Question about RCA HD52W59 HDTV Projection Television
Tv will not power up
I have a rca hd52w59 serial #f432cg036 manf 10/2005 chassis #itc222a. the other day it just shut off and then i could smell electical burning smell. when i plug it back in the green light flashes then i saw sparks on the rear right side of the tv opposite side of the power cord.. is this the power supply? is it hard to change and do you have a part # price and supplier?
  • Ylee8 Jun 06, 2008
    My RCA HD52W59 is not turning on. The power light comes on, but then it turns itself off after a few seconds with a burnt smell.The board where the Flyback transformer plugs into that has is burnt spot, there is a little hole about an inch away from the Flyback transformer. Not sure if that is the composite power supply board. Where can I get a new board????
  • michael9803 Oct 29, 2008
    I have sparks arching on the under side of the board in the middle of the board. Do I have to replace the board or can it be repaired. If I need to replace do you know the part number?
  • 61 Answers
Flyback transfromer is bad,part number 259296,part is around 60.00,you might find it at mcm electronics,phone number is 1-800-543-4330
Posted on Mar 30, 2008
I have a RCA HDTV Model #R52WH74 Serial #G385c1080 Chassis #ITC222A that I had since 2007 or 08...I turn the TV on and about 15 or 20 minutes it goes out, but the green light indicates it's still on and it...
This set is known for low grade Chinese capacitors in the power supply, most likely if you remove the back you will see some that are bulged at the top and bad, you have 2 choices if you want to fix it yourself, purchase new caps and solder them in or replace the power board, caps are quite cheap if you can solder and have the equipment
Mar 04, 2018 | RCA HD52W59 HDTV Projection Television
Green lite keeps going off
you have the ITC222A chassis TV so it only has the one power light does it come on briefly three times then go out and stay out or does it come on one time then goes out and stays out? Let me know and will assist you with the issue.
Jul 09, 2012 | RCA HD52W59 HDTV Projection Television
Should I,change just the resistor that is burned?
Normally if a resistor has burned you will need to locate the cause or a replacement resistor will surely blow instantly in most cases? Is your model the HD52W59 RCA with the ITC222A chassis? If so let me know the resistor board location number such as RP256 etc.
Oct 15, 2011 | RCA HD52W59 HDTV Projection Television
My RCA R52WH74 chassis # ITC222A wont turn on. The green power light comes on for about 10 seconds then shuts off. No picture, no sound. How do I fix it? Buying a new TV just isn't in out budget!
That model is famous for having issues with the deflection board failing. Replacing the deflection board should solve the issue. You can get replacement deflection board for the ITC222A chassis from www.tvrepairworld.com under the RCA circuit boards catagory.
Aug 05, 2011 | RCA R52WH73 Projection Television
Power comes on but the power goes off after three times coming on
Thats the ITC222A chassis. Famous for deflection boards. You can get replacement deflection boards from www.tvrepairworld.com
Jul 11, 2010 | RCA HD52W59 HDTV Projection Television
Television will not powwer on
Hello al1895,
This model of TV uses the ITC222A chassis. This is a common problem in this unit. The problem is usually centered around 4 capacitors (CP140, CP150, CP110, and CP114) They usually vent (becom bloated or puffy) and develop an internal short which causes the TV to shut down. This is usually caused by power surges (even when connected to a surge protector). The repair for this problem does not cost much, and I would suggest that you have a TV repair technician examine this TV due to the other problems that can happen with this chassis (ITC222A).
I hope this helps,
Thank you,
Shuttle83,
http://www.electron-age-technologies-llc.com
Jul 27, 2009 | RCA HD52W59 HDTV Projection Television
Part?
Go to Tritronics or Union or Andrews electronics for RCA parts. They all have websites.
Jun 08, 2008 | RCA HD52W59 HDTV Projection Television
RCA HD52W59, Serial: G075CN0AO, Chassis # 1TC222A
ask your service depot about the service flash on the covergence connector,causes intermittant faults and deflection problems /
Aug 22, 2007 | RCA HD52W59 HDTV Projection Television
RCA HD52W59 HDTV Projection Television Logo
213 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
