Question about Magellan Maestro 4040 GPS Receiver
Freezzes on ups connection when it comes on in my car.
    President:
  • 1,111 Answers
Turn your 4040 on, then when it freezes, use a paper clip or something similar to depress the reset switch located on the lower left side of the 4040....if that fails, let me know and i will help you fix this.
Posted on May 10, 2010
Hard drive makes a noise then computer freezzes on and off, why?
Your hard drive is going bad. I would recommend that you back-up your data before the drive no longer works.
Here is something you could try to tell how bad your hard drive is. Take the hard drive out of your computer and put it in your freezer for about 10min and then take it out and plug it in and see if it works without freezing. We used this trick in CCNA school to recover data from hard drives. This should allow you enough time to start saving your data.
(You can do it multiple times to get your information saved, It does not hurt the hard drive in any way.)
Jun 23, 2010 | E-Machines eMachines Desktop PC
Vivitar 8025 comes up msdc when i connect usb lead to my computer
It's supposed to do that, informing you that it's in mass storage mode. Once connected you control it from the computer, not the camera.
Nov 03, 2009 | Vivitar ViviCam 8025 Digital Camera
I have a toshiba satellite laptop. sometimes it freezzes and then goes to blank grey screen. I have to reboot to get it to go away. and someyimes it wont do it again for week or so.
You probably have some bad spots on your hard drive. The satellite has been around for awhile. I have been doing this for 20 years and have seen the problem before. The best solution is to live with it. If you are ambitious you may want to try reinstalling windows to a different version. Sometimes that helps
Aug 15, 2009 | Computers & Internet
When i turn my psp on it freezzes then shuts off
if u tried changing the xmb waves, look for original sony waves file on google. then put the file"system_plugin_bg.rco" file to flash 0/vsh/resource.
if u didn't just rehack the psp.
if u didn't hack it at all, contact sony, i broke my ps3 once and they sent me another one 4 free. hope this helps.T_T
Dec 10, 2008 | Sony PlayStation Portable (PSP) Console
Phone freezzes when i text
Much like Windows or a Mac, the Razor's functions are controlled by an Operating System. And, you can run out of memory. More specifically, the OS for your phone can run out of temporary working space when free memory falls near or below 10%.
You have two options, but first export your address book and ring tones using one of your apps.
1.) Delete some entries in your inbox, be they images or songs and do a soft reset of the phone by turning the phone off, removing the battery for a short time. Reinsert the battery, turn the phone on and try texting again see if that works out.
OR
2.) Take your phone to one of your carriers stores and ask them to upgrade your simm chip with one that holds more memory and ask them to do a hard reset after explaining what has been happening.
Either way, probably the second choice will set you right and you'll be better off more storage than you have now. If they test your phone and an error code indicates the problem is fatal they will advise you on your options. Keep in mind, this could be a fatal error and it may and probably is not. There is no easier answer I can give you other than what I've stated in the above.
I know this hasn't fixed your problem, but you are well on your way to having your problem fixed if you take it in if option 1 does not clear it up.
Regards,
Worldvet
Jun 03, 2008 | Motorola Mobility RAZR V3
Protection Light Is Coming On
try redoing the wires you might have wires touching somewhere if that dont stop it try new RCA wires
Jan 08, 2008 | Lanzar Vibe 235 Car Audio Amplifier
My green light comes on but no soun
If the voltage is dropping to 0.06v, there is a bad connection somewhere. It's likely a defective fuse or a corroded connection. Also check the ground connection.
Oct 30, 2007 | Sony Xplod XM-1652Z Car Audio Amplifier
Sandisk Sansa e250
These are the most common methods for recovering Sandisk's Sansa Mp3 Players. I have been almost universally successful in recovering Sansa players using one or a combination of these methods. These methods do not work if you are having synchronization or music format issues - they are for recovering a player that will not power up, freezes, flashes, is not recognized by the computer, and a host of other issues.
Reset the Sansa Player first. On most models, restart is done by holding the power button in for 15 seconds or longer. Check your specific manual to be sure. The manuals are available from the Sansa website if they have been misplaced.
Download the Sansa Recovery Tool from the Sansa website.
Format - Erases Everything: Connect your Sansa player to the computer and open Windows Media Player. Click on the Sync tab. Pull down the drop down menu underneath the Sync tab by moving your cursor over the Sync tab and left clicking on the little black arrow underneath the Sync tab. Highlight "Sansa 1GB" (wording may vary slightly), and then select "Format." - this should erase everything.
Firmware Upgrade- Erases Everything: Get the latest firmware upgrade from Sansa - it updates the firmware and erases every song in the player all at once. Note: this method doesn't work if already have the latest firmware. Go to this website and click "Firmware Updater" to find out: http://www.sandisk.com/DriverDownload/driverList.asp
If these fail, then:
Try this: disconnect the player from the computer, turn it off, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard.
If you get the problem where MTP Device keeps popping up continuously, uninstall the “MTP Device” by going to Start à Control Panel àSystem à Hardware à Device Manager (you computer may vary slightly, depending on Windows Version).
You may have to restart your computer after each of these methods to get them to work properly. Disconnect your Sansa player BEFORE shutting down your computer.
-Tha Mp3 Doctor
Aug 16, 2007 | SanDisk Sansa e200 MP3 Player
Magellan Maestro 4040 GPS Receiver Logo
109 people viewed this question
Top Magellan GPS Experts
Jungle Ghost
Jungle Ghost
Are you a Magellan GPS Expert? Answer questions, earn points and help others
