Question about Garden
Hard to start, and wont idle long.
Hard to start and wont idle long. Mcculloch d195. How do you adjust carburator?
    Brigadier General:
  • 4,088 Answers
Check the air cleaner and muffler for plugging first. Turn both jet needles CW to stops (lightly), then back out each CCW 1-1/2 turns. Turn the idle speed screw CW about 1/2 turn. This is a basic setting and the engine should start and run. Allow to warm up, then pull the throttle full on and adjust the H needle CW til the engine speeds up somewhat, but is still 4-stroking. Correct setting is when the engine 4-strokes, but immediately 2-strokes when cutting. Release the throttle and allow to idle. Turn the L needle CW until the engine runs fairly well, but still allows the engine to 'follow the throttle'. Adjust idle speed screw so that the chain stops moving, but still allows the engine to keep running. Hope this helps!
Posted on May 10, 2010
HARD TO START WHEN RUNNING IT DIES UNEXPECTANTLY ?
Is the fuel fresh? What is the idle like? Does the chain spin when idling? Could be a clutch problem or broken clutch spring? Carby setting could need adjusting? Is the air filter clean? Have a look at the spark plug?
Sep 27, 2013 | McCulloch Garden
Carburator and idle problem
Believe it or not you just said the solution to your own problem manufacturers specs requires for any adjustments to engine idle or other carburator adjustments to be preformed while the engine is idling and at normal operating temp in plain english let the car warm up then make your idle and mixture adjustments if this doesnt solve it i would check the auto choke and make sure it is opening at normal operating temp hope this helps good luck
Sep 01, 2008 | 1984 Toyota Tercel
I have McCulloch 11-600031D PRO MAC 55 08/73 to 03/77 IPL 92384A-R1. i got it running but it is hard to keep it running i screwed in both idle and mix all the way in i just don't know how much need to...
Typically the screws are seated gently then turned out 1 turn as a base adjustment. The saw should start & run, if not perfectly at this point. A little fine tuning is always nescessary. If you can't get it to run at these basic settings, a carburetor service is probably needed.
Nov 26, 2010 | McCulloch Garden
Need intructions on carberator adjustments for mac-3514 35cc/cm3 runs but hard to start after using it for few minutes.
There is a low speed jet and high speed. Low speed sets the idle or stays running without feathering the throttle./// When setting high speed, hold the throttle wide open until engine revs high, then turn back in(at least ¼ turn) to slow the engine which in turn gives the engine more gas and runs cooler. If you have it too lean on the high speed, it will be hot and hard to start. Sometimes using 40 to 1 mix helps with starting, especially on older chainsaw. good luck
Sep 22, 2010 | McCulloch Garden
I have 5700 Mcculloch generator and when I open the fuel line it starts leaking from a hard black rubber next to the carburator
remove the filter and look down the tube if the carb is filling with fuel then the float needs adjustment or replaced from sinking the tube if it is the one that attaches to the side of a plate on the engine block then replace the oil do to your filling the case with gas this ia is vent tube that attaches from the plate to the carb just under the filter you may have to rebuild the carb about $20.00 for the kit and $6.00 for a float. hope this helps
Aug 21, 2010 | McCulloch 13HP 338 Cc Portable Generator #...
How do i adjust the carburator ? I put a carburator on this car , and ,like an idiot, messed around with the adjusting screws, to keep it running. Now I don't know how to adjust it back.I have a haynes...
Turn the front idle screws in until they bottom out gently. DON'T turn them in hard or you will damage the tapered ends. From there turn them back out 1 and 1/2 turns. That should start the car and you can adjust from there. If you do then do it in 1/4 turns and do both screw at tne same time. Hope this helps.
May 19, 2010 | 1987 Chevrolet Nova
It is a 1997 husqvarna 51 idle is to high when i start it then warms up and wont idle at all
The carburator may need adjusting. If this doesn't correct the problem check the air filter then clean or replace it. If this doesn't correct the problem inspect the diaphragm for holes or if it has become hard. If so replace it. Otherwise the carburator may require rebuilding or replacing.
Mar 22, 2010 | Husqvarna Chain Saw 20" Bar
Hard to start, and wont idle long. mcculloch d195. how do you adjust carburator?
I would start with both the "H" and "L" needle valves at 1.5 turns CCW from lightly seated then adjust for performance as follows:
Carburetor Adjustment by Madsens.com
http://www.madsens1.com/saw%20carb%20tune.htm
  • CW is leaner; to lean will destroy the saw. If over tightened closed (CW) the adjustment screw faces are easily marred; marred adjustments are difficult to impossible to set properly.
  • Clean the air filter; adjusting with a dirty filter can cause a run lean condition once cleaned and the saw run.
  • Clean the spark arrestor and muffler; if the saw cannot exhale it cannot inhale.
  • There are 2 wav (sound - idle & full - may not be highlighted) files that I find most helpful, I think you will too.
If you have more questions or need additional help please reply below and I will get back to you. Thank you for using FixYa and Good Luck. HTH
Lou
Mar 16, 2010 | McCulloch Garden
I would like to know how to adjust the carburator of McCulloch 3516 chainsaw 35cc/cm 46759-77
the carbuator has two 2 adjusting screws on it.one is high side and the other is low side.start by turnig them both in until they touch bottom.now turn them both out 1 1/2 turns.this should start and run saw.throttle saw up to full throttle and adjust high side in until you get the best RPM out of saw.do not adjust high side any less then 7/8 turn out from bottom.if you do you will burn saw up from to lean burn.once the high sie is set now adjust low side until the saw will idle by it's self.let me know if this helped you.......
May 02, 2009 | Garden
McCULLOCH FG2000Tc engine starts but idle
Check the valve clearances with a feeler guage. Over time the valve lash adjustment vibrates a little looser than we want and the engine gets hard to start, runs rough, etc. After the engine warms up the heat makes the valve tappets expand enough to make the engine smooth out.
Regards,
Carl
Feb 26, 2009 | McCulloch 13HP 338 Cc Portable Generator #...
Garden Logo
197 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
