Heaters
Problem for Heaters
Generic problem for all Heaters
Our heater won't light
By chazza101 on Mar 28, 2008
we've recently moved into a new house and the previous owners haven't left the instruction manual. we're not sure whether it's broken or we simply aren't doing it right. when we turn the ignition knob around and then press it down we hear the clicking sound that means it's trying to ignite the pilot light but it doesn't light it. we've tried everything we can think of but nothing works. please help- it's very cold without it
Best Solution
posted on Mar 29, 2008
Helpful)
racingsmoke
Rank: Wiz
Rating: 87%, 25 votes
You may have a blockage in the pilot orifice. You may need to remove the pilot assembly and clear any obstruction in the orifice. The end of the orifice is about the size of the tip on a straight pin. Make sure you bleed the gas line if you have not used it before. There could be air in the line. Good luck.
Was this helpful?
Yes
No
Solution #2
posted on Jan 28, 2009
Not Rated)
fireoff
Rank: Apprentice
Rating: 0%, 0 votes
we have a gas vent free fireplace it will burn when we use it elecrrically but it won't light when we try manually with the electric off help please
Was this helpful?
Yes
No
Popular Solutions for Heaters
Questions and Unsolved Problems for Heaters
Answer
best heater for a 5,000 square foot monolithic dome
Answer
What is the best portable heater for a 700 sq ft area
Answer
how do I clean the "presto heat dish plus footlight" parabolic heater. There is a lot of... (More)
Answer
all pro SPC 150 has spark but will not egnite.Thank you for any help you can pass my way. I can bye... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Heaters Experts
Top Heater Repair
(888) 448-9872
Nationwide plumbers where ever you need us any...
plumbingcoop
(800) 905-9506
Traditional water heaters use a storage tank to...
Plumbing Key
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
