Question about Sony KP-61HS30 TV
No signal tv has developed what i believe to be and internal problem. has started showing an intermittent no signal with loss of picture and sound. when it does this screen is dark and not white static like when there is no reception. getting progressively worse. will be working fine then signal and sound loss. have ran other sets on cable to make sure its not external problem. home theater and dvd still work and play fine.
  • 129 Answers
Good day. Try to check the tuner section. You mention that it functions good in auxilliary functions. check tuner section and system IC.
chris
Posted on Mar 30, 2008
SOURCE:
My TV brings up message "No Hard Disk Found" and doesn't show pictures
sounds like the hard drive went in the Digital TV box, call your local tv cable company for a replacement.
May 08, 2015 | Audio Players & Recorders
LG HDTV LED
Sounds like you might have a defective unit, or the source that is connected to your tv (cable box, dvd etc) is going out. A lot of times if you have a cable box, glitches, loss of sound and/or color are because of the quality of the input source. Try changing the channel. If the problem is the same on any channel - or on your dvd/xbox, then it is probably a defective tv. You may be able to get it exchanged through LG. Hope this helps! Good luck!
Feb 04, 2012 | LG 42SL9000 42 in. HD-Ready LED TV
Just bought a Yamaha RX-V371 surround sound receiver and the TV audio signal is cutting out. I am running a Samsung LED TV with a single HDMI cable (sound/picture). I tested a smaller tv with a short HDM...
Settings are not the source of intermittent problems.
"Signal loss" is indicated WHERE? So what's going on upstream at the source? ITS cables are a part of this.
My $.02... I never route any signal unnecessarily to or through a device that doesn't enhance or consume it. Hence, my BEST video from each of my several video sources goes directly to my TV/monitor and my BEST digital audio from all sources goes directly to my AVR.
No problems.
Sep 20, 2011 | Audio Players & Recorders
Picture disappears,
This is an intermittent problem developing on your interface board. The low-signal input is being interupted by a fault in the video processing stages and buffering stages. Get it serviced now before it bacomes a really expensive repair.
Nov 02, 2009 | Olevia 237T 37 in. LCD TV
Hello Fixya, Thanks for being available in the Net!!! I have a mitsubishi tv model #ws-55809 and the picture is funky.... It's like it's cartooned. The words are fuzzy a bit and so is the skin...
Sounds like a loss of picture resolution. There is a circuit board in your TV that determines the type of signal (HD or standard definition) The video signal (picture signal) is routed thru this board. Call a local Mitsubishi servicer and get a price on replacement. It may cost more than its worth.
michtech
Feb 12, 2009 | Televison & Video
Sound but no picture
I believe the cable guy is correct and I will suggest you call for professional help now,if you try to use it like this the problem might become expensive.
Sep 23, 2006 | Sony KV-35S66 35" TV
Sony KP-61HS30 TV Logo
127 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Steve Allison
Steve Allison
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
