Question about Brother IntelliFAX 885MC Plain Paper Thermal transfer Fax
Help need help with fax
    President:
  • 2,072 Answers
What is the issue?
Posted on Mar 28, 2008
SOURCE:
I cannot receive fax on my dell940 printer. help
The A940 is not a standalone fax machine, and needs to work with your computer to send and receive faxes. Your computer needs a dialup modem installed and a connection to a phone line, and you need to have fax software installed. The printer actually only works as a scanner to input a document to be faxed, and as a printer to display a received fax. The installation CD supplied with the printer has fax software on it you can install, and other software is available online. This document from Dell (the fax section of the user's guide) may be helpful.
Jul 29, 2011 | Office Equipment & Supplies
Have changed phone service providers. they say that the fax mach. and land line can work together. I say i need another phone line for the fax mach. please help. the fax mach. is a hp 1040 fax. jeff h.
If they changed you over to Vonage or some other digital service, the fax machine will not work reliably.
You need a plain old telephone system POTS for your fax. All faxes are analog.
Nov 12, 2009 | HP 1040 Plain Paper Inkjet Fax
C6180 FAX UNABLE TO SEND OR RECEIVE
check the the phone line, The fax sinal need good clear. Surely,plug the phone-line is rigth line socket. If you do that all, the broblem is still happenning,need to change "relay" on moderm fax board.
Jul 27, 2009 | HP Photosmart C6180 All-In-One InkJet...
Need to change 1 fax number in group dialing on a cfx-L4000 fax
All the numbers saved in group dail,are separatly saved in the one touch speed dails,you have to locate that fax number in one touch dails and change it there.
Nov 19, 2008 | Canon Laser Class 310 Fax
I need help on my sharp fax
I need instructions to receive a fax
Oct 24, 2008 | Sharp UX B700 Plain Paper Inkjet Fax
Please help me send a fax on my HP 5610
Send a fax
You can send a fax in a variety of ways. Using the control panel, you can send a blackand-
white or color fax from your HP All-in-One. You can also send a fax manually
from an attached phone. This allows you to speak with the recipient before sending
the fax.
If you frequently send faxes to the same numbers, you can set up speed dial entries.
For more information on setting up speed dial entries, see Set up speed dialing.
Send a basic fax
You can easily send a single- or multiple-page black-and-white fax by using the
control panel, as described here. If you want to send a color or photo fax, see the
onscreen HP Image Zone Help.
Note If you need printed confirmation that your faxes were successfully sent,
enable fax confirmation before sending any faxes. For more information, see
Print fax confirmation reports.
Tip You can also send a fax manually from a phone or by using monitor
dialing. These features allow you to control the pace of your dialing. They are
also useful when you want to use a calling card to charge the call and you
need to respond to tone prompts while dialing. For more information, see Send
a fax manually from a phone or Send a fax using monitor dialing.
1. Load your originals, with the print side up, into the document feeder tray. If you
are sending a single-page fax, such as a photograph, you can also load your
original on the glass.
Note If you are sending a multiple-page fax, you must load the originals
in the document feeder tray. You cannot fax a multiple-page document
from the glass.
2. Press Fax.
Oct 10, 2008 | HP OfficeJet 6110 All-In-One InkJet...
Brother intellifax 4750e
if the copy comes out black and/or sends black the Contact Image Sensor in the scanner may be needed.
Hope that helps...
Jun 17, 2008 | Brother IntelliFAX 4750 Plain Paper Laser...
Sharp fax machine: help!
look to see if it is in tel,fax,or a.m. mode you need to have it in fax mode.tel=telephone,a.m.=ansering machine
May 09, 2008 | Sharp FO 3150 Plain Paper Laser Fax
Wont recv.faxes but will fax out,which setting do i use for incoming/out faxes
sir,
check the connection and the settings or try to read the manual
yours,
alecz
Apr 01, 2008 | Canon PIXMA MP530 All-In-One InkJet...
Brother IntelliFAX 885MC Plain Paper Thermal transfer Fax Logo
27 people viewed this question
James Cagle
James Cagle
Jim Keysor
ctnozil
