Question about JVC AV-48WP30 48" Rear Projection Television
Jvc rear projector
Color not good
Explain in a little more detail.
Posted on May 11, 2008
JVC TV with color problems ??
There are two color systems PAL and NTSC make sure the Projector is set to the matching System with what you are wanting to project ie the source signal. .
Apr 14, 2015 | JVC Televison & Video
Jvc x3 projector orange lamp light flashes wont power up
1,Check the fans ,if the fan is running
2,Inductor (Sensing element),near the Color Wheel. Use a cotton swab moistened with alcohol to wipe the Inductor.
Have a good day!
We supply original projector parts: lamp, bulb, Lcd, Lens, DMD,
motherboard, powersupply ... with high quality and competitive price.
Jerry China
Tel: +86 131788 67858
E-mail: lampdeng@hotmail.com
Skype: lampdeng.com
YM: lampdeng@yahoo.com
http://facebook.com/lampdeng
http://www.lampdeng.com
Nov 02, 2013 | JVC Dla X3 3d Projector
Color wheel replacement
good times here--take the front and rear bezels off and remove the top cover. remove the power input board and power supply. next remove the metal shield covering the bottom of the projector to expose the main board. next, cut the ribbbon cable as close as you can to the color wheel. remove the color wheel leaving the cut ribbon behind. Now, carefully set the new color wheel in the general area and tape the new cable to the cut cable. Next pull the cut cable out of the main board paying careful attention to which way the cable was plugged in. Now pull the new cable thru and remove the tape and the old cable, plug it in, install the new colorwheel and put your projector back together with the exception of the front and rear, turn it on and make sure the color wheel spins, if it kind of just jumps, it means you plugged the cable in backwards. also when you test to see if it works, make sure the lamp door is shut so the safety switch is pushed in, otherwise the projector won't light.
Apr 01, 2010 | InFocus ScreenPlay 4805 Multimedia...
JVC AV-56WP74 Colors quit working or went out of balance.
Guns or CRT are probably ok. Your TV needs a convergence IC STK392-120 replacement. Lamp are used on LCD and DLP rear projection TV's. Color wheel are for DLP's. :)
Dec 26, 2009 | JVC Televison & Video
How to wire car speaker to JVC CD Receiver.
Hello anstrayer,
On your JVC wiring harness the speaker wire colors are:
Left front (+) - White
Left front (-) - White/Black
Right front (+) - Gray
Right front (-) - Gray/Black
Left rear (+) - Green
Left rear (-) - Green/Black
Right rear (+) - Purple
Right rear (-) - Purple/Black
You can download a the manual from Crutchfield. A complete wiring diagram with color codes is on page 41.
Hope this helps.
May 31, 2009 | JVC Car Audio & Video
Replacement Screen for 65 " Sony Color Rear Video Projector
Try HERE to get replacement screen for your TV.
Good Luck.
Sep 26, 2008 | JVC AV-48WP30 48" Rear Projection...
Tv set 48 inches projector..[jvc]
replace 2 X convergence ICs and align. Maybe burnt resistors as well.
easyab@hotmail.com
Calgary
http://calgaryconvergencerepair.weebly.com/convergence-repair-explanation.html
Jun 16, 2008 | JVC AV-48WP30 48" Rear Projection...
JVC HDTV Pictrure Distortion
Your TV needs to be calibrated. Rear projection TVs are very sensitive to movement. They have 3 color canons that need to be precisely aligned so that the colors overlay each other. They are like three projectors all aimed at the same screen.
If you were to enter the User Menu on the TV, you should find an alignment/calibration choice that will re-align the colors using some on-screen help.
If you are not able to resolve the situation on your own, a certified ISF Calibrationist should be called.
And, since you've bought this TV used, it should be cleaned by a professional (the canons, lenses, etc.)
Apr 07, 2008 | JVC PD-42WX84 42 in. HD-Ready Plasma...
JVC 48WP74 HDTC rear projection
While it is true JVC tubes rarely fail, they can give trouble.
Another possible solution is bad screen / focus block......
Remove lower front grill panel and access board...Check for
smooth adjustment of RGB screen and focus.....let me know....T..
Sep 28, 2007 | JVC AV-48WP74 48" Rear Projection...
JVC AV-48WP30 48" Rear Projection Television Logo
55 people viewed this question
Top JVC Televison & Video Experts
Jaime Hernandez
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
