Question about D-Link Wireless
HELPPPPPPPP have a router D-link WIRELESS DIR-655 and a COMCAST MOTOROLA S85101 Surfboard cable Modem hooked up to my computer I need your help desperatley I have tried everything.. HERE IS WHAT I NEED----------- I need to be able to connect to the following Server "OUKA CHAT SERVER --------http://www.webfrik.com/Oukahelp/ I have tried everything but cannot get the portas to open up..something is blocking them...and it is not the firewall cause I turned that off to find out...and ppl still cannot enter the Chat Room. please help I have tried it all and cannot find a solution..I must tell you that I do not know awhole lot about computers and configurations and that sort of thing. So tell me is there a service that you provide where you can set me up so this will work? Can you access contrtol of my computer perhaps? Thank you in advance for your help.. Martha
  • Ron Coons
    Ron Coons May 11, 2010
    sorry my expertise is in appliances. please search through for another tech with computers as a specialty
    President:
  • 2,651 Answers
Sorry my expertise is in appliance repair, please repost with another tech
Posted on Mar 30, 2008
Globe symbol won't turn green.
I was banging my head for 2 days with about 35 different configurations and finally tried the following and it worked just fine. Also, tried connecting 3 computers and they all connected with "NO" issues. Even connected wireless with "NO" issues. Now I am at 20mb download speed...J compared to AT&T 1.5mb download speed.
This is my DLINK model -> (DIR-601 Wireless N 150 Home Router Wireless router)
1. Reset your Comcast Surfboard Cable Modem by unplugging it for 5 minutes.
2. Then reset your DLINK Router to the manufactures default settings. Then Unplug DLINK Router for 1 minute then plug it back in (Just plug your cat5 cable into port 1 and connect it to your computer) there should not be anything else plugged into the DLINK Router at the time you make the changes. Just 1 computer can be connected.
3. Went into the DLINK configuration 192.168.0.1 and changed the PPPOE setting that I was using for my AT&T Modem to Dynamic IP (DHCP). Once you make the changes save them and then unplug your DLINK Router it's off.
4. Turn on Comcast Surfboard Cable Modem and wait until all lights are on. Now plug in a cat5 cable from the Surfboard Comcast modem (NOT A CROSSOVER CABLE LIKE THE CD INDICATES) to the INTERNET port of your DLINK Router. Now turn on your DLINK router.
5. Then turn on your computers or restart them and it will pick up IP Addresses from your DLINK Router
Jun 08, 2010 | D-Link Wireless N 150 Home Router 4Port...
CAN NOT GET INTERNET FROM DIR-655 TO NS7000S
Are you trying to set up the router. You can do it manually without the CD. Make sure that your computer is able to go online through the modem. If your computer is not able to go online through the modem then you will need to call ISP first. If your computer is able to go online through the modem then you need to connect the computer to the router and the modem to the router. open the set up page of the router and change the settings of the router according to the ISP.
Apr 05, 2010 | D-Link Xtreme N DIR-655 Wireless Router
My DIR-655 won't work!
It would be helpful if you could be a bit more specific regarding the way you hooked up the dir 655 to your network and your specifc DSL modem. If the modem you are using is the Actiontec M1000 DSL modem you will not be able to obtain internet access because the DIR 655 is trying to route an already routed IP, the M1000 has a built in router / DHCP that by default is enabled. You can use option 1, access the configuration settings of your M1000 and change the WAN configuration to act as a transparent bridge. After doing so and rebooting the modem you will have to enter your DSL login information like a PPPoE username and password for example into your DIR 655 network settings. With this configuration the modem simply acts as a bridge to relay data directly to the DIR 655 and the 655 itself provides login credentials to obtain internet from your DSL provider as well as hand out IP addresses to the local network. Option 2 is to continue to use the M1000 as a router by default and disable DHCP on your DIR 655 so that it essentially acts as nothing more than a switch or wireless access point while the M1000 hands out local IP addresses. I personally would recommend using the DIR 655 to route IP's as it's got far more configuration utilities than the M1000 does as a router, and really what's the point of getting the 655 if you're only going to use it as a switch or access point when there are other simpler and cheaper devices that could do that for you.
Jul 20, 2009 | D-Link Xtreme N DIR-655 Wireless Router
Computer will not connect to internet through router
check the connections between the router and the modem either cable or dsl or whichever
and change the setting in the router interface so you know what the ssid is being broadcasted and the network key
Jul 18, 2009 | D-Link Xtreme N DIR-655 Wireless Router
Connect Laptop to PC desktop which has cable connection.
YOU WILL NEED TO GET A WIRELESS ROUTER TO BE ABLE TO USE THE LAPTOP WIRELESS, iT IS A VERY EASY SET UP AND CONNECT THE DESKTOP WIRED AND THE LAPTOP WIRELESS TO A WIRELESS ROUTER.
May 06, 2009 | Arris SURFboard SB5120 Modem
I have an issue with my Dlink DIR-625 wireless and cable modem
it isn't syncing up with your modem, try a hard reboot, disconect everything, even the cable, after 5 minutes , first screw the coax cable back to the modem, that will re establish the cable connection, plug everything back in, and if that pc light still is still doesn't work, the router may be bad, look on the Dlink site and download the latest firmware, as a last resort, but also reset the router first before trying anything, there is a reset button on the router. Sometimes certain routers don't work with certain modems, if you try the reset, then the hard reboot, and the firmware, you have covered all the bases
Mar 30, 2009 | D-Link DIR-625 (790069292637) Wireless...
Wireless router stops internet connection to modem during install
are you sure your hooking the comcast modem in the right place?
Feb 08, 2009 | Arris SURFboard SB5120 Modem
Helpppppp
Hi, sorry I only do vaccuums, not computers.
Mar 28, 2008 | D-Link Wireless
CAN YOU HELP PLEASE?
Sorry that isnt my area of expertise. I am mainly Television and appliances. I would try one of the other experts that specialize in computers. they will be able to help you out.
HELP WITH MY ROUTER
sure..send me a email to pn4pm@yahoo.com and we'll get you right as reign..
Computers & Internet Logo
100 people viewed this question
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
