Question about Ace Hardware Living Accents Patio Heater Cover
Out of the box the patio heater didn't work and I never returned it. The pilot would light then when you move the knob to the on postion the pilot would go out and it wouldn't fire up. I bought a new regulator and now the pilot flame is tall and yellow the heater turns on for about five minutes then extinguishes. Any ideas?
  • 8,404 Answers
If it is beyond any adjustment period from Ace, I suggest you take this to a full service propane service center for repair. You shuld first check with your Ace hardware man.
Posted on May 16, 2010
2 Suggested Answers
cadesertmax
  • 274 Answers
SOURCE: Out of the box the patio heater didn't work and I
When the pilot flame is tall and yellow it normally means there is a partial blockage in the pilot tube or pilot jet orifice. Try cleaning out the pilot tube and orifice.
Posted on Jul 10, 2011
I have a Kirkland patio heater model # PTH-106SS-3G the pilot will not stay lit. Do I need to replace the whole pilot assembly
Hi, If the pilot light goes out when you turn the gas knob to full power on lighting them the most likely cause will be a worn thermocouple, these usually last between 2 years up to 6 years. Found this site very helpful, patio heater problem solving. They have a few solutions to checking patio heaters.
Oct 12, 2011 | Williams 2509612 Ceramic Mid-Size Heater
The pilot seems to light but then when I turn the knob to ignite the main burner, the pilot goes out. Is there a technique to clean the igniting assembly?
let the pilot light burn for a few min and get hot after this try slowly moving the knob over to full burn. Sometimes it just need to heat up.
Feb 14, 2011 | Endless Summer 233000 Open Flame Patio...
Pilot on my patio heater will not stay lit. goes out when i release the knob
If the heater is the same as this type of patio heater and it lights on pilot and goes out it is generally a worn thermocouple. These are designed to switch off the patio heater when something is wrong, changing one fixed 90% of the problems. Sometimes it can also be caused by a worn tilt switch but always start with the most likley and work backwards. Found this site very useful, patio heater problem solving page.
Jan 04, 2011 | Stainless Garden Sun Steel Propane Patio...
Out of the box the patio heater didn't work and I never returned it. The pilot would light then when you move the knob to the on postion the pilot would go out and it wouldn't fire up. I bought a new...
Mar 16, 2010 | Ace Hardware Living Accents Patio Heater...
I go thru the process of lighting the pilot light following the directions exactly, but as soon as I let the pilot light switch pop out so that I can turn it to the left to light the heater the flame goes...
The system works off of a thermocouple that is heated by the pilot. The thermocouple creates millivolts that magnetize a head behind the control knob. When you push in the knob the magnetized head behind the knob holds the gas valve open. So obviously the head is not being magnetized. First make sure that the pilot is not plugged and the flame is large enough to heat the thermocouple. Also sometimes you may need to hold the knob for several minutes before the pilot will stay on. Also patio heaters have a safety feature that will cut the millivolt circuit if the heater falls over. It is possible that this safety device is tripped or defective causing the pilot to not stay lit. Also check for any loose wires on the millivolt system.
Dec 21, 2009 | Endless Summer UniFlame (GWU501E) Open...
Napoleon PTH10PSS Infra-Red Patio Heater
If you have a piezo ignition, then all you will hear is one click when you turn the knob. If I am guessing correctly, when you push in the knob and turn it, the gas flows to the pilot assembly, when you turn the knob far enough it will clilck and that sends the spark to the pilot assembly to light the pilot. Try turning the knob slowly before you get to the click, that will allow more gas to flow to the pilot. If this does not work, then you may have a blockage in the pilot.
Jun 29, 2009 | Napoleon PTH10PSS Infra-Red Patio Heater
Charmglow patio heater
Looks like the knob or the contacts are faulty.
Nov 07, 2008 | Williams 2509612 Ceramic Mid-Size Heater
Patio Heater pilot lights won't stay lit
crappy pilot flame (not properly heating the thermocouple), bad thermocouple, thermocouple loose where it screws into the pilot safety valve, bad safety valve magnet.
One or more of those is the problem.
Oh...there is also a saftey switch...in case it tips over. It will also cause the pilot to not stay lit (if the switch or wires that go to i are faulty)
May 30, 2008 | Coleman (5040B750) Patio Heater
Windchaser patio heater
You have to hold the button down for 30 seconds at least before turning the knob to ON. If you are doing this and it still goes out after you let up on the knob, then it needs a new flame sensor, or thermocouple. Same thing different names.
Feb 29, 2008 | Endless Summer 2009 Open Flame Patio...
Ace Hardware Living Accents Patio Heater Cover Logo
171 people viewed this question
Top Ace Hardware Pool & Spa Experts
Jay Finke
Jay Finke
john h
David Spradling
David Spradling
Are you an Ace Hardware Pool and Spa Expert? Answer questions, earn points and help others
