Question about Dell E228WFP LCD Monitor
The monitor keep going to black when its still on.
    President:
  • 1,561 Answers
It is the picture picture board on your monitor that is malfunctioning, since the power led or button is on, but black screen, it means the picture board of your monitor has developed fault.
The best thing for you to do now is to take the monitor to a local repairer within your vicinity or any service center to help with the replacement of the picture board because the fault is not something you can fix yourself, in order not to complicate issues.
Take care.
Posted on May 10, 2010
My dell monitor will only turn on for a few seconds then it goes black. it doesnt turn of it just goes black and I can keep doing it and it will keep going black.
The picture board on your monitor is bad, since it goes off after few seconds and the power led or button is on, it means the picture board of your monitor has developed fault.
The best thing for you to do now is to take the monitor to a local repairer within your vicinity to help with the replacement of the picture board because the fault is not something you can fix yourself, in order not to complicate issues.
Take care.
Jun 29, 2010 | Dell E193FP 19" LCD Monitor
My emprax monitor keeps going black. why is this and what can it?
You can have failed filter caps in the power supply, or failed backlight inverter, or worstcase will be the lamps, open it up and inspect the caps first and report back what you find so we can guide you further, see example of failed monitors: http://s807.photobucket.com/home/budm/allalbums
Jan 24, 2010 | Emprex LM1704 17" Monitor
Screen keeps going black
check your numlock key presss it then check numlock led if it on /off then your computer gives dispaly to monitor perfact then when you power up ther computer press F8 key then enter in enable vga mode if you see safe mode and other mennu.
But if you can't able to see those menu then you have to check your monitor to cpu vga cable connection.
Also check your monitor is properly working? or not.
Aug 13, 2009 | Acer X193W LCD Monitor
Monitor keep going to black screen while viewing.
Disable the Screen Saver in the Display Properties from Control Panel of your Computer.
A Black ScreenSaver is active in your Display Settings. Change it to "NONE" and your problem will be solved.
Apr 22, 2009 | Daewoo L700C 17" Flat Panel LCD Monitor
Check video cable keeps reading and go off, but the power is still on
the screen on most monitors will go black if the cable connecting them to a device is lose or disconnected altogether. try the cables in the back the ones other then power cable
Apr 15, 2009 | Neovo F 415 (Black) 15" LCD Monitor
Starlogic 20 inch widescreen monitor screen keeps going black
This is probably a back light problem. Take a bright flashlight and while the monitor is on, point it at the LCD and try different angles, etc. If you can see an image, it is the back light, probably the back light voltage converter unit in the lcd. It could also be the back light bulbs.
If you don't see an image with the flash light, then it could be the main logic board.
ort11
Mar 08, 2009 | Computers & Internet
bad capacitors you will need to replace the "blown caps" and resolder new ones in.
Feb 01, 2009 | Star Logic 17" LCD Monitor
Monitor keeps going off.
try while it''s on to press the menu button and in the top right is the model number.
Jan 20, 2008 | Dell E173FP 17" LCD Monitor
Monitor problem
This monitor is bad replacement is the only option as the CRT monitors are obselete you could get a good deal on one if you are not shopping for a flat panel!
Oct 24, 2007 | Samsung 793S 17" CRT Monitor
Dell E228WFP LCD Monitor Logo
370 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
