Question about Whirlpool Calypso GVW9959K Top Load Washer
LD CODE BUT NOT PUMP
I HAD A LD CODE AND HAD THE PUMP AND MOTOR REPLACED, THERE ARE NO CLOGS IN THE TUB, OR ANY OF THE DRAIN HOSES ANY OTHER SUGGESTIONS?
CHECK THE AREA MOULDED INTO THE OUTER TUB AT THE
BOTTOM BACK WHERE THE HOSES ATTACH TO THE TUB.
A FAVORITE PLACE FOR OBJECTS TO GET CAUGHT. IF O.K., CHECK THE ELECTRICAL WIRING FROM THE PUMP
MOTOR TO THE CONTROL BOARD. THERE IS A CONNECTOR BEHIND THE FRONT PANEL AT THE BASE. MAKE SURE THE PINS IN THE CONNECTOR ARE NOT CORRODED.
IF ALL IS O.K., REPLACE THE CONTROLLER FOR THE PUMP
MOTOR.
Posted on Mar 31, 2008
Washing machine not draining, LD error code
Through the lower tube of the tub may be able to remove the item of clothing.
Dec 22, 2013 | Kenmore HE2 Washing Machines
We continuosly get an LD code on our Oasis Washer. Hoses are fine and have ran it through the clean cycle several times. any suggestions
LD means long drain ( time ) and is usually attributtable to either a bad water pump, clogged water pump or clogged hose from tub to pump or pump to drain.
Jun 01, 2011 | Washing Machines
I have the whirlpool Cabrio model WTW6600SB2. We keep getting the code LD when we use the normal rinse cycle. Also trying to do a clean with bleach cycle and t is supposed to go 60 mins and goes less...
The LD:
Ld (F32) Long Drain "Ld" flashes when water level drop ain't sensed by that fancy lectronic control.
Check these things out:
Drain pump fouled/clogged
Drain hose too high for propah pumpin.
Pressure hose tubing clogged/pinched came loose from that fancy control upstairs.
Service Manual
More Here
Feb 03, 2011 | Washing Machines
My Maytag Bravos quiet series 300 washing machine stopped. Won't drain. A message Ld shows. Not sure what to do
Hi and welcome to FixYa, I am Kelly.
My response is very long and will be in 2 parts this is PART 1
Here is what the service manual says about Ld:
"Ld" (Washer is taking too long to drain
water from the wash tub)
Check the following:
Is the drain hose kinked or clogged?
Is the drain hose installed properly? See
"Connect the Drain Hose," page 2-5. Press
PAUSE/CANCEL to clear display
Also:
Is the drain hose clogged, or the end of
the drain hose more than 96? (244 cm)
above the floor?
See "Drain System," page 2-3.
6. To remove the drain pump: (there are 2 pumps... the drain pump is on the left)
a) Loosen the clamps and pull the inlet
and outlet drain hoses off the pump.
Note that there is a tab on the outlet
connector that fits into a slot in the
hose.
b) Remove the three 5/16? hex-head
screws from the drain pump and remove
the pump from the tub.
Check the pump inlet and the tub outlet for obstructions.
Pump electrical winding resistance test:
-Disconnect the wire connector from the
drain pump terminals.
- Set the ohmmeter to the R x 1 scale.
- Touch the ohmmeter test leads to each
of the drain pump terminals. The meter
should indicate between 10.5 and 14 ?.
----Due to the design of the machine the 2 wires going to the drain pump have be notorous for backing out of the plastic connector. Check the connector of the pump for loose terminal connections. --
From the Ld troubleshooting steps / procedure:
Long Drain
Ld flashes when the water level does not change after the drain pump is on.
• Is the drain hose or the drain pump clogged?
• Is the drain hose height greater than 96? ?
• Is the pressure hose connection from the tub to the machine/motor control pinched or plugged?
• Is the pump running? If not, see TEST #7.
TEST 7
TEST #7 Drain/Recirculation
Perform the following checks if washer fails to drain or recirculate.
1. See Activation of Manual Diagnostic Test
Mode, and perform the Manual: Pumps
test.
2. Remove the console to access the machine/
motor control assembly. See Accessing
& Removing the Electronic Assemblies.
3. Visually check that the P4 connector is
inserted all the way into the machine/motor
control.
If visual check passes, go to step 4.
If visual check fails, reconnect P4 and
repeat step 1.
4. Remove connector P4 from the machine/ motor control and check resistance values of pump motor windings. Resistance values should match those shown in wiring diagram, page 7-1.
If resistance values are good, go to step 7.
If winding measurements are much higher (tens of ohms to infinity) than shown in wiring diagram, a problem
exists in the motor winding or in the connection between the machine/motor
control and the motor. Go to step 5.
5. Tilt machine forward to access the bottom
of the machine and the pumps. See
Figure 1, page 6-13.
6. Check the resistance at the pump motor. Remove the connector at the motor and
take measurements across pump terminals. Measurements should be as shown in the wiring diagram.
If winding measurements are much higher (tens of ohms to infinity) than shown in wiring diagram, replace the
pump motor.
If the resistance at the pump motor is correct, there is an open circuit in the wiring between the motor and the machine/
motor control. Repair or replace the lower wiring harness.
If the pump motor windings and machine/ motor control check OK, repair or replace the pump. Be sure to check
the pump and tub sump for foreign objects before replacing pump.
7. See Activation of Manual Diagnostic Test Mode, and perform the Manual: Pumps test.
8. If the Manual: Pumps test failed, then the machine/motor control has failed:
Unplug the washer or disconnect power.Replace the machine/motor control assembly.
Perform the Manual: Pump test.
Nov 21, 2010 | Maytag Bravos 3.8 Cu. Ft. Washer
My washer is indicating a "ld" problem. I have readjusted the load and restarted the machine but it continues to stop and the "ld" code keeps coming on. I have a very small load in the machine so I know...
Hello, the "Ld" error code indicates a long drain. It is displayed when water level does not change while the drain pump is running. You can check for the following problems:
  • Is the drain hose kinked or clogged?
  • Check the drain pump for clogs. Is it running?
  • Is the drain hose height greater than 96 inches?
  • Is the pressure switch hose connection from the tub to the machine control board pinched or plugged?
  • Do you see excessive suds in the basket? Are you using high efficiency (HE) detergent?
  • Thanks
Jun 13, 2010 | Whirlpool Calypso GVW9959K Top Load Washer
What does LD mean
The Ld error code indicates a long drain. It is displayed when water level does not change while the drain pump is running. You can check for the following problems:
May 29, 2010 | Whirlpool Calypso GVW9959K Top Load Washer
My kenmore elite calypso has a code of ld
Well error Ld means - Long drain - The Ld error code indicates a long drain. It is displayed when water level does not change while the drain pump is running. Anyway you can please check out the following steps -
Is the drain hose height greater than 95 inches?
You can try to reset your washer by Pressing STOP/CANCEL. Please check out all the above steps, post comments if further you have the same problem.......
Good Luck!!
Thanks
May 12, 2010 | Washing Machines
During the wash cycle, the washer started beeping and I found a code "LD" on the dial. What is the problem
Here is what the manufacture says about LD -- my comments will follow
Long Drain
ô Is the drain hose or the drain pump clogged?
ô Is the drain hose height greater than 96"?
ô Is the pressure hose connection from the tub
to the machine/motor control pinched,
kinked, plugged or leaking air?
Phil's comments ---->
Almost always this code is due to a plugged drain pump or hose, it is especially common when washing a rug with a rubber backing that comes off or small articles like baby socks that get caught in the drain system of the machine. Depending on how adventurous you feel in taking this unit apart is your call, but due to the complexity of it I would recommend calling a service expert.
Just one guys opinion..
Apr 19, 2010 | Whirlpool Cabrio WTW6600SBT Top Load...
What does the Ld code mean on a calypso Kenmore Elite Washing Mashine
Hello there
LD means a long drain
it is taking longer than 8 minutes to drain out the tub
please check the following
First unplug the machine to prevent electrical shock·
Check wiring harness to ensure they are all connected and are not fried
·If needed remove the side panel and Check the hoses going to pump for clogs and all drain hoses and drainage system
· Check circuit board that controls the pump to see if any wires are burnt or have failed
once the faulty part or the clog has been cleared simply plug in the machine and press the cancel button and resume your normal washing operation
Hope this has been very helpful for you
Best regards Michael
Dec 30, 2009 | Kenmore Washing Machines
Calypso washer gives error code Ld or ob. won't finish load or drain
Ld=Long drain. If it takes longer than five minutes to drain the water the operating pressure switch resets. Most common problem associated with this code is a clogged or failing water pump and hoses.
ob=Off balance. Open the lid and redistribute the clothes evenly around the tub, close lid and press the start button.
Jul 14, 2009 | Whirlpool Calypso GVW9959K Top Load Washer
Whirlpool Calypso GVW9959K Top Load Washer Logo
Dan Webster
Dan Webster
Mike Cairns
Mike Cairns
prem mathew
