Question about Mtd 22" Yard Machine Push Mower
How do I change the starter cord on a 22 inch mtd gas powered push mower. I have the intial housing removed but instead of screws on the starter cord housing it looks like rivets and I'm not sure how to take them out. Any suggestions?
    Teacher:
    An expert who has written 2 tips or uploaded 1 video tip.
  • 46 Answers
Don't need to take it out. If you flip it upside down you can see the wheel the cord goes on. Inside the wheel you will see a slot with a hole in it . Get enough slack to cut the knot off and clean out the old rope.
The wheel has a coil spring in it the winds up like a clock spring.
DO NOT REMOVE the wheel if the spring is not broke. It is a pain to get back together .
Wind it up and then stick a screw diver though to keep it from unwinding. Line up the holes and feed a length of pull rope (3 feet or so long) through the holes and tie a knot in the end. Pull the rope and set the knot. Remove the screw driver and let the rope wind itself up. Put the handle on the loose end then pull just enough tension to tie another knot in the rope so the handle stay on and is snug against the assemble when released.
Posted on Jun 09, 2010
Travelling with a push mower in the car
not sure what you are asking
but if you want to put mower in car drain gas or run it all out
try to keep it as flat as possible, the oil will go into cylinder if you dont
remove from car pull the spark plug pull cord a couple times replace plug and gas
Apr 21, 2014 | Mtd 22" Yard Machine Push Mower
Can't pull starter cord
clean the underside of mower so the blade can turn.
Sep 14, 2012 | Mtd 22" Yard Machine Push Mower
Pull cord want retract so i can start mower got plastic cover off but the cord is in medal housing which is held down with three rivets how do i get it off to fix cord.
You have to remove the motor cover that the starter housing is riveted to. Usually three or four bolts around the perimiter of the housing and it will slide off with the starter housing.
May 05, 2011 | Mtd 22" Yard Machine Push Mower
MTD Yard Machine Model # 11A-084E029 Need help putting the pull cord assembly (coil, etc) back together. Standard repair books don't give enough detail. My pull cord broke, I bought just the cord, took...
Remove the recoil assembly from the mower, there are 3 machine screws.
Remove the old rope and get matching cord, make sure you get the correct diameter, usually 3/16 or 1/4 inch, and type, I believe it should be nylon braided. Do not cut the new cord.
Use a match to light the end of the cord and once it ignites, use an old rag to pull and form the end into a point.
Notice which way the pulley in the starter assembly rotates and hand spin it in that direction until it is fairly tight. Once it is tight, rotate it into a position such that you can push the pointed end of the cord from the outside into the hole in the housing of the starter and directly into the hole on the inner pulley. Tie a tight knot in the end of the rope inside the pulley.
Remove the clamp and let the rope get rewound on the pulley. Cut the cord, point this end and run it into the handle and knot it.
Gary
Apr 30, 2011 | Mtd 22" Yard Machine Push Mower
MTD Yard Machines 22'' mower, pull cord won't extend
From what you describe it sounds like the line may be tangled, remove the rewind housing in order to inspect the line up close.
Jun 03, 2010 | Mtd 22" Yard Machine Push Mower
Lawnmower won't start
Remove the bowl from the carb. and blow it out with air.
May 07, 2010 | Mtd 22" Yard Machine Push Mower
MTD Yard Machine CD000147 6HP 21 inch ..The problem is "Cannot pull the starter string for start. The string or engine stuck to pull the starter. We didn't use it for the whole winter.
The operator presence bail must be in the run position to release the flywheel brake. If you can't pull the rope with the bail in the run position, your rope is fouled. You will have to remove the shroud and take it to a repair shop.
Apr 19, 2010 | Mtd 22" Yard Machine Push Mower
Lawn mower troubles
You must first remove the cover assembly which houses the starter pulley. Pull the old rope completely out until it no longer moves. Hold the starter pulley and remove the old rope. Try to wind the starter pulley spring tighter if possible. DON'T LET GO. The starter rewind spring must be wound before installing the new rope. After winding the spring, thread the new rope through the cover and into the hole in the pulley. Tie a good knot in the end and let the rope wind slowly into the housing. Once you have this done, replace the cover, get the proper length of rope, thread it through the handle, tie a knot in this end and your ready to go.
May 19, 2009 | Mtd 22" Yard Machine Push Mower
Broken starter cord MTD Model 125-478R062
try this link.
http://www.smallenginesuppliers.com/shop/html/broken_starter_rope.html
you will want use size #4 or 4.5 starter rope. about 7 foot in length.
Mar 17, 2009 | Mtd 22" Yard Machine Push Mower
Mtd 22" Yard Machine Push Mower Logo
403 people viewed this question
Top Mtd Garden Experts
Jim Parker
Jim Parker
Tim Whalen
Phil Walker
Phil Walker
Are you a Mtd Garden Expert? Answer questions, earn points and help others
