I was working with Benimur for along time and he disappears.I would like to reconnect with him since he is familiar with my unresolved printer problem
    Brigadier General:
  • 6,966 Answers
And Hi again.
There you are. I posted in your original post. In any case did not disappear. the Live Session sort of closed on us.I was working with Benimur - ac3158a.jpg
With your indulgence may we continue in your original post (http://www.fixya.com/support/t472742-unable_print_document_1_quot)
Posted on Mar 28, 2008
Stop the two red lights on my epson r200
Please try this procedure one more time using the instructions below.
  1. Turn the printer off, and disconnect the interface cable.
  2. Turn the printer back on.
  3. If the error lights disappear, turn the printer off and reconnect the interface cable. Turn the printer back on and try printing again.
  4. If the error lights continue, unplug the printer power cord for a few seconds and reconnect it to a different power outlet.
  5. If the printer is plugged into a power strip or surge protector, try plugging it directly into the outlet.
Note: Also check that the ink cartridges and lids are pushed down fully.
If the problem persists, an unknown printer error has occurred. The printer may require service.
Sep 24, 2014 | Epson Photo Office Equipment & Supplies
Dragon NaturallySpeaking 9 preferred will not work, Microsoft Excel
i do not understand your problem, can you please reexplain
Nov 29, 2007 | Computers & Internet
Tip
Buying s6 edge plus LCD replacement for phones can be a toss up
Buying s6 edge plus LCD replacement for phones like this can sometimes be a toss up. After installing it and having used my phone (with new screen) for weeks now I feel confident saying mine worked perfectly! It's like having a brand new phone. If you install this screen and are seeing lines on the display it's not a manufacturing problem, it just means the connector is loose/slightly misaligned. If this happens when you first power your phone back up, simply disconnect and reconnect the plug for the display. May take a few tries. With a little trial and error they should eventually disappear once it's properly aligned.
Keep in mind replacing this yourself is doable but will take lots of patience and time. Lots of things to disconnect and reconnect. Followe along with a Youtube tutorial. Samsung Galaxy S6 Edge Plus Replacement Parts Galaxy S6 Edge Plus LCD...
on Apr 07, 2017 | Electrical Supplies
How I can Hardware TEST IN service mode
Canon (I think your product?) recommends the following:
Please attempt to reset your printer as outlined below:
1. Disconnect the power cord attached to your machine while "on" for up to 10 minutes.
2. Reconnect the power cord for the unit and plug it into a different known working outlet direct to the wall (not a surge/power strip) to ensure it is receiving full power.
4. Once your unit has initialized, confirm an error is not displayed in the LCD.
If unresolved, please refer to your Canon support contacts for further assistance and whether a firmware update may be available to address the issue or if service may be required.
May 25, 2014 | Canon ImageCLASS MF4350d Laser All-in-One ...
C:31:23 code with flashing icon for eject,with a beeping sound
The error message indicates that the Camcorder has detected an issue that may require a power reset.
Step 1:
Try to reset the Camcorder and check if it helps to resolve the issue. Locate the RESET button behind the LCD screen of the Camcorder.
Step 2:
Turn off the Camcorder. Remove the battery or disconnect the AC power adapter for 60 seconds. Insert the battery or reconnect the AC adapter.
Step 3: If still unresolved Service may requires.
Jul 17, 2009 | Sony Handycam CCD-TRV318 Camcorder
Scanner suddenly disappeared from the Applications folders.
First unplug scanner, turn off mac, remove mac battery and unplug adapter, plug everything back , restart and reconnect.
If that did not work, then do the following:
Unplug scanner usb and reinstall scanner/printer software again on your MAC.
Oct 14, 2008 | Canon MP970 Photo All-In-One InkJet...
C42UX problem
An unknown printer error has occurred. Turn the printer off, disconnect the interface cable and turn the printer back on. If error disappears, turn the printer off, reconnect the interface cable and turn the printer back on. If error continues then printer needs service. If printer returns to normal the issue is resolved.
Jun 09, 2008 | Epson Stylus C42UX InkJet Printer
When i try to start my computer it gives me the option to repair or start windows normally....when i try to repair it gives me this error code: 0xc00000e9..... and then when i try to start normally it...
where is asking for start normally look for another option called last known good configuration select it and see.
if he does not work insert your window cd into drive it will tell you press any key to boot from cd rom you press then it will get to a sgtage it will ask you press r to repair or press enter to continue you press r it will take you to dos environment type chkdsk it will scan and recover all lost data then type exit to restart then it wil work
May 31, 2008 | Toshiba Computers & Internet
2006 cobalt ss supercharged
Sorry, but I am not familiar with this model. You may wantto try another expert..try Benimur
PS. dont rate this post, as I did not provide a solution..
May 12, 2008 | Pioneer SD-P50A5-K 50" Rear Projection...
Computers & Internet Logo
David Payne
David Payne
