Question about Nortel BAP120 802.11a/b/g Wireless Access Point
Default use name and password with ip address of nortel bap120.
2 Suggested Answers
SOURCE: default use name and password with ip address of
For that Connect your router to computer with ethernet cable then you can access it with following default link.
http://192.168.0.1
or
http://192.168.1.1
If you are not able to access it with above ip then check your computers ip address gateway ip is your router ip try with it.
Then it ask for user name and password.
Type user as "admin" and password as "admin" or "password" or blank.
Then you can see configuration page of router.
Let me know if you need further assistance.
Thanks for using FixYa.
Posted on Mar 16, 2010
How do i enter new network name and password
If you are having problems accessing routerlogin.net, visit Router login page cannot be displayed or is blank.
  1. Enter the router user name and password when prompted. ...
  2. Click OK. ...
  3. Select Wireless.
  4. Enter your new user name in the Name (SSID) field.
  5. Enter your new password in the Password (Network Key) fields.
Oct 27, 2016 | Computers & Internet
I cant accesses 192.168.136
Open a command-line prompt.
Enter 'IPCONFIG /ALL'.
Scan the output for the IP-address of the "gateway" (or "DHCP-server").
Type that IP-address into your web-browser.
Jul 10, 2014 | Nortel BAP120 802.11a/b/g Wireless Access...
My router is nortel BAP120 and after using reset option it is not able to finding by search and 11b/g sign also disapper on router what should i do?
AFTER reset access-point disables wireless access so you need to connect CAT5 cable to pc and Access-point then type 192.168.1.136 in your browser
User Name nnadmin
Password PlsChgMe!
login with above details and reconfigure wireless and other properties of your access point.
Mar 29, 2013 | Nortel BAP120 802.11a/b/g Wireless Access...
Lynsksy E1200 tried to reset. my passord and network name are of no assistance. After running software, router is not found. Tried using "admin" for both but nothing works. Please advise. ...
Reset your router back to it's factory settings by holding the reset button for about 5 seconds. I have provided a list of the most popular router brands. If it does not work you may need to google what your specific model's default IP address/default username/default passwords are, for example search for "Encore ENHWI-2AN3 default IP address" The default login info can change, it can depend on where you obtained your router. If you purchased it yourself from a store then the standard defaults should work. If you obtained your router from your Internet Provider you may need to contact your service provider. It also may depend whether it's an old or new model router as well. And you may need to press and hold the reset button on your router several times before it actually clears. Make sure you have a wired connection then once you have accessed your router simply run the Setup Wizard. Set your SSID as something you'll remember like "Mavericks Network" and your Password can be something like your phone number for example 3109876543
Belkin - Username: Leave the field blank Password: Leave the field blank Default IP address is: 192.168.2.1
Buffalo - Username: root Password: Leave the field blank Default IP address is: 192.168.11.1
D-Link - Username: admin Password: Leave the field blank Default IP address is: 192.168.0.1
Encore - Username: admin Password: admin Default IP address 192.168.1.1
Linksys - Username: admin Password: admin Default IP address 192.168.1.1
NetGear - Username: admin Password: password Default IP address will be: 192.168.0.1 or 192.168.1.1
TP-Link - Username: admin Password: admin Default IP address 192.168.1.1
TrendNet - Username: admin Password: admin Default IP address 192.168.10.1
Zhone - Username: admin Password: admin Default IP address 192.168.1.1
Zyxel - Username: admin Password: 1234 Default IP address 192.168.10.1
Sep 07, 2011 | Computers & Internet
I want to factory reset my nortel AP 7220, how do I reset? What would be default IP after reset?
There is probably a reset button somewhere on the device, it is probably a small pinhole that you put a paper-clip into the reset.
If it has its own http web page, there is likely a reset to factory defualts option.
The ip of the computer connecting to it should not change.
On a computer connected to it, open cmd start>run then type in cmd, and type 'ipconfig'.
It will display details about your connection. Where it says 'default gateway' is the ip of the device.
You could try to put the ip in your browser and see if the device has a web page.
May 02, 2011 | Nortel Networks 7220 (NTE350BG) 802.11...
When i try to install my Linksys wireless G, it ask for a password. I don't know it and it won't let me proceed!
Step 1:
Open a web browser such as Internet Explorer.
Step 2:
Go to the Address bar and enter your router's IP address ("192.168.1.1" is the default IP of most Linksys routers) then press [Enter].
NOTE : For WRP400, the default IP address would be "192.168.15.1" and if you place the router behind a primary router with the IP address of "192.168.15.1", then the router will automatically assume a new default IP address, "192.168.16.1".
NOTE: If the IP address of the router has been changed, type the router's IP address in the Address bar instead.
The router's IP address can be changed by:
1. Running the router's setup CD.
2. Changing it on the router's web-based setup page.
1. Check the router's IP address. For instructions, click here.
2. Press the Reset button at the back of the router for 30 seconds.
NOTE
: This procedure will reset your router to factory defaults. Any settings on the router will be erased. The router's IP address will be "192.168.1.1" and the password will be "admin".
Step 3:
A new window will prompt for a User name and Password. Leave the User name field blank then enter your router's password ("admin" is the default password), then click OK.
If you forgot the router's password you need to reset the router. For instructions, click here.
Nov 04, 2010 | Linksys Wireless-G Broadband Router
How to obtain my password and add another laptop to wrt54G
To access the router's web-based setup page using Mac, click here. Step 1:
Step 2:
Step 3:
If you forgot the router's IP address you can:
Aug 23, 2010 | Linksys Wireless-G WRT54G Router
http://192.168.0.1
or
http://192.168.1.1
Mar 16, 2010 | Nortel BAP120 802.11a/b/g Wireless Access...
Reset password for nortel BAP120
there might be a reset button in the back of the router or you can try your routers ip address or give them or your ISP a call and tell them to reset it.
Nov 24, 2009 | Nortel BAP 120 (NT5S40CEE6)
Nortel BAP120  802.11a/b/g Wireless Access Point Logo
Top Nortel Computers & Internet Experts
J John
Gopi Venkatesan
Gopi Venkatesan
Jax Planet
Jax Planet
Are you a Nortel Computer and Internet Expert? Answer questions, earn points and help others
