Question about Craftsman 25cc Gas Line Trimmer
How do i get the spring back into the recoil - Craftsman 25cc Gas Line Trimmer
  • Ed Gore May 11, 2010
    Which one?
    Have no idea what you are talking about? Too vague dude! That is like me asking you, "how do I put the screw back to the winder?" Now, from just that alone...do you know what I am talking about? Not being a wise guy but we need to be able to picture whats on your mind. It makes sense to you because its your experience, but to anyone here...big ?
I think he's trying to replace the recoil starter spring. He's having trouble getting the spring and pully and rope back into the housing. I'm trying to do the same thing with an old Green Machine weedeater and would appreciate any help.
Posted on May 27, 2010
  • Paul Schneider
    Paul Schneider May 29, 2010
    Thanks for the detailed response. On my Green Machine there are no screws holding the spring or pully in place. The spring just lays flat in the housing, the pulley engages the spring and the whole contraption is held onto the weedeater by three screws. This is an old weedeater that I inherited and I'm wondering if it's missing some parts. I can't get the spring to lay down in the starter housing with out it losing tension and coming apart. The new spring came in a wire retainer under tension, but when I put it in the housing and remove the retainer it unwinds and goes all over the place. Any help would be appreciated.
    Sniper:
  • 53 Answers
Well, The problem with a lot of those rewind coil issues, for me anyway, usually stems from the fact that I don't have 3 or even sometimes 4 hands! Some of those have to be placed into position under "full tension" in the spring or 2 problems arise. 1) The rope won't recoil "the full length" back in. or 2) it will recoil back in, but with far too much energy (Wound too tight). So the real trick is to "tweak" the rewind in such a way that it takes all the line back, in a normal feel. With any of those recoil systems its always best to have "full access" to the spring(s). Some have coiled up, flat, blue steel, bands. Usually encased, and the start string winds around that encased spring/band and creates "more tension" when you pull. Very much like a tape measure works. When these types of recoilers fail its usually due to 2 things. One end of the band is usually anchored at the center inside of the enclosed pulley. This "anchor" has broken or let go due to "wear" or friction. It simply "breaks" instead of holding. And other designs use regular springs, but rely on more complication to work. (more parts) And to worsen it further, each mfgr. has its own unique designs! (Take that consumer!) But I'll assume you have the flat band wound type. Copied from the "ASK ME" Help desk:
You will have to separate the fan housing/shroud (WeedEater's term from their parts manual) and remove the pulley. It will require a 5/32" Allen wrench to remove the four screws. There will be another shorter screw holding a metal plate shaped like an elongated "D" at one of the bottom corners that holds the pulley in. There will be a small screw with a washer attached in the pulley that will probably have the small remaining piece of the original rope. Remove it and the and the small piece of rope. The part number for it is 530069232, but going to a power equipment dealer and requesting 3 ft. of high quality rope of size 3.5 will suffice. High quality rope will have a braided exterior and three inner core strands. With the new rope insert it; if you bought bulk, make sure the ends are burned to prevent unravelling. There will be a cuved groove that the rope fits in and is bound by the small screw/washer. Do NOT overtighten and strip. Wind the rope in a counter-clockwise direction on pulley as referenced by the side that you would see if mounted in housing. Put through eyelet in housing, into starter grip and secure with a knot. Slip the pulley into replace after winding up slack and pretension. To pretension You must wind the pulley two turns counter-clockwise to remove the slack and make the rope fully rewind when used. There could be a single notch in the pulley to facilltate this , or a number of scallops around the pulley. Holding the pulley loosely in place with a finger, take a pair of needle nose pliers and ease the rope toward you in a loop long enough to make the revolutions. Care must be taken to keep the pulley seated on the spring during this to achieve the pretensioning. Once done replace the screw and plate to hold the pulley in place. Seat the housing to the engine, a small, short pull of the rope may be necessary to get the starter pawls into position. Holding It in place, test it by pulling it slowly through to see if all works correctly. Then and only then do you reinstall the four screws that hold it together.
That does it and, if all other things are functioning properly, the machine should be startable. A note: there is no reason in the world to pull the rope to full extension, ie all the way out until it stops; that breaks starters! You only need 12 to 18" of the 3 ft. of rope to start a working machine.
Peace,
Clarke
PS. I could have repaired three of these machines in the time it took me to write this answer.
Posted on May 29, 2010
Why won't mypull string recoil
when it broke it may have unwound. the spring has to be wound up before it will recoil. you tube has many videos to show you how to rewind the spring. be careful as when wound up it has pressure on it. also be sure to back it off one turn past the string hole so if you pull all the way out it will not break the spring.
Jan 30, 2016 | Garden
How do I put a spring back into a mountfield sp544
sp544??? is it a 534 or 454 possibly? either way i think they have mountfield rv engine,you will need to remove the recoil housing assembly,remove the rope pulley (think the centre pulley screw is left hand thread) then if the recoil spring is undamaged you can wind the recoil spring back into the recoil housing
Mar 10, 2015 | Garden
How to replace spring on recoil starter
If you are talking about replacing the recoil spring inside the top cover of the motor, it is best to replace the entire top cover. The covers are relatively cheap and once those springs pop out they are difficult to get back in. Even if you do manage to get the spring back in, it is likely to pop out again since damage or wear is usually what makes it pop out in the first place. If you are bent on getting that spring back in, take a look at this video on YouTube: How to Repair Small Engine Recoil Starter
Jan 08, 2015 | Garden
The starter cord jammed on recoiling, after attempting got release it the recoil spring rewound, now the cord and spring are interlocked. I'm looking to strip the recoil mechanism but I believe I
Its an easy opperation to undertake if you know how. Take note of where everything goes during the stripping down of the recoil assembly. Use eye protection when trying to recoil the rewind spring, they have a tendency to jump back out at you while coiling them back in. easiest way is to start by putting the hooked end into the plastic housing and work your way inwards coiling it back in. Then place the starter cord roller in on top, adding the one or two black sliders, the washer and the spring clip to hold it all in place.
Feb 16, 2013 | Stihl Trimmer Oe Rewind Starter Spring 36...
Fs44 whipper snipper recoil spring unwound, cord jammed and when tried to release recoil spring released
http://rapidlibrary.com/source.php?file=ulztcbvqczi89on&url=http%3A%2F%2Fwebweevil.co.uk%2FPublic%2FInfo%2FStihl%2520FS36%252C%2520FS40%252C%2520FS44%2520parts%2520list.pdf&sec=a0a080fc8669d51a
The link is for the breakdown manual and parts list
Snow blower recoil rope broke tied back up and now will not recoil
Unless the recoil spring is broken, then you may have neglected to pre-load the recoil spring. With the recoil unit off of the motor, wind the rope fully around the pulley. Then, while keeping the rope fully wound, turn the pulley about 5 times around in the direction that would push the hope out through the hole. At this point the recoil spring will be trying to spin. Without losing that tension, push the end of the rope out through the hole, thereby putting a bit more tension on the recoil spring. Tie on the handle. Now, when you let go of the rope, the spring should hold the handle snug against the hole. An alternative method is to use a rope about 2 to 3 feet longer than the original. Wind it fully around the spool and put the end of it through the hole. Now pull the extra length through the hole until the tension is sufficient. Cut off the extra length and tie on the handle.
good luck, Al K
Jan 11, 2011 | Tecumseh Horizontal Tiller Engine 8 Hp, 1"...
Repair of pull start to garden blower
To replace the pull cord line:
If your pull cord is still attached to the grab handle, it's likely your spring is still wound. Follow this if this is the case, purchase rope of the correct length (or cut) and the correct diameter at your local lawn/garden store, then:
1. Disconnect the long drive shaft by removing the small set screw and the clamp - pull the shaft out of the engine body.
2. Remove the recoil assembly (About 5-5 torx bolts). You may need to disconnect a wire to the kill-switch at this time.
3. Pull the cord until it stops and use a small piece of wood acting as a wedge to jam between the recoil and the housing.
4. Cut the line and pull the knotted terminating end from the hosing.
5. Keep the wedge tight so it does not spin back. If this happens, you will simply need to rewind the spring back (about five turns) and re-wedge it.
6. Feed line through the recoil housing and into the recoil. Pass line through the hole in the recoil and knot the end. Trip to about .25 inch tail. Pull the rope through the grab handle and single or double knot this.
7. Remove the wedge and allow the spring to pull the rope back into the recoil.
8. If it does not completely recoil, either your rope is too long or you will need to add a "wind" to your spring buy removing the line and wind back 1 more turn. Retry.
Sep 25, 2010 | Garden
How to put together a toro recoil
first you put the rope into place then place the spring in the center lock ,if its out then you tighten up the spring by turning it in the direction that will pull rope back in once at the end of recoil send rope into pull hole, hold it tight and let it coil up slowly,reattach to machine and your done.
Jan 14, 2010 | 2005 Suzuki RM-Z 450
Craftsman 25cc Gas Line Trimmer Logo
758 people viewed this question
Top Craftsman Garden Experts
Dean Gruber
Roland W VanLue
Roland W VanLue
Dennis Key
Dennis Key
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
