Question about Motorola Mobility SLVR L7 Cellular Phone
Picture messaging My Moro SLVR won't let me send picture messages. I even set the picture resolution to the smallest res for messaging. It tries to send them, then just says it is unable to send the message. I don't know what I am doing wrong!
It has to allow I suppose. May be the picture size is greater than 3 SMS sizes.
Posted on Mar 29, 2008
Message
Reduce the screen resolution to 600x480 for instance and see if the projector can handle the low res output OK. Then increase screen resolution on the PC unitl the error message appears. Try the video menu settings in the acer
Jul 17, 2010 | Acer X1230 DLP Projector
Hi I've got a Samsung TFT monitor -Syncmaster 710V - that gives an error message.Message reads: Not optimum mode Recommended Mode: 1280 x 1024 60Hz This screen is impossible to get rid of. Anyone know the...
Try to change the desktop display settings, see screenshots below, see if it works
Right click on your destop and go to properties > settings
  1. Set your Screen resolution to 1280X1024
  2. Then click advanced and go to Monitor and set the refresh rate to 60 Hertz.
Dec 06, 2009 | Samsung 710V 17" LCD Monitor
Dynex 19 LCD
I went over the specs of the TV.
The max input for the VGA is 1360x768 at 60Hz. Anything higher will make the TV go bonkers.
I would try to get the resolution at 1360x768, then change the frequency to 60Hz.
May 29, 2009 | Dynex 32 in. LCD Flat-Panel HDTV
Can't sent photo message
If you want to send a picture message, then you have to make sure that the resolution of the image is 320x240 or lower. This is the usual limit on most phones. If it works then you can try a higher resolution like 480x320.
Hope that helps,
Sai.
Apr 09, 2009 | LG Shine KE970 Cellular Phone
How to send picture msg
Here's how send a picture in a message.
1. Press the Center Select Key
2. Press the Navigation Key to scroll to Messaging, and press the Center Select Key
3. Press the Navigation Key and scroll down to Create Message, and press the Center Select Key
4. Press the Navigation Key and scroll down to New MMS Message, and press the Center Select Key
5. Press the keypad to enter desired text
6. Press Options, by pressing the left soft key
7. Highlight Insert, and press the Center Select Key
8. Highlight Picture, and press the Center Select Key
9. Press the Navigation Key and scroll up or down to the desired picture
10. Press Insert, by pressing the left soft key
11. Press Send To, by pressing the right soft key
12. Press the Navigation Key, and scroll down to desired contact, and Press the Center Select Key
13. Press Send, by pressing the right soft key
You can find this, and other helpful stuff at
this page on the Motorola Support site
Don't forget to rate this solution once you've tried it !
Apr 17, 2008 | Motorola Mobility SLVR L7 Cellular Phone
Picture messanging
oops forgot to login :)
i contacted support with this same problem...i get the triangle with a ! in it.
they said the receiver is sending a resolution that isn't supported by the album. although you can still set the picture to a contact in your address book1.gif, go back to the text message4.gif and view it, or even us the file browser that you downloaded to view it. it just doesn't show up in the album correctly.
they didn't offer any fix to the issue.
Feb 12, 2008 | Helio Ocean Cellular Phone
Can't send/recieve picture messages with motorizr z3
make sure picture messaging is set up through your service provider.
Feb 09, 2008 | Motorola Mobility MOTORIZR Z3 Cellular...
Mortorola slvrl7
The only time that happened with mine was when the internal memory was almost full. Try moving some stuff to the memory card. those phones only have about 5MB of internal.
If that doesnt work then your phone is not unlocked for internet and mms use. You could be paying for the service and your phone isn't set up for it. Only your carrier can activate it unless you know how to hack it.
Or, you could be just outside the GSM data coverage area.
Dec 23, 2007 | Motorola Mobility SLVR L7 Cellular Phone
"Not Supported Mode" Message...
Your tv does NOT support any higher than 720p res.
Is your cable box set to this? If not, and it is set to 1080i than it would explain this, and is also a common problem with computer(vga) connections even with monitors. To see the current resolution the box is set to hook up a yellow jack to the to from cable box just to get the picture back long enough to navigate to a setup menu and lower the resolution back to the highest supported which is 720p
Nov 04, 2007 | Samsung LN-S3241D 32 in.LCD HDTV
Motorola Mobility SLVR L7 Cellular Phone Logo
Top Motorola Mobility Cell Phones Experts
Virgil Wolter
Level 1 Expert
vince
Rami Obeid
Level 1 Expert
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
