Question about Western Digital Caviar WD800BB 80 GB Hard Drive
The hdd does spin but is not detected
The hdd is 80gb wd800 type it does spin but is not detected by my pc and it sometimes produce clicking sound
    President:
  • 2,022 Answers
It is phyisically damage and will not work it is bettre just replace the hard dirve.
Hope this helps. Please rate my response.
Thanks.
Have a good day.
Posted on May 10, 2010
2 Suggested Answers
kozachek
  • 122 Answers
SOURCE: the hdd does spin but is not detected
A clicking noise from a hard drive typically indicates that the drive is about to fail or has failed completely. If the drive is still under warranty, contact Western Digital for a replacement drive. If not, you will need to purchase a new hard drive. There are services to recover some of the data off of a failed hard drive, but the rates can be quite high.
Posted on Mar 16, 2010
Testimonial: "thank you for your help and I liked your response, it was quick"
Laptop can not boot,noisy hdd
Hello, welcome to Fixya!
It is obvious that the hdd of your laptop is defective. The HDD has some bad sectors which is most likely beyond repairs.
You need to replace the HDD of your laptop because the noise you are hearing is an indication that the HDD is defective.
I hope the above information is clear. If not clear, please let me know.
Regards.
Nov 16, 2011 | Computers & Internet
I have a 250gb seagate sata but when i put my 80gb IDE hdd it only detects in booting and in bios but after that if i open my computer i cant see my 80gb IDE Hdd and even in device manager my hard disk was...
there was wrong in the set up of jumper in your 80gb hdd. Look closely to the 80gb harddrive, in between the ide cable terminal and the power supply connector you will see 8pin terminals paired together and a jumper use to short the paired terminals. It is most likely that the jumper was configure to detect your hdd as master. If the ide cable you use for the 80gb hdd was also use for the dvd/cdrom drive then it will conflict with it if both jumper setting was set to master. See the description of jumper settings in the sticker of the hdd. Position the jumper to slave.
Reboot your system again and see if the 80gb finally appear in your system. When system boot upon detection of hdd, the primary master should be 250gb while your primary/secondary slave will be read your 80gb hard disk.
Jan 24, 2011 | Seagate 80GB 7200 rpm SATA/150 8MB Serial...
My WD800 external drive sounds like it is not "spinning up" and I hear a constant clicking sound coming from the drive. Is it "toast"?
The drive is toast, that is a common sound from a western digital drive when the heads are banging against the platters.
Nov 11, 2010 | Western Digital External USB 2.0 80 GB...
I am connecting my 40gb PATA HDD, but my PC doesn't start. There is no problem when i connect my 80gb PATA HDD in same PC. My 40gb HDD had detected once but it gave symbol S@ in the BIOS setup. Can U...
You did not indicate that the 40 Gb hard drive had Windows installed on it and whether it was the original hard disk for this computer.
There is a possibility the 40Gb hard drive is faulty.
Try installing the 40Gb hard drive as a slave drive with the 80Gb drive as the master drive (don't forget to set the jumper on the 40Gb hard drive as Slave. Check the BIOS to see if it detects the 40Gb hard drive, and when the computer boots up, if it can see the 40Gb hard drive and opens the various folders and files, then the hard drive is OK.
Sep 19, 2010 | Computers & Internet
Hard drive does not operate
1, switch off computer
2. remove side (usually two screws on the back held it)
3. remove and then re-insert power cable from hdd
4. remove and re-insert data cable, from hdd as well as from m/b
5. start computer and hold your fingers on the top of the affected hdd, if you feel vibrations, this meant that driver is spinning and therefore rescue can be attempted at home.
6. research and purchase hdd recovery software, follow it's instruction and save data on another medium, be it another hdd or cd's dvd's.
if there is no spin, recovery is still possible but in specialist lab and will cost more money....
always back-up your data, second hdd is much cheaper than data recovery from existing one...
Jul 27, 2010 | Maxtor Hard Drive
Mar 16, 2010 | Western Digital Caviar WD800BB 80 GB Hard...
DIY solution for data recovery on a failing Hitachi HDD
Yes it is possible to data recover from this hard disk to using "active partetion recover v2.0 or above" software. This software should be registered and also bootable disk. It will be possible to data recover, if it will be detect in dos mode.
Procedure:
Insert the bootable disk into CD-Rom and choose boot from the cd rom and now check your disk is detected or not, if detected follow the instruction and your all data could be recover with your complete partions.
Good Luck
Dec 14, 2009 | Hitachi Deskstar 7K80 Hard Disk 80GB,...
No HDD Detected
You may need a Boot Fix. You may opt to chat with a technician on FixYa, because there are many steps you may take.
Apr 16, 2009 | Dell Inspiron 1300 Notebook
Sata hdd not detected in bios
Tried a differant SATA power inout into it? Is it making a clicking sound?
Feb 18, 2009 | Samsung SpinPoint T HD501LJ 500 GB SATA...
Western Digital Caviar WD800BB 80 GB Hard Drive Logo
365 people viewed this question
Top Western Digital Computers & Internet Experts
Arora Singh
Arora Singh
Alun Cox
Are you a Western Digital Computer and Internet Expert? Answer questions, earn points and help others
