Question about Sharper Image Ionic Breeze 3.0 Air Purifier
Broken wire inside of air purifier?? Can this be
Broken wire inside of air purifier?? Can this be repaired?
  • 26 Answers
Get same size wire and run it, or splice using solder and shrink tubing
Posted on May 10, 2010
Ionic pro CA500
Yes, a new portion of wire can be put in place of the broken wire.
Sep 28, 2014 | Ionic Pro CA500 Air Purifier
TRYING TO FIND REPLACEMENT PARTS FOR A SHARPER IMAGE HYBRID GP GERMICIDAL AIR PURIFIER MODEL SI724 NEED THE WIRES AND BEADS TO REPLACE SOME BROKEN ONES
I have 2 of these air purifiers and I love them. I came to this site looking for a resolution because 1 of them stopped working properly. After running for about 30 seconds, the red light would come on. I had cut out 1 wire that was broken and thought that was the problem. There were sparks when it was turned on. After reading a couple answers here, I took a closer look and noticed that a second wire was also broken at the bottom. I just cut the second broken wire off the top and removed it and the purifier works great now. No more sparks!
Aug 16, 2012 | Sharper Image Hybrid GP (SI724) Air...
Hi, I have the ionic breeze germicidal air purifier floor model. One of the wires inside has broken. Can I get this fixed?. Thanks for any help you can give. Joyce Turner
Joyce, according to Sharper Image, if you purchased it online from Sharper Image after 2008, they will assist you with the repair. Call Customer Service 877-714-7444 . If that is not the case, you can either return it to the place of purchase for repair or take it to a small appliance repair shop,
Apr 21, 2011 | Sharper Image Ionic Breeze® Quadra® 4.0...
If is a wire inside the filter collector cell.Clip as short as possible and remove wire.That part of the collector plate will cease to function as that is the ionizer wire but u can resume using the rest of the filter as normal at slightly reduced capacity.
Mar 16, 2010 | Sharper Image Ionic Breeze 3.0 Air...
Not cleaning! plastic forks that run on the two wires broken
These forks aren't needed to operate the machine, as you know.
You can clean the grid wires with compressed air and electrical contact cleaner. But these units are very unreliable, difficult to impossible to repair, and there are no parts nor repair service available. They don't usually run very long. I'd have to say, as soon as it quits working, shop for an alternative ozone-generating air purifier.
Charlie
Sep 25, 2009 | Sharper Image Ionic Breeze 3.0 Air...
Broken Wire inside unit. Looking to have it repaired or purchase part.
You're probably screwed....
The company went under and doesn't service them anymore. It's possible you could find a local repair place that might be able to do something, but there is no authorized or trained service station, and you can't get parts.
You might be able to pick up spare parts if you scour eBay long enough.
May 21, 2009 | Sharper Image Ionic Breeze® Quadra® 4.0...
Ionic breeze stopped working
Check inside the unit to see if the two very fine wires which run from top to bottom are intact. My guess is one of them is broken, You'll need a very good flashlight to see them. If they are broken, tech service is the best way to get them fixed. Check your user manual for the service procedure -- if you don't have one let me know.
Mar 24, 2009 | Sharper Image Ionic Breeze 3.0 Air...
Thin wire broken in front
Describe this wire, is it a small silver shiny wire? It is most likely the ni-chrome wire or high tension wire that zaps the particles, I would think thay would have that part available have you called them?
wbwill@sbcglobal.net, if it is obsolete you can mail it to me and I will take a look
Nov 12, 2008 | Sharper Image Professional Plus Ionic...
Quadra - only red light goes on.
In addition to cleaning the plates on the cartridge, also turn the unit upside down then right side up a few times. There are 2 small wires inside the housing, and each has a ceramic ball on it that cleans the wire when the unit is inverted. Also, look through the vents to make sure the wires are not broken. If they are intact, they run in a straight line, almost the entire length of the unit.
If this does not help or the wire is broken, contact The Sharper Image. I believe this unit has a 5 year warranty. When mine failed, they exchanged it for free, even without a receipt.
Jul 12, 2008 | Sharper Image Ionic Breeze GP SI720 Air...
Broken wire on filter grid
Not easily but it can be done if you have superior skills with small tools.
Nov 17, 2007 | Oreck XL Professional Air Purifier
Sharper Image Ionic Breeze 3.0 Air Purifier Logo
510 people viewed this question
Top Sharper Image Air Purifiers Experts
Jason
Are you a Sharper Image Air Purifier Expert? Answer questions, earn points and help others
