Question about Garden
Need information on how to change drive belt for master craft 3 1/2 /22 front tine tiller
    Problem Solver:
  • 9 Answers
O I SEE THANKS FOR USING FIXYA
Posted on May 10, 2010
Garden master tiller 5020d
Get behind the tiller as if you are ready to use it. Look down towards the tines. There's a protective cover. Remove it and you will see the belt running vertically between the motor and the tines.
May 08, 2013 | Ardisam 5.5 Hp Rear Tine Rototiller
Drive belt is slipping when under load. How do you tighten the belt. thanks, Ted Troybilt Horse rear tine tiller
hi there, ive been doing a bit of head scratching over this one as i needed to check my facts. i think the belt has a automatic spring loaded adjuster so it sounds as if you need a new belt for it.
good luck
iain
Apr 30, 2011 | Troy-Bilt 21AE682L766 Big Red 10 HP...
Need to see belt route for gilson bros. tiller
You did not state if it was a front or rear tine tiller. This is for the front tine tiller:
http://photos.cubfest.com/albums/userpics/10231/Belt_Routing.jpg
The rear belt has a 1/2 twist in it for reverse. The front belt goes on nomally.
If this does not help you I would like a model number if you can locate it so I can get your the proper routing diagram.
Kelly
Apr 14, 2011 | Troy-Bilt Garden
I need to find out what size belt for tine engagement on a Dayton 5hp Tiller model # 32885 C144B
a simple way to figure out the length is to engage the tine mechanism and take a string and wrap it around the pulleys mark it and take it to any belt store, and buy the Belt you need. You will need to know if it's a 3/8s or 1/2 inch drive belt. Normally tine belts are half inch or 5/8 wide on a 5 horse power motor, You can get these belts at sears or Nappa auto parts store. hope this helps.
Mar 19, 2010 | Garden
Tiller goes For./Rev. but wont drive forward with tines engaged
check the sher bolt on the tine to drive shaft. ill need model and ser number off the unit before i can go further with helping you thy changed them around a lot
Oct 09, 2009 | Mtd Garden
Just need to see the order in which the parts go back on the drive assembly for a Ward/Gilson 1575 front tine tiller
which drive assembly do you need info on,the belt drive or the gear box/case ***'y,I have a manual and can send a pic if needed,plus I have microfiche also on most of the Gilson jed1950@earthlink.net
Jul 16, 2009 | Garden
I have an older (30 yrs) Ariens front tine rototiller. Over the past few times I've used it, I've noticed that the tines have started to turn even when I do not have the clutch engaged. It's to the point...
Your belts are grabbing, make sure they are loose when not holding clutch lever. Also make sure that the guide pins are close enough to hold the belt loose when not engaged, I have the same tiller I use now.tines cannot turn if belt is loose enough. Maybe you bought the wrong belts A verses V belt.
Jul 09, 2009 | Garden
Help, new craftsman rear tine tiller stopped tilling.
It sounds like the belt just stretched. Now you need to move the belt tensioner over to put more pressure on it.
Apr 25, 2009 | Craftsman 8.50 Torque Rating Rear Tine...
Garden Logo
59 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
