Question about Jl Audio 12W7 Car Subwoofer
I have two jl audio 12 w6v2 running with a jl audio 1000/1 and at high volume they make a poping noise does any one know y
    Problem Solver:
  • 7 Answers
Could be a power serge in your remote wire try different power sourse could be alot of things id try this 1 1st
Posted on May 14, 2010
2 Suggested Answers
  • 417 Answers
SOURCE: i have two jl audio 12 w6v2 running with a jl
That popping noise is your speaker telling you to turn it down, and that your amp is too powerful for your setup. The speaker cone is moving beyond its limits of excursion and on it's way to malfunction/blown. Basically the voice coil will fry.
Posted on Apr 03, 2010
I have a 1000/1 amp running two W6s in my truck along with a 300/ going strictly to my highs, i also have a capacitor for 1000 that only runs for the 1000/ amp and a JL audio 100 amp fuse for all of it....
You need to get another capacitor and wire it in series with the fist cap when you crank the volume your system is not getting enough power from the alternator this is called surge current. In modern electrical systems we use capacitors to compensate for these surges.
Mar 05, 2011 | Jl Audio 1000/1 Car Audio Amplifier
One sub not working
Try this....the speaker that is not working, gently work the cone up and down with you fingers. Be careful not to go right thru the cone. One hand underneath(near webbing) and one hand on top over the dust cover. If you hear any kind of scratching, or noise, or it's not "breathing" freely, then the voice coil of that speaker may have overheated, or the speaker has extended above and beyond its range of movement (called excursion). And may as well be blown/dead/fried..however you want to say. I hope this is not the case for you.
Apr 26, 2010 | Jl Audio 10W6v2 Car Subwoofer
Mar 16, 2010 | Jl Audio 12W7 Car Subwoofer
What would be a better amp for my jl audio 12in w6v2
its not the amps my dude ur ohm loading is wrong if u have a 4 ohm stabled amp n ur speakers r 2 ohms naw thats not gonna fly caus it cant put out what ur asking 4 so u need 2 reload ur subs try this link http://www.bcae1.com/spkrmlti.htm this should help u out n save u money
Jun 17, 2009 | Jl Audio 12W6v2 Car Subwoofer
Jl audio 1000/1 low voltage -keeps shutting off at high volume
You should definitely upgrade the power wire to the sub amp to 4 gauge -absolutely your choking your amp its starving for current-poor thing is starving !!!!!!!
Apr 16, 2009 | Jl Audio 1000/1 Car Audio Amplifier
ALPINE PDX 1.1000
well you would have to look into the ohms of the amp compared to the ohms of the speaker. If the ohms are different you would have to hook them up in a different way. check the RMS on the speaker as well as the amp, this can also be sufficed by wiring it different if ohms match up properly! Hope this helps you out and if this is not the case let me know.
Feb 28, 2009 | Alpine PDX-1.1000 1000W x 1 Car Amplifier...
Jl audio 500/1 amp low ohm light at high volume
I would try running the subs in parallel. Pos to Pos Dual Voice, Neg to Neg Dual Voice. Then Run + to + stereo - to - stereo on both channels.
So you have + and - running to one channel and + and - running to the other channel.
Also your LPF filter could be set too high.
Feb 07, 2009 | Jl Audio 500/1 Car Audio Amplifier
Jl 1000/1 popping fuse
well you need to check to see if nt no shottage with the amp and also check if the fuse is not to low amp 20,,,, 25 if not put the amp in a separet 12 volt battery
Dec 10, 2008 | Jl Audio 1000/1 Car Audio Amplifier
Amp problem
you either have a bad ground or your power line is too small, the farther you go from the battery the larger wire you need.
Dec 18, 2007 | Jl Audio 1000/1 Car Audio Amplifier
Low ohms light ! ! ! !
How are the speaker wired and what is the ihms for the speakers?
Dec 06, 2007 | Jl Audio 1000/1 Car Audio Amplifier
Jl Audio 12W7 Car Subwoofer Logo
218 people viewed this question
Top Jl Audio Car Audio & Video Experts
Mark Skinner
Tygh Duval
Tygh Duval
Matthew Spark
Matthew Spark
Are you a Jl Audio Car Audio and Video Expert? Answer questions, earn points and help others
