My fireplace was purched in 2005. Since then I have replaced the Vanguard Thermalheostat blower twice the last time was last fall. It is now going bad. Is there a problem with these blowers? My next one will be the 4th blower. Is there an alternative fix to this problem. My first blower was installed in the fall of 2006. They seem to last only one season and are quite expensive. Thanks for any help you can offer.
  • Heating & Co... Master
  • 3,315 Answers
I would try the makers of the fire place perhaps google them see if they have a tech line they should be able to tell you if this a common fault or offer help with this type of blower .
Posted on May 10, 2010
I HAVE A HC3820 AND AM CURRENTLY LOOKING TO OBTAIN A BLOWER. THE PROBLEM IS THAT THE ONE NEEDED FOR THIS MODEL IS FAK-1500 AND I CANT FIND IT ANYWHERE! PLEASE HELP!
Honestly, go to www.grainger.com. Since Superior/Lennox Hearth/and FMi are all merging into one company you are going to have a very hard time finding replacement parts for older Superior units. Plus the new company, Astria Fireplaces, is going to be using FMI for their woodburning products so no more Superior products available.
If you bring the old blower to your local Grainger they can match it up. I hope this helps.
Jan 24, 2014 | Superior FBK-200 Fireplace Blower Kit for...
Elco fireplace blower wont work
If your blower/fan blows air into a "box" with tubes that conduct heated air out through the screen, that assembly may have failed. I had one that burned out and had to be replaced.
Dec 03, 2013 | Leisure HOMEPRIDE Electric Fireplace...
I have a heatsurge electric fireplace and the blower comes on but i have no heat. i replaced the plug but it wont produce heat
Not sure what cord you replaced, but the problem is generally caused by the heater's circuit failing or the heating element itself has failed. This is a common problem with 98% of all electric fireplaces. If I recall correctly, the Heat Surge has a one year warranty. If yours falls into that one year time line and you still have your proof of purchase, file a warranty claim with the manufacturer. If it's not still in the warranty period, you can locate the necessary parts in your area, by clicking on the link below.
http://www.heatsurge.com/help/parts-locator.cfm
Hope this helps you and thanks for choosing FixYa.
Sep 20, 2011 | Heating & Cooling
Where does the FBK200 blower go in the Marco fireplace
As you are aware the Marco Fireplace Co is no longer in business. However, the blower model # you listed is a DESA/Vanguard part number. In any event, it may work.
The blower goes in the lower compartment (probably louvered) under the firebox. It is then attached to the rear wall of the compartment, with the blower output facing up the back wall of the firebox. There should be an arrow on the blower housing indicating which way it should point.
If your firebox is already wired for a blower and has a duplex receptacle in place (for the blower to plug into), you're in business. If it doesn't I highly recommend that you install one and not try to hard wire the blower.
The blower, if purchased new, should come will all the hardware to mount it. If it didn't you can use sheet metal screws to attach it to the rear wall of the firebox. However, make sure that you put a rubber flat washer behind the mounting frame and then screw thru it into the firebox wall. This will help eliminate vibration and noise.
Hope this helps to get you started.
Feb 25, 2011 | Heating & Cooling
My fireplace was purched in 2005. Since then I have replaced the Vanguard Thermal/rheostat blower twice, the last time was last fall. It is now going bad. Is there a problem with these blowers? My next one...
I have not heard of a problem with the blowers or a recall. But depending on what unit you have, and who you purchase the blower from, perhaps you could get a warranty so that you aren't spending out of pocket everytime. The original Vangaurd manufacturer, Desa International, went out of business in 2008, but there is a new company that took over some lines of the units and are still making the blowers for most of them. They hold a warranty on the blowers if you purchase is from a Distributor. I hope this helps a little!
Mar 16, 2010 | Heating & Cooling
2001 Kia sportage blower motor resistor has been replaced twice and now failed for the third time. Blower motor will only work on high speed. How do I trouble shoot root cause. - Blower motor has also been...
hi there i was wonder can anyone help me i have replaced my heater blower resister has been replaced and now has stoped working again what is the problem can someone plz help me. the fan is working fine i ran a ground wire and it works but only on high and will not turn off
Dec 29, 2009 | Kia Sportage LX Cars & Trucks
Heating & Cooling Logo
Top Heating & Cooling Experts
Paul Carew
Tim Whalen
