Question about Brother IntelliFAX 885MC Plain Paper Thermal transfer Fax
Need some help
Hi i have a fax brother 645 i don't have the instruction book..I can't do any coping and not sure if the fax i send is received.. can you please give me some instruction
    Genius:
  • 2,120 Answers
Go to www.brother.com. They might have your manual available for download.
Posted on Oct 19, 2008
Using a brother MFC-J415W printer, what are the steps in sending a fax?
How to fax :
1. Entering fax mode To enter fax mode press (Fax), and the key will glow green.
2. Sending a fax from the ADF (Automatic Document Feeder): Using the ADF to send your faxes is the easiest way. To cancel a fax in progress press Stop/Exit.
a. Make sure you are in Fax mode . b. Place your document face up in the ADF. c. Dial the fax number. d. Press Start.
The machine scans the pages into memory and then sends the document.
3. Sending a fax from the scanner glass : You can use the scanner glass to fax the pages of a book, or a single page at a time. The documents can be up to Letter or A4 size. Press Stop/Exit to cancel a fax in progress.
a. Make sure you are in Fax mode . b. Place your document face down on the scanner glass. c. Dial the fax number. d. Press Start.The machine starts scanning the first page.
For more detailed instructions, you can go directly to Section 4 - page 22 of the manual in Brother's site. Hope this helps.
Apr 14, 2011 | Office Equipment & Supplies
I need the instruction to set the machine right for sending a fax from Cambodia to Australia or receiving a fax from Australia. I typed number in Australis to send a fax but my friend there did not receive...
There is not much to do than to set the machine in the fax mode after setting up the time and data as instructed on the interactive menu .
You need to type the STD code of cambodia and the number of the fax there which must also be active. Make sure that you enter the correct local code if the number is in sub-district.
Ask your friend to send the fax after placing your machine in fax mode.
Make sure there is dial tone and you are able to make calls using the telephone mode.
if not check the connection.
Feb 15, 2011 | Brother MFC-7340 All-In-One Laser Printer
Fax machine can send, but not receive. The line has been tested and is fine
You need to make sure that your fax machine's ability to receive an incoming fax has been enabled. Please read your manual and follow the instructions to enable receipt of faxes.
Don
Jan 29, 2010 | Brother MFC 9700 All-In-One Laser Printer
Brother MFC-8440, send fax ok, but no receiving fax
The manual has step by step instructions, I'll include a link for the online version. Section four runs through setting up recieving, if it's on a dedicated line follow the first set of instructions to set up automated answering. If it's a shared line(phone/fax) then continue down to the next section.
Note: for a shared line you may need to contact your line provider for a second number that has a "dedicated ring"
http://welcome.solutions.brother.com/BSC/public/files/dlf/doc000219/MFC-210C_UsaEngUsr_B.pdf
Hope this helps FixYa,
Chris
Apr 11, 2009 | Brother MFC 420CN All-In-One InkJet...
Able to receive fax but cant send
sleep mode is just a status of the machine when it is in idle mode.you cannot turn this off however you can delay the time before the unit goes into a sleep mode.it has nothing to do when you are sending out faxes.so here are a few things you need to check when sending a fax (1)dial tone by pressing hook/hold button (2) insert the doc into the adf, make sure it will change to "enter fax # and start,or copy press copy (3) dial the number (4) wait for fax tones of the receiving unit before you press start. now if you can hear an operator on the line,that has to be verified with your phone company since brother machine does not restrict incoming and outgoing faxes UNLESS that is restricted from your phone line.
Nov 18, 2008 | Brother IntelliFax-2820 Laser Fax
I need to print instructions on how to use a brother fax -645 machine. how to set and send faxes
An on line manual probably does not exist. Put paper in feeder face down, dial number, press send.
Sep 11, 2008 | Sharp UX 108 Roll paper Thermal Fax
How to use a brother fax- 645 plain paper fax
You may have been given a heap of junk. Happens all the time. Just place the document face down in the ADF and dial the number then press the green button to send.
Feb 27, 2008 | Brother IntelliFAX 885MC Plain Paper...
Unable to Receive Incomming Fax's
I need help with my MFC 240 c Brother printer. I cannot send faxes or receive faxes. I do not know how to set the setting. Plus I lost my book that went with it.
Feb 07, 2008 | Brother Multi-Function Center MFC-240C...
Brother IntelliFAX 885MC Plain Paper Thermal transfer Fax Logo
110 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Jim Keysor
