System dead - checked switch, changed Power supply
Antec E-210882 monther board - System dead - checked switch changed power supply. Light on mobo - no fan nothing else. Disconnected everything from the mobo still no fan - tried different cord and switch.
    Master:
    Sergeant:
  • 460 Answers
Your motherboard has been faulty.you can repaired it from service center.
Posted on May 10, 2010
Turn on the computer nothing happen then smell burning from the power supply! turned off right away.
That power supply is probably dead. try your motherboard witha known-to-be-good power supply to determine if your system has survived. IN my experience the failrate for antec sp450 watt psu is close to 40% over 4 years (300 pc:s at university), so there is a high probability that your psu is unrecoverable.
Feb 13, 2011 | Antec SP-400 400-Watt Power Supply
We are facing a problem with a power supply with ref. Antec BP500U SN: F06070600295. The power not switch on. We try to see if it was a fuse but we don´t found it. Could you give us a suggest...
Try to check the transformer to see if the cores are still in one piece. Also check the capacitors to see if they're status is OK.
The simplest solution to resolve all the problems is to change the power source. They tend to become as cartridges nowadays.
If you need further assistance just leave a comment. Cheers
Nov 30, 2010 | Antec Basiq BP500U (ASKU51402) 500-Watt...
My power supply died (popped), so I replaced it (Antec SL350 with an Antec SL350S). However, when I turned on the switch on the back of the power supply, the motherboard powered up immediately (tower...
If you "popped" the power supply, I would check to see if the RAM might have taken a hit as well. Ram chips and CPU are sensitive when it comes to power surges. I would troubleshoot the system, unplug everything. you need monitor, power, cpu, and ram (1 at a time). Check to see if the system will POST. if you do get it to POST, start with 1 item at a time and see if the system will POST every time. If nothing happens, there is a chance you may have a damaged motherboard or cpu.
Mar 28, 2017 | ASUS A8V Motherboard
My client has a p4m900-m4 mobo that was installed Oct. 2009. The system has 2 dvd players. He tried to play a dvd and the system shut off and now appears dead. I get a power light, one of the dvd players...
Hi
There could be many things that could stop the board from turning on, Determining what is wrong is like detective work. What I do, is take everything off the board to start. Then add the minimum to start a board to see if it will start. That's one drive (cd or HDD or whatever as long as it's a drive) the CPU, graphics card (if required) and one bank of memory, unless the board requires dual matching chips.. (that's not a required eliminate, but it helps avoid beep codes) Also, make sure you have your pin's set on the board absolutely correct, or that could be your problem to begin with. Also, if your going to load a ide drives, make sure you set your pin settings for master/slave/CS are set correctly on it. Now, you should get the power supply on, and the cpu fan spinning. If those don't power up, it's then either one of the six elements. The CPU, Power supply, Ram, Drive, graphics card or finally the motherboard. The next step is to replace each one of the elements with another to see if you get any change. Also, on the drive, try a different cable to make sure it's not that. I usally start with the drive, then move to the memory chip, next CPU, Last PSU. I also make sure that my replacements work on another machine first. If no change, then it's save to say you have a bad Board. It's a lot of work I know, but it's the sure fire way of finding out what isn't working.
Please don't forget to leave a rating.
Thanks Mark
May 15, 2010 | Biostar P4M900-M4 Motherboard
I have an Antec full tower with a 350W power supply it seems somewhat old...i hooked everything up inside and tried to turn it on but it would not turn on any suggestions?
First, is there power from the power supply? Is the power supply turned on in the back? If there is powere to the Mobo, then the mobo is likely the problem. The cpu fan fan should spin if there is ower to the board.
Apr 20, 2010 | Computers & Internet
Sounds like either you have a faulty memory stick, faulty CPU or CPU fan or a faulty Mobo..
Mar 16, 2010 | Computers & Internet
HI, I have an Acer Aspire AM5641-B5540A. THE SYSTEM IS COMPLETELY DEAD. i HAVE RULED OUT A BAD POWER SUPPLY. WHAT DO YOU THINK COULD BE THE PROBLEM?
I understand now that you really checked out that power supply. Before we rule out a dead mobo, you should make sure the on off switch on the computer case is not broken.
Look on your mobo and find the power switch leads from your case power button to your mobo and remove them. Short out these two pins with a small screw driver and see if computer goes on.
http://www.pctechbytes.com/troubleshooting/detail.php?How-to-Bypass-A-Motherboard-Case-Switch-8
If that fails, and you checked your memory and CPU, then well, R.I.P. motherboard.
Hank
Oct 06, 2009 | Computers & Internet
Mobo does not power up Dead cpu dead mobo?
A dead CPU will not hinder a board from powering up. The board is unlikely to POST. However, you should heard attempts at powering up and immediate shutdown. Or, you will see the PSU comes on but system not boot.
No mobo, but, CPU.
If no failed attempts at boot, no indicator lights, then you have either a failed power supply or DEAD motherboard.
Good luck
Sep 27, 2009 | Fujitsu Siemens Computers & Internet
Motherboard problem
The mother board is bad. there is only two things that keep it from running. the power box or the monther board. most of the time it's both.
Nov 22, 2007 | EliteGroup P4VMM2 Motherboard
Dell dimension 5100 won't power on
might be a problem with the power button...try exchanging the power adapter and the reset adapter in your motherboard...this would become:
RESET BUTTON: as power button.
view your manual on where to find this adapters in your board.
Nov 19, 2007 | Dell Dimension 5100 (D51L1) PC Desktop
Computers & Internet Logo
70 people viewed this question
David Payne
David Payne
