Question about Motorola Mobility SLVR L7 Cellular Phone
Hi there where to begin...I'm i Puerto Rico and I have a sliver, with Claro. I connect dial up at a rocking 21 kbps. My phone service man can connect here using his cell phone at 230 and I'm looking to do the same. What do I need to do. Claro can connect me, here comes the interesting part: (at leat to me). I know I need a USB, and some softwear. How can I get that software and the cable? Radio Shack here of course doesn't have it. And I'm probably getting half the info. Can you advise please about what, and how I can get it, thanks. Marlene
Get a Bluetooth device the device is provided win a CD install it.
power 'ON' the Bluetooth and pair the device using a pass key(eg. '123')on both the computer and mobile. and click on dial-up network.
dial the dial -up number(eg.*99#) provided by your service provider.
Posted on May 27, 2008
SOURCE:
I want to send a check to someone in Bayamon, Puerto Rico. Is there a Bank of America in Puerto Rico?
As a matter of fact, yes. Here is the particulars.
255 Avenida Juan Ponce de Le?n, San Juan, 00917, Puerto Rico Phone:(202) 910-2599
Dec 10, 2015 | Cars & Trucks
ENTER NETWORK MEP CODE
Contact your carrier for the code.
Nov 23, 2013 | RIM BlackBerry Curve 3G 9300 Cell Phone
Unlock lumia 800 claro puerto rico
Try calling either #228 or i think its *228 and re-programming your phone, it will change the lock code to its default, he last 4 digits of your number without changing anything else
Jul 06, 2012 | Nokia Lumia 800 - 16gb - Black Gsm Locked...
No 3G network using it with claro carrier
The reason your Vibrant wont get 3g with Claro in Puerto Rico, is because T Mobile broadcasts their 3G at 1700Mhz, and Claro does at 1800Mhz, like AT&T. T Mobile phones cant receive the 1800Mhz signal, so you will never be able to get 3G on T Mobile phones, unless you use T Mobile. You must get the T Mobile phones, as unbranded international phones, to be able to get 3G with Claro and AT&T.
Mar 02, 2011 | Samsung Vibrant
Im tryng to send a fax to purto rico but 4fax
Get Magic Jack and connet it to your computer. You can connect to a fax machine, telephone, and call to Puerto Rico. Connect this to your Computer. You now have an option to call or fax anything.
http://www.magicjack.com/5/index.asp
If this information is helpful, pls rate me.
Good Luck.....
Thanks
Feb 14, 2010 | Brother Multi-Function Center MFC-240C...
9397056163 address plz
939-DDD-DDDD .........
It's either Homer Simpson's fictional area-code, or, in real-life ...
Area code 939 - Puerto Rico
Due to a shortage of 787-related numbers that was a result of increased cell phone and modem usage on the island, 939 was created as an overlay for the original 787 area code. Most telephone numbers in Puerto Rico that have this area code tend to be wireless phones.
As an overlay, the area code was added sometime around September 2001. The 939 area code was created following 787's split from the legacy regional 809 area code.
When in Puerto Rico, the full area code + seven digit phone number must be dialed.
Area code 939 In Popular Culture Is a Area Code of Springfield (The Simpsons) a fictional city in U.S.
Jan 19, 2010 | Microsoft Windows XP Professional
I HAVE A CLARO ACCOUNT BUT CANNOT GET INTERNET
I found these internet settings for Claro from another website:
http://forum.itechinnovations.com/index.php?tid=101
Claro's Internet Settings are:
WEB CLARO & Java Claro
homepage: http://internet2g.claropr.com
APN: internet.claropr.com
Port: 8080
username:
password:
authentication: none
Primary DNS: 0.0.0.0
Secondary DNS: 0.0.0.0
IP address:
WAP CLARO
HOME: http://wap2g.claropr.com
PROXY: 10.50.38.3
Port: 8799
APN:wap.claropr.com
MMS CLARO
Homepage: http://mmsg.claropr.com:1021/mmsc
APN: mms.claropr.com
PROXY: 10.50.38.3
Port: 8799
username:
password:
IP address:
This is how you set it up on your phone. Just substitute the settings provided with the ones above:
From: http://www.tomshardware.com/forum/49719-36-a008-ming-xing
The setup of WAP and MMS on your DUALSIM Mobile Phone is carried out in 4 stages.
• MMS Data Account Setup
• MMS Setup
• WAP Data Account Setup
• WAP Setup
Step 1 – MMS Data Account Setup
1. Go to the following menu “MENU > SERVICES > DATA ACCOUNT > GPRS > Select an empty Account”
2. Edit the following parameters in the account
a. Account Name = OptusMMSGPRS
b. APN = mms
c. User name = [blank]
d. Password = [blank]
e. Auth. Type = Normal
3. Exit back to MAIN SCREEN.
Step 2 – MMS Setup
1. Go to the following menu “MENU > MESSAGES > MMS > MMSSETTINGS > SERVER PROFILE > SIM 1 or 2 > Select an emptyAccount”
2. EDIT the following parameters in the account
a. Rename Profile = Optus MMS
b. Homepage = http://mmsc.optus.com.au:8002
c. Data Account = OptusMMSGPRS
d. Connection Type = WAP
Proxy Address = 061.088.190.010
e. User Name = [blank]
f. Password = [blank]
3. BACK then ACTIVATE PROFILE and exit back to the MAIN SCREEN.
4. Your Phone is ready to access WAP and MMS services.
Step 3 – WAP Data Account Setup
a. Account Name = OptusWAPGPRS
b. APN = prepaidyesoptus
Step 4 – WAP Setup
1. Go to the following menu “MENU > SERVICES > WAP >SETTINGS > EDIT PROFILE > SIM 1 or 2 > Select an empty PROFILE> EDIT PROFILE”
a. Rename Profile = Optus WAP
b. Homepage = http://networker.optus.net.au/wap/index.wml
c. Data Account = OptusWAPGPRS
Proxy Address = 202.139.083.152
Hope this helps!
WizardRepair
Jul 17, 2009 | Cell Phones
My GPS map has only Hawaii and Puerto Rico
there maybe a upgrade for maps out online you can get to help. I have the same GPS as you, and I have 48 state maps and canada and puerto rico on mine.
Feb 11, 2009 | Magellan RoadMate 1400 Car GPS Receiver
Motorola Mobility SLVR L7 Cellular Phone Logo
63 people viewed this question
Top Motorola Mobility Cell Phones Experts
D. E. Hev
vince
Lawrence Oravetz
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
