Question about Dell Dimension 2400 PC Desktop
Keyboard controller failure ,2 bips ABC in green D
Keyboard controller failure 2 bips abc in green D in yellow iv tried pressing the start button 10 secs with no cables atached and then remove the battery but how reset then?? thnx for all if some body can help i apreciate i cant acces to set up i need to put the chasis is neccesary??
  • Dell Master
  • 4,737 Answers
Two beeps generally means RAM failure, so it's better for you to check the RAM or replace using another from your friend or you can try your's to another PC so that you an make sure which one is the fault. If this isn't the problem, then you need to clean the motherboard and its components, blow away all the dusts, and reinsert everything after cleaning, you can use brush or rubber eraser to clean the tip of the ram or pci cards etc.... Good luck..
Posted on May 10, 2010
How do i type the @sign on the above product
if it is a hey board operation the @ sign is press shift key to upper case and press the number 2
if is on an i pad or phone press the numbers section on the onscreen keyboard and the @ sign is in the numbers section under the abc button ( press the abc button to get numbers up on the keyboard.)
Sep 16, 2015 | The Computers & Internet
ABC diagnostic lights are green and D is yellow. Ram only works if slot 1 is used. If slot 1 and 3 are used Bios appears on the monitor with a flashing cursor. Dell dimension 8400
A,B,C green and D yellow is indicative of a component failure...in that the system cannot read a device it feels necessary to boot the machine such as a hard drive, floppy or cd/dvd drive. Power down the system, remove the power cord from the back, push the power button in for 10 seconds to bleed off the power. Remove and reseat all cables connecting the system devices. Remove all ram except for one stick and reboot. If you get boot, then try replacing the ram one stick at a time. If you still cannot boot though, try removing the cables from the devices and then plug in one a time until you get the machine to boot. If there is still a problem, the hard drive or its controller maybe the culprit.
Jun 14, 2010 | Dell Dimension 8400 PC Desktop
Keyboard controller failure ,2 bips ABC in green D in yellow ,iv tried pressing the start button 10 secs with no cables atached and then remove the battery but how reset then?? thnx for all if some body...
Have you tried with another Known, good & working keyboard? If not, try it first. If the problem persists, then you have to clear the NVRAM using the jumper (if a mere re-seat of the CMOS coin-cell didn't work). To locate the jumper, consult the user manual. Also, re-seating the memory modules (RAM modules) is known to have resolved this.
Mar 16, 2010 | Dell Dimension 2400 PC Desktop
Iv tried yo many keyboard even dell and mouses and nothing at first says keyboard controller failure
The problem could be caused due to system setup lockup. Kindly disconnect all the devices from the back of the computer including the power cord. Press and hold the power button for 10 seconds.
Open the system chassis and remove the cmos battery to reset your motherboard.
The following link would help you do the same.
http://support.dell.com/support/edocs/systems/dim2400/en/sm_en/rmvcvr.htm
Once you have reseated the cmos. Connect the monitor keyboard and power cord and start the computer and check for the problem
Thanks for using fixya
proton
Mar 15, 2010 | Dell Dimension 2400 PC Desktop
Dear Sir, Re: Laptop NEC Versa E6300. When I am using the keyboard a,b,c,...I get the wrong letters. Somebody told me I have pressed the ''Fn'' key by mistake. Please help & thanks. Regards Sheik A...
The fn key would convert most abc keys into function keys not make them produce other letters. You may have changed your region settings or your keyboard style. Both can be changed under the control panel under keyboard settings.
Oct 28, 2009 | NEC Versa VX Notebook
Keyboard not working :@
are u change the writing language into ABC mode from DICTIONARY mode(in message setting).If answer is NO then first change it & see the results.
And if it is already in ABC mode then i suggest u to show it in wellknown mob. shopee for repairing.
Dont take a risk,give it in safe hands.
Aug 13, 2009 | RIM BlackBerry Bold 9000 Smartphone
Keyboard keeps defaulting to numbers when texting
configure received message settings:
1. From standby mode, press the OK Key [OK] to unlock the keypad,
then press the Left Soft Key [Message], then the Left Soft Key
again for [Settings].
2. Press the Directional Key up or down to highlight one of the
settings below, then press the OK Key [OK] to select it:
ENTRY MODE
Sets an Entry Mode as a default. For example, if Abc Mode is the default, its icon
will appear.
1. Select "Abc", "ABC" or "123" by pressing the Directional Key up or
down then press the OK Key [OK].
Jul 18, 2009 | UTStarcom Blitz Cell Phone
Toshiba qosmio E-10 noises keyboard and start up
Sound like you have a stuck key and the bip noise is the keyboard buffer pverloading.
If you can't unstick this key, you need a new keyboard.
Apr 13, 2009 | Toshiba QOSMIO E15-AV101 Notebook
Question mark sign
If you aren't comfortable with using Graffiti 2 (manually writing on the provided pad) then call up the Z22 keyboard (tap the ABC symbol on the top left of the entry pad) and then tap Shift and the (/); that's the slash button on the bottom right corner of the keyboard. If you are interested in learning more about Graffiti 2 input for your device, try reading this PalmOne article or download the Graffiti 2 Alphabet or Graffiti 2 Tips & Tricks guide.
Nov 05, 2007 | Palm Z22 Handheld
When on web & changing abc to numbers for passwords cant do but is fine for texts
Hello , As far as I know and as correct as I am maybe this is a simple problem that you can resolve by pressing the num lock key which is situated on the right of a qwerty keyboard that is the keyboard that the majority of people are using and then make a try with your password abc123..
Jan 10, 2007 | Motorola Mobility RAZR V3
Dell Dimension 2400 PC Desktop Logo
120 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
