Question about Samsung (DSSM522452OEM) CD-RW Burner
My dvd burner disappear
My dvd burner Tsstcorp disappear in my computer window,I still see it in device manager with a yellow sign ,i update the driver ,it failed..I try to plug another external dvd burner pioneer,the pioneer still goes the same as the tsstcorp.help me pleasr
  • 1 more comment
  • Rusty-60 Jul 04, 2008
    I have a brand new PC, AMD Phenom 9750, Asus M3A MB, 4 GB Corsair Twinx ram, 2 x 640Gb HDD Asus GE 9600GT Video, so it should all work really well.
    bUT My dvd burner Tsstcorp disappear'S in my computer window, I still see it in THE bios and device manager with a yellow "!" sign , I updated the driver, it failed..I tried to plug another external dvd burner LG and another Samsung but still goes the same as the tsstcorp. This happened 5 times after I had installed a Video editing program. Power Director 6. I am Running Win XP 64bit. It done the same after installing regsupreme. I do video editing so I need the DVD burner to operate properly.
    Help would be appreciated thanks.
  • Anonymous Jan 04, 2009
    I have very similar problem but I am running Vista. Burner was running fine until an automatic update finished installing. Now it shows up in the device manager as this device cannot start. (code 10). Most current drivers are installed. Any help would be greatly appreciated.
  • nelsondlgd Jan 07, 2009
    I also have exactly the same problem.
  • 807 Answers
Try this.
  1. Click Start, then Run, then enter REGEDIT to open the Registry Editor
  2. Navigate to the HKEY_LOCAL_MACHINE/SYSTEM/CurrentControlSet/Control/Class entry
  3. Under the Class entry, double click on {4D36E965-E325-11CE-BFC1-08002BE10318}
  4. In the right-hand pane, click ONCE to select the UpperFilters entry
  5. Make sure the UpperFilters entry is highlighted, press Delete, then Yes.
  6. In the right-hand pane, click ONCE to select the LowerFilters entry
  7. Make sure the LowerFilters entry is highlighted, press Delete, then Yes.
  8. Close the Registry Editor by clicking File, Exit.
  9. Reboot.
Posted on Mar 28, 2008
I had a problem similar to this. I had to remove my ITunes software and everything worked fine. Apparently ITunes and Vista dont jive on some computers. Its a little known problem.
Posted on Oct 26, 2009
SOURCE:
Hp pavilion dv 6910us with windows 7 ultimate 64 bit doesn't recognize my installed dvd rw drive by pioneer model kd08... sometimes it will appear in devices with removable media but will later...
this could be a registry issue
Click start control panel administrive tools,computer management,device manager scroll down cd-dvd rom drives you might see a yellow question mark ? right click you will have options to update driver,roll back driver,or select properties general troubleshoot, select driver click to reinstall drivers click update driver or uninstall then reinstall if this does not fix the problem it might be a registry problem if you cant see your disk drive in windows explorer
Close all open programs
Click on Start, Run, and type regedit and press Enter
Click on the plus signs (+) next to the following folders
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
This folder is the DVD/CD-ROM Drive Class Description in the registry. Look for any of the following names in the right hand column.
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
If any of the above keys shown in step 4 are listed, right-click on them and choose Delete
After deleting the keys, close the registry editor
Reboot your computer
Open My Computer and check to see if your CD or DVD drives have returned. You may also want to open Device Manager and verify that the yellow exclamation and error code on the CD or DVD drive is gone. or
you might have to physically unplug the leads for this cd/dvd then plug them back this should activate the found new hardware wizard or
you might have to uninstall then restart your computer then reinstall your DVD/CD then reinstall the driver for this device
if your computer came with a motherboard disk the drivers could be on it
click start control panel administrive tools computer management device manager scroll down cd dvdrom drives if you see a yellow question or exclamation mark? ! or a red x right click you will need to update the driver or
hope this helps you
Sep 08, 2011 | Pioneer DVR-KD08 DVD±RW Dual Layer Burner
I'm currently using Windows XP, and have: TSSCorp SH-S182D and SH-S183L. Neither are currently working - they show up in the Device Manager, but the Samsung drivers I try to update them with never...
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
click start control panel administrive tools computer management device manager scroll down cd dvdrom drives if you see a yellow question or exclamation mark?! or a red x right click you will need to update the driver or
hope this helps you
Aug 18, 2011 | Samsung SH-S182 DVD±RW Dual Layer Burner
My burner comes on for a second and shuts back off
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
hope this helps
Jul 14, 2011 | Gear Head 8XDVDEXT DVD External Slim...
Laptop does not see device. windows xp sp3 os. Cannot find any drivers for device.
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
hope this helps
Jun 13, 2011 | Lenovo USB Portable DVD Burner - DVD±RW...
The program no installed ( windows)
if you mean that the dvd is not installed
you might have to physically unplug the leads for this cd/dvd rw then plug them back in or
you might have to uninstall then reinstall your DVD/CD or uninstall the driver then reinstall for this device
click start control panel administrive tools computer management device manager scroll down cd dvd rom drives if you see a yellow question mark? right click you will have options to update driver,roll back driver,or
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
Hope this helps
Jun 08, 2011 | NEC ND 1100 (50022667) DVD+RW Burner
Will Not Play a Music CD, Will Not Burn Music downloads ,Messege" connect Burner " ?? Burner is already installed .
you might have to physically unplug the leads for this cd/dvd burner then plug them back in this should activate the found new hardware wizard or you might have to uninstall then reinstall your DVD/CD or uninstall the driver then reinstall for this device click start control panel administrive tools,computer management,device manager scroll down cd dvd rom drives right click you can you can update driver roll back driver or select properties general troubleshoot, select driver click to reinstall drivers click update driver or uninstall then reinstall Click start control panel administrive tools,computer management,device manager scroll down cd-dvd rom drives you might see a yellow question mark ? right click you will have options update driver roll back driver or select properties general troubleshoot, select driver click to reinstall drivers click update driver or uninstall then reinstall if this does not fix the problem it might be a registry problem if you cant see your disk drive in windows explorer Close all open programs Click Start, Run, and type regedit and press Enter
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
hope this helps
Jun 02, 2011 | Lenovo 42Y9354 CD-RW Burner
Dvd burner for windows has gone
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
Hope this helps
May 29, 2011 | Dell (7W036) DVD+RW Burner
My cd drive writer 640c won't work, I check the device manger and it had a Exclamation sign in yellow by it
HI,
open device manager, right click on cd-dvd driver with yellow ! mark and select uninstall
it would be disappeared.
then open the following Fixit software weblink and run it
http://support.microsoft.com/kb/929461
restart computer, yellow !mark would be gone ..
issue resolved :)
May 26, 2011 | Computers & Internet
I am looking for the windows 7 starter driver to install my usb to serial adapter. XCS-RS232.
click start control panel administrive tools computer management device manager scroll down cd dvd rom drives if you see a yellow question mark? right click you will have options to update driver once you have select update windows will ask where to find the driver and if you want to connect to the internet
click start control panel administrive tools ,computer management ,device manager look through all of your devices if you see a yellow question mark?or exclamation mark ! or red x
right click to reinstall drivers
if your computer came with a motherboard disk the driver could be on it
hope this helps
May 10, 2011 | Freecom Classic CD-RW/DVD-ROM Burner
Wont come ,seems to have disappeared
make sure that the dvd burner is getting enough power test all leads that are attached to the dvd burner including electical extensions and make sure they have a secure connection or just replace them there might be bad/faulty or the drivers may have been corrupted or you might have a virus run your antivrus program you might have to physically unplug the leads for this cd/dvd burner then plug them back in this should activate the found new hardware wizard or you might have to uninstall then reinstall your DVD/CD or uninstall the driver then reinstall for this device Click start control panel administrive tools,computer management,device manager scroll down cd-dvd rom drives you might see a yellow question mark ? right click you will have options to update driver,roll back driver,or select properties general troubleshoot, select driver click to reinstall drivers click update driver or uninstall then reinstall if this does not fix the problem it might be a registry problem if you cant see your disk drive in windows explorer
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
hope this helps
Apr 09, 2011 | Gateway (5502572) DVD±RW Burner
Samsung (DSSM522452OEM) CD-RW Burner Logo
2,834 people viewed this question
Top Samsung Computers & Internet Experts
Ekse
asber
RONALD CARTER JR
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
