The Pioneer dvdrw DV-RK17B in my hp dv6646us has read played and burned cd's & dvds with no problem until yesterday. It has not burned the last three dvd projects I've created with Windows dvd Maker. It goes through the burning process and kicks out the dvd. The surface of the disc is visibly altered as in previous discs that work fine. When I try to play the dvd in either a dvd player it says the disc is blank. When I try to play it in the laptop drive it says there's no disc in the drive. What's up?
    President:
  • 1,619 Answers
Sounds like its not closing the sesion.
Posted on May 14, 2010
Dvd driver does not play or burn blank dvds compaq r4000 but it will play dvds & cd its got dvdrw/r rw dvd+r dl n the driver
Try another DVD-RW drive because it sounds like the laser is going bad. Burning requires alot of power from the laser. Playing DVD or playing cd's doesn't require much so thats why it would play those.
Feb 06, 2012 | HP Compaq Presario R4000 Notebook
My pioneer dvdrw dr-td08hb ata in my HP pavillion is not burning anything, I try changing the blank cd and dvds brand and also empty out most of my hard drive, try uninstal and reinstal it again and still...
If your not a PC guru then try removing DVD from device manager and reboot
if your a geek try editing your registry and remove the upper and lower filters from this HIVE HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Class\{4D36E965-E325-11CE-BFC1-08002BE10318}
Aug 25, 2010 | Pioneer DVR 108 Dual format 16X DVDRW...
I have an Hp laptop with a pioneer dvdrw dvr k17b not burning.
dies your burned this work on your PC? if it works on your pc you just have to select the correct settings for your burning software, when you burn does it ask you to burn multiple sessions? if it does and you selected the option create multiple session then what will happen is the disc's you burnt will only work on your windows and not on any other computer or devices that use dvd's or cd's, on the options it will also have a choice for you to choose single session only wherein this will allow you to use the burnt disc in any other computer and will most likely work 100% of the time ^_^ NOTE: this step I gave all depends on the software you use to burn your disc and you may be required to play around your software for some softwares do not have the same info in them but at time be the same in thier function and purpose ^_^ I just based this answer to your question using my NERO
Jun 06, 2010 | Pioneer DVR-107D DVD±RW Burner
I have a dvd/cd SD-R6252 unit in my r3000 compaq presario. I've burned CDa but cannot burn a DVD. I think I know the answer but I want to be sure is this unit capable of burning DVDs?
Hi, well ur DVD\CDRW drive is a combo drive. It can play CDs\DVDs but burns only CDs as it's NOT a DVDrw @ the same time. It won't burn a DVD.
.... In future I propose u either to replace the drive by a DVDRW or u may buy an external slim dvdrw if u want to keep ur existing drive as well. 2nd solution is best BTW.
Feb 08, 2010 | Compaq Presario R3000 Notebook
Hp laptap pioneer CD wont play
I had the same problem. Go to the link below and follow the directions. Don't worry if you don't have a lower limit directory. I didn't and it still worked. Before restarting go to the device manager and uninstall the driver. I have a similar computer to yours and when I restarted it automatically reinstalled the driver.
http://support.packardbell.com/uk/item/index.php?i=topic_02125&ppn=PB42B00901
Feb 20, 2009 | Pioneer DVR 108 Dual format 16X DVDRW...
PIONEER DVDRW DVR-K17B ATA Device Issue in HP Pavilion DV9500 Lap
you may need to clean the lens of drive with a wet tissu paper, otherwise the drive might gone out of order, need replacement.
Feb 10, 2009 | Pioneer DVR-107D DVD±RW Burner
DVD RW DVR-K16 does not recognize blank DVD-R
I have a Pioneer DVDRW DVR-K16, in a sony dv81114Notebook. Running Windows XP. It cannot play dvd's and cd's, It will recognize blank CD-R's but when I insert a DVD-R it say's no disc installed. I have firmware version 1.15.
Nov 26, 2008 | Pioneer (DVR-K16) DVD RW Dual Layer Burner
HP dvd740i DVD+- 16X Double-Layer LightScribe Drive
Your response quoted the "WRONG PROBLEM" that I had asked assistance
to fix
Jul 05, 2008 | HP Pavillion ZV6000 Athlon 64 3500+ 15.4in...
Computers & Internet Logo
54 people viewed this question
David Payne
David Payne
