May 27, 2010 | 2003 Honda Accord
THE QUESTION MARK IS OVER THE NUMBER 6 AND SHOWS AS A TRIANGLE. THE BACKWARDS SLASH SHOWS AS AN A WITH A MARK OVER IT. WHAT IS GOING ON.
Mar 16, 2010 | Acer NSK8458AN Keyboard
How do you use the question mark
The numeric keypad functions like the numeric keypad on an external keyboard. Each key on the keypad has multiple functions. The keypad numbers and symbols are marked in blue on the right of the keypad keys. To type a number or symbol, press <Fn> and the desired key after enabling the keypad.
Your responses are intended to improve the level of service provided. Please show your appreciation by rating your experience.
Dec 22, 2008 | Dell Inspiron 1501 Notebook
Key board functions
the backward slash is under the question mark key
Oct 05, 2008 | Compaq Presario Notebook
Acer NSK8458AN Keyboard Logo
217 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
