Question about Brother MFC 210C All-In-One InkJet Printer
No power on
My printer model is mfc-210c this is power on no indicate in lcd screensome light sound in speaker of tak tak...., that,s type. i will power suplay cahnge but may be same sound . the first one power supplay to connect to the other printe that printer is working . this printer is not working plase tell any suggestion.
thanq.
  • 832 Answers
No chance. The main circuit board is defective and needs replacement. the spare part costs as much as a new mfc!
Posted on Mar 28, 2008
What can i do i have the mfc-210c--mfc-420cn brother
Go to www.brother.com
Under Printers Soultions select printers.
In the search bar type your model number.
Here you can select Support and type of operating System. Click on view Brother solutions Center for MFC-210C, Click on downloads, click on drivers etc.. you will find the drivers for your peticular Operating system. Download full utilites and drivers.
Thanks
Sep 27, 2009 | Office Equipment & Supplies
Brother MFC 210 stops working at start (power supply problem?)
my mfc 210c printer power supply are blast please where to buy power supply circuit
Apr 26, 2009 | Brother MFC 210C All-In-One InkJet Printer
MFC does not recognise the new black ink cartridge.
Disconnect power supply and USB lead (leave disconnected for 10 min). Repeat this for each colour that is not working and hey presto the LCD readout will revert to normal and you will be able to print again. Happy Christmas! Hope this works for you (worked for me)
Dec 18, 2008 | Brother MFC 210C All-In-One InkJet Printer
Unable to clean?
Heres the mauel for the MFC-210C printer.
http://www.brother-usa.com/manuals/default.aspx?PRODUCTID=MFC210C&ProductGroupID=5
You can clean the outside of the printer and the paper handling mechanisms with a mild cleaning solution and a lint free cloth. To clean the insdie of the printer, use a HEPA vacuem and follow the manuels recommendations.
Nov 10, 2008 | Brother MFC 210C All-In-One InkJet Printer
LCD problem
unplug from power outlet. wait 2 minutes. plug to power again. should work. If not there is a defective main circuit board which has to be replaced (costs more than a new mfc at sale!)
Jan 14, 2008 | Brother MFC 210C All-In-One InkJet Printer
Machine error 36
There are several reasons for that:
check travel path of the print head. Any obstacles there?
Does the purge station work well?
Is your power outlet fit enough, or did you had some lighting strikes the days before? It could be another indicator for a weak power supply (ac or dc!)
Nov 27, 2007 | Brother MFC 210C All-In-One InkJet Printer
Printer won't power on
Do any power indicators come on? If not, then check all power connections- if all is OK here, you might have a power supply problem, which, on most printers is internal to the printer. Repair would require tech savvy. If you do have a lit power indicator, and no activity otherwise, such likely indicates an error condition. If indeed printer has set unused for a substantial period of time, ink might've dried inside the printhead(s, as it sounds like this uses separate ink tanks/printhead(s). What repair might be possible beyond this, I don't know.
Apr 25, 2007 | Brother MFC 210C All-In-One InkJet Printer
Brother MFC-210C Firmware Problem
I would try re-running the firmware installation if you haven't. Last time I had a firmware problem like this I left the machine unplugged for a hour or two came back and re-tried it and the machine took the upgrade fine the second time.
Oct 24, 2006 | Brother MFC 210C All-In-One InkJet Printer
Brother MFC 210C All-In-One InkJet Printer Logo
52 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Jim Keysor
