Question about Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+
I need to relocate my Craftsman remote entry pad. How do I get it off the screwed-in mounting bracket underneath? Thanks.
    President:
  • 3,197 Answers
If you mean the wireless keypad you need to remove the screw inside the battery compartment and then hit the bottom of the keypad with the heel of your hand. It needs to move up about 1/4 inch and then will come off.
Posted on May 10, 2010
How to remove starter from 2004 pacifica
REMOVAL
Disconnect the negative battery cable.
Remove (UPPER RADIATOR CROSS MEMBER) and relocate (UPPER RADIATOR CROSS MEMBER REMOVED) the upper radiator crossmember, (Refer to 23 - BODY/EXTERIOR/RADIATOR CROSSMEMBER - REMOVAL).
Remove the radiator fan module (FAN MODULE IN VEHICLE) (Refer to 7 - COOLING/ENGINE/RADIATOR FAN - REMOVAL).
Remove the wiring harness clip from front mount.
Remove the coolant line clamp bolt (COOLANT LINE BRACKET).
Remove the upper nut from the front mount (FRONT RUBBER MOUNT UPPER NUT).
Remove the upper starter mounting bolt (UPPER STARTER BOLT).
Remove the middle starter bolt (MIDDLE STARTER BOLT).
Raise vehicle and support.
Remove the lower front mount nut (FRONT RUBBER MOUNT IN POSITION).
Raise and support engine (SUPPORT ENGINE).
Remove the lower bracket bolt to transmission (BRACKET TRANS BOLT).
Remove the lower bracket bolt to engine block (BRACKET ENGINE BLOCK BOLT).
Relocate the front mount and bracket.
Disconnect the positive battery cable from starter
Disconnect the solenoid connector from starter.
Remove the lower starter bolt (STARTER LOWER BOLT).
Remove starter from vehicle.
Aug 16, 2011 | 2004 Chrysler Pacifica
Ladies / Gentlemen: I have a Craftsman 139.53975SRT1 Garage Door Opener. What is the correct keyless entry pad for this opener? Will a 139.53876 keyless entry pad work with this opener? Thank You! ...
The correct keypad for your opener is 139.53684. The 53876 keypad is an older technology and will not work correctly. If you program it you will find your remotes no longer work and if you reprogram your remotes the keypad will not work.
Sep 08, 2010 | Sears Craftsman LiftMaster Chamberlain...
Remove the screw you can get to in the battery compartment and then using the heel of your hand hit upward on the bottom of the keypad. It will slide up and off the hidden screw.
Mar 16, 2010 | Sears Craftsman LiftMaster Chamberlain...
Reset Craftsman keyless entry pad.
What you are asking for is not possible. You need to call a garage door repair technician. They will drill a hole through the door and using a special tool can pull the rope to release the door.
Sep 25, 2009 | Sears Craftsman LiftMaster Chamberlain...
LiftMaster 1/2hp: Key Pad Won't Work!
If you have a wireless keypad replace the battery.
Jun 05, 2009 | Sears Craftsman LiftMaster Chamberlain...
Keylees entry and remote controls do not work at the same time
There are two types of technology with this operator (rolling code and non-rolling code). This operator will except one or the other but not both. It is not uncommon for a rolling code (Security+) remote or keyless to lose the "rolling"part of its technology and become a non-rolling code device so it is not compatable with the rolling code technology. You will need to replace the one remote or keyless that is not like the others.
Nov 15, 2008 | Sears Craftsman LiftMaster Chamberlain...
Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+ Logo
23 people viewed this question
Top Sears Building Materials Experts
Glenn Mayer
Glenn Mayer
Mike
Are you a Sears Building Material Expert? Answer questions, earn points and help others
