Question about D-Link Wireless
CAN YOU HELP PLEASE?
have a router D-link WIRELESS DIR-655 and a COMCAST MOTOROLA S85101 Surfboard cable Modem hooked up to my computer I need your help desperatley I have tried everything.. HERE IS WHAT I NEED----------- I need to be able to connect to the following Server "OUKA CHAT SERVER --------http://www.webfrik.com/Oukahelp/ I have tried everything but cannot get the portas to open up..something is blocking them...and it is not the firewall cause I turned that off to find out...and ppl still cannot enter the Chat Room. please help I have tried it all and cannot find a solution..I must tell you that I do not know awhole lot about computers and configurations and that sort of thing. So tell me is there a service that you provide where you can set me up so this will work? Can you access contrtol of my computer perhaps? Thank you in advance for your help.. Martha
Hey Martha, I believe your problem is with your windows firewall, I just recently had a similar problem, I install Ouka on my pc, which i just re installed windows on, anyway, it worked great when i first started it to test it, then when i restarted pc it would not connect. The problem was my windows firewall(btw I run mcafee as my primary firewall), even though the ports were set and Ouka was allowed.. To correct the problem, first i deleted Ouka from my windows firewall, then i deleted the ouka program from my pc, turned off mcafee firewall, turned on windows firewall, re downloaded the ouka file and when i started the program again, windows firewall asked if i should block or unblock ouka, I unblocked it, set up the port. then i turned off my windows firewall, turned on my mcafee firewall and Ouka is working great ever since, even after restarts. Hope this helps, if not check out winmxworld.com forum I have posted there my problems/solutions for Ouka. Good Luck, Lisadee
Posted on Aug 19, 2008
  • 8,617 Answers
Sorry that isnt my area of expertise. I am mainly Television and appliances. I would try one of the other experts that specialize in computers. they will be able to help you out.
Posted on Mar 28, 2008
3 Suggested Answers
SOURCE:
IB4G2008
  • 3587 Answers
SOURCE: HELP WITH MY ROUTER
sure..send me a email to [email protected] and we'll get you right as reign..
aborcass
  • 2651 Answers
SOURCE: HELPPPPPPPP
sorry my expertise is in appliance repair, please repost with another tech
Posted on Mar 30, 2008
Globe symbol won't turn green.
I was banging my head for 2 days with about 35 different configurations and finally tried the following and it worked just fine. Also, tried connecting 3 computers and they all connected with "NO" issues. Even connected wireless with "NO" issues. Now I am at 20mb download speed...J compared to AT&T 1.5mb download speed.
This is my DLINK model -> (DIR-601 Wireless N 150 Home Router Wireless router)
1. Reset your Comcast Surfboard Cable Modem by unplugging it for 5 minutes.
2. Then reset your DLINK Router to the manufactures default settings. Then Unplug DLINK Router for 1 minute then plug it back in (Just plug your cat5 cable into port 1 and connect it to your computer) there should not be anything else plugged into the DLINK Router at the time you make the changes. Just 1 computer can be connected.
3. Went into the DLINK configuration 192.168.0.1 and changed the PPPOE setting that I was using for my AT&T Modem to Dynamic IP (DHCP). Once you make the changes save them and then unplug your DLINK Router it's off.
4. Turn on Comcast Surfboard Cable Modem and wait until all lights are on. Now plug in a cat5 cable from the Surfboard Comcast modem (NOT A CROSSOVER CABLE LIKE THE CD INDICATES) to the INTERNET port of your DLINK Router. Now turn on your DLINK router.
5. Then turn on your computers or restart them and it will pick up IP Addresses from your DLINK Router
Jun 08, 2010 | D-Link Wireless N 150 Home Router 4Port...
My DIR-655 won't work!
It would be helpful if you could be a bit more specific regarding the way you hooked up the dir 655 to your network and your specifc DSL modem. If the modem you are using is the Actiontec M1000 DSL modem you will not be able to obtain internet access because the DIR 655 is trying to route an already routed IP, the M1000 has a built in router / DHCP that by default is enabled. You can use option 1, access the configuration settings of your M1000 and change the WAN configuration to act as a transparent bridge. After doing so and rebooting the modem you will have to enter your DSL login information like a PPPoE username and password for example into your DIR 655 network settings. With this configuration the modem simply acts as a bridge to relay data directly to the DIR 655 and the 655 itself provides login credentials to obtain internet from your DSL provider as well as hand out IP addresses to the local network. Option 2 is to continue to use the M1000 as a router by default and disable DHCP on your DIR 655 so that it essentially acts as nothing more than a switch or wireless access point while the M1000 hands out local IP addresses. I personally would recommend using the DIR 655 to route IP's as it's got far more configuration utilities than the M1000 does as a router, and really what's the point of getting the 655 if you're only going to use it as a switch or access point when there are other simpler and cheaper devices that could do that for you.
Jul 20, 2009 | D-Link Xtreme N DIR-655 Wireless Router
Computer will not connect to internet through router
check the connections between the router and the modem either cable or dsl or whichever
and change the setting in the router interface so you know what the ssid is being broadcasted and the network key
If you need further help, reach me via phone at https://www.6ya.com/expert/david_eb7ea98642566cc6
Jul 18, 2009 | D-Link Xtreme N DIR-655 Wireless Router
Connect Laptop to PC desktop which has cable connection.
YOU WILL NEED TO GET A WIRELESS ROUTER TO BE ABLE TO USE THE LAPTOP WIRELESS, iT IS A VERY EASY SET UP AND CONNECT THE DESKTOP WIRED AND THE LAPTOP WIRELESS TO A WIRELESS ROUTER.
May 06, 2009 | Arris SURFboard SB5120 Modem
I have an issue with my Dlink DIR-625 wireless and cable modem
it isn't syncing up with your modem, try a hard reboot, disconect everything, even the cable, after 5 minutes , first screw the coax cable back to the modem, that will re establish the cable connection, plug everything back in, and if that pc light still is still doesn't work, the router may be bad, look on the Dlink site and download the latest firmware, as a last resort, but also reset the router first before trying anything, there is a reset button on the router. Sometimes certain routers don't work with certain modems, if you try the reset, then the hard reboot, and the firmware, you have covered all the bases
Mar 30, 2009 | D-Link DIR-625 (790069292637) Wireless...
Wireless router stops internet connection to modem during install
are you sure your hooking the comcast modem in the right place?
Feb 08, 2009 | Arris SURFboard SB5120 Modem
Setup DIR-655 w/ Westell 6100 USB DSL Modem
First check if your computer can get on the modem with an Ethernet ( This is to find out if your router will work with your modem) If you cannot get on give your ISP a call to have them configure the modem for Ethernet connection. If you do get on then connect the router to the modem and your computer to the router. You can run the CD for the router or do the connection manually.
Jul 27, 2008 | D-Link Xtreme N DIR-655 Wireless Router
Helpppppp
Hi, sorry I only do vaccuums, not computers.
Mar 28, 2008 | D-Link Wireless
HELPPPPPPPP
HELP WITH MY ROUTER
Open Questions:
-\&;-COMCAST Customer Care Phone Number #{+ I8OO-828-O294 } AB .U.S.A This Comcast USA phone number is ranked #2 out of 2 because 7,728 Comcast USA customers tried our tools and information and gave us feedback after they called. The reason customers call # I:8OO:,:828O294 is to reach the Comcast USA Customer Care department for problems like Where to buy, Complaint, Customer care, Repairs, Returns. As far as we can tell, Comcast USA has call center locations in New Mexico and you can call during their open hours Mon-Fri 9am-8pm EST. Comcast USA has 2 phone numbers and 4 different ways to get customer help. We've compiled information about I8OO8O30294 and ways to call or contact Comcast USA with help from customers like yourself. Please help us continue to grow and improve this information and these tools by sharing with people you know who might find it useful. Calling Comcast USA Calling Comcast USA at this number should be pretty straightforward. Also important is what you do once you call, or what your other phone number options are. First of all, we strongly recommend using our free call-you-back tool. Essentially, we navigate their phone menu for you, wait on hold, and then call you when a representative from Comcast USA Customer Care can talk. Generally, it saves you at least 27% of your wait time. So it's faster and you don't need to listen to bad hold music. Once on the phone with Comcast USA's Customer Care department, you may need to provide them with information that identifies you as a customer, like your full name or name on the account, email address, phone number, or an account number. It's usually worthwhile to gather this information before you call. Click here if you want to compare Comcast USA's phone numbers against each other. Contacting Comcast USA in General While I8OO8280294 is Comcast USA's #2 most popular phone number, it's not the only way to get a hold of their customer care team. You already know from reading above that I8OO8280294 is their best customer phone number overall, and we have put together a comparison of their 4 total ways to contact care for you to look at as well. One thing to keep in mind as you try to reach Comcast USA help by calling them, is that other customers give their customer care at this number a 84% score for their communication skills and a 94% score for the overall help they received. That could be indicative of their abilities to help you resolve your problem overall, regardless of whether or not you call this number. Click here to see a comparison of all the phone numbers, social media and other avenues to contact Comcast USA.
Oct 16, 2019 | Best Computers & Internet
Amazon Best pHoNe NUmber #{+1-85O-8I2-4OO9 how to get refund from amazon prime Amazon Prime Refund Phone Number +1-85O-8I2-4OO9. While +1-85O-8I2-4OO9 is Amazon's best toll-free number, there are 7 total ways to get in touch with them. The next best way to talk to their customer support team, according to other Amazon customers, is by telling about your issue above and letting us find somebody to help you. Besides calling, the next favorite option for customers looking for help for Customer Service. If you think this information is inaccurate or know of other ways to contact Amazon please let us know so we can share with other customers. And you can click here if you want to compare all the contact information we've gathered for Amazon. AMAZON PRIME Tech Support Number +1-85O-8I2-4OO9 to resolve all AMAZON PRIME products. End Your Amazon Prime Membership You can end your Prime membership by clicking the End Membership button on this page. Paid members who haven't used their benefits are eligible for a full refund of the current membership period. [1``85O`-8I2`-4OO9``] UsA Amazon Prime Technical SuPpOrT Number +1-85O-8I2-4OO9 to resolve all Amazon Prime products. Amazon Prime is an American multinational company which was founded by Michael Amazon Prime using its company headquarters in Round Rock, United States of America.Contact Amazon Prime for Setup & Installation Amazon Prime Setup Support & Installation Amazon Prime Helpline number Connect is a utility carrier that lets in you to print and scan from anywhere.
Oct 16, 2019 | Amazon Computers & Internet
-\&;-XFINITY Customer Care Phone Number #{+ I8OO-828-O294 } AB .U.S.A This Xfinity USA phone number is ranked #2 out of 2 because 7,728 Xfinity USA customers tried our tools and information and gave us feedback after they called. The reason customers call # I:8OO:,:828O294 is to reach the Xfinity USA Customer Care department for problems like Where to buy, Complaint, Customer care, Repairs, Returns. As far as we can tell, Xfinity USA has call center locations in New Mexico and you can call during their open hours Mon-Fri 9am-8pm EST. Xfinity USA has 2 phone numbers and 4 different ways to get customer help. We've compiled information about I8OO8O30294 and ways to call or contact Xfinity USA with help from customers like yourself. Please help us continue to grow and improve this information and these tools by sharing with people you know who might find it useful. Calling Xfinity USA Calling Xfinity USA at this number should be pretty straightforward. Also important is what you do once you call, or what your other phone number options are. First of all, we strongly recommend using our free call-you-back tool. Essentially, we navigate their phone menu for you, wait on hold, and then call you when a representative from Xfinity USA Customer Care can talk. Generally, it saves you at least 27% of your wait time. So it's faster and you don't need to listen to bad hold music. Once on the phone with Xfinity USA's Customer Care department, you may need to provide them with information that identifies you as a customer, like your full name or name on the account, email address, phone number, or an account number. It's usually worthwhile to gather this information before you call. Click here if you want to compare Xfinity USA's phone numbers against each other. Contacting Xfinity USA in General While I8OO8280294 is Xfinity USA's #2 most popular phone number, it's not the only way to get a hold of their customer care team. You already know from reading above that I8OO8280294 is their best customer phone number overall, and we have put together a comparison of their 4 total ways to contact care for you to look at as well. One thing to keep in mind as you try to reach Xfinity USA help by calling them, is that other customers give their customer care at this number a 84% score for their communication skills and a 94% score for the overall help they received. That could be indicative of their abilities to help you resolve your problem overall, regardless of whether or not you call this number. Click here to see a comparison of all the phone numbers, social media and other avenues to contact Xfinity USA.
See all D-Link Wireless Questions
Computers & Internet Logo
150 people viewed this question
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Ekse
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
