Question about Sewing Machines
My thread keeps breaking. I got this machine
My thread keeps breaking. I got this machine second hand where can I get a manual for it? I am a novice at sewing but it's something I always wanted to do so my mother gave me her machine but could not find the manual and I know nothing about it not even how to thread it.
  • 92 Answers
Thred breaking is one of the following: tention to tight, wrong thred, wrong needles - use jersey baal point 80/12 needles for all material and thred, bobbin tention too tight. wcbotha@yahoo.com
Posted on May 12, 2010
Hi...just bought myself a second hand Homestyles sewing machine. F08-702-H-01...How do i thread the machine....thanks. The thread breaks before I get to thread it
Change thread. It sounds like your thread may be dry-rotted. Otherwise, it could need some cleaning. Do you have a manual?
Nov 18, 2016 | Sewing Machines
Why the thread cracked with when i sticked with the machine
Thread breakage could occur for several reasons.
First, try a brand new needle.
Second, use only good quality thread--NOT old thread or bargain bin varieties.
Third, when threading the upper thread, be sure to ALWAYS RAISE the presser foot throughout the threading process.
Verify that the thread path is correct (consult the owner's manual). Incorrect threading will usually break the thread.
Check that the upper thread tension is set at the midway point between the high & low numbers.
Why Does My Top Thread Keep Breaking Sewing Machine
Sewing Machine Problem 1 Thread Breakage
Sewing Machine Thread Keeps Breaking
NMSU Checklist of Common Machine Troubles
Why Does My Thread Keep Breaking While Sew
Aug 27, 2016 | Brother ES2000 Computerized Sewing Machine
How do I thread my overlocker
If thread is breaking, it usually means it is threaded incorrectly--either you have missed a thread guide or have it looped somewhere it shouldn't be. The tension could also be too tight on that one thread.
RAISE the presser foot BEFORE threading!
Be sure you are threading each thread in the ORDER described in the owner's manual. Most machines are threaded in this order: 2nd thread from the right (upper looper), last thread on right (lower looper (this thread must cross over the top of the upper looper in the final step!!!), then the needles--but you must check your machine's manual for the correct order!
Confirm with your owner's manual that you are threading all the guides. If you miss one of the thread guides, your machine will most likely not operate.
Also, if you break a thread, it is strongly recommended that you remove ALL the threads and start over from the beginning. Sergers can be very finicky!
This video may help, although your machine may thread differently:
How to Thread Serger Overlock Machine
Oct 28, 2015 | Sewing Machines
While sewing the thread keeps busting
Hello Rachel, Too much needle tension can cause the thread to break. Old thread becomes weak and breaks easier than new thread. Wrap some of your thread around your fingers on both hands and try to pull the thread apart. If it breaks easily, try some new thread.
Apr 26, 2015 | Sewing Machines
Top thread keeps breaking, I've re-threaded to make sure it's right, wound and re-inserted a new bobbin, checked the needle to make sure it's not bent (as described in the manual) and put it back with flat...
Not sure if you noticed but if you thread a machine with the pressure foot down it will not thread correctly. There are two little things that sorta looks like symbols for the tension on most machines. (learned this when my viking 600e kept breaking thread and I put it in shop) If you thread the machine with the pressure foot down it closes the symbol things and the thread will break as you described. If you have completed that correctly check the spool of thread. You may have a burr on the thread spool that is catching the thread that too has happened to me.
Mar 30, 2017 | Brother LS2125i Sewing Machine
Hi. I'm really glad to hear that you want to learn to sew! You're right to try to find a manual for your machine first, because your sewing machine is the most important piece of equipment you have.
You didn't say what model your Euro-Pro machine is and that's pretty important in order to find the right manual. See if there's a name plate somewhere on the machine with the model and serial number information.
I did find a manual for a Euro-Pro model 1260 at Relics: http://pages.sewing-machine-manuals.com/173/InventoryPage/1424422/1.html. Check it out and see if the drawing looks like your machine and the description sounds like yours.
Sew4less (http://www.sew4less.com/index.php) has a lot more Euro-Pro manuals, but no drawings or pictures.
I also found Euro-Pro manuals at http://homeappliance.manualsonline.com/manuals/mfg/europro/europro_sewing_machine_product_list.html.
But this may be your best bet: http://www.euro-pro.com/europro/faqhelp.aspx They have an example of where to find the model number and then you can enter the model number to find the manual.
Since you're new to sewing but want to learn, here are a couple of websites that you might be useful:
http://www.sewing.org/
http://clothing-design.suite101.com/article.cfm/a_selection_of_simple_sewing_books_for_beginners
http://www.asg.org/ (American Sewing Guild)
http://www.sewing.com/index.html
http://sewing.patternreview.com/ (they have online classes!)
Have fun surfing--one will lead to another, I guarantee!
You can visit me at my sewing blog (www.robbiesews.blogspot.com), explore the links I have there and all my posts, and ask me anything about sewing.
Happy Sewing!
Robbie
Mar 16, 2010 | Euro-Pro Sewing Machines
Machine is jamming
You need to remove the bobbin from the "race" by following the instructions in the manual. Give it a good clean and remove any bits of fluff and thread. Remove the upper thread also andmake sure that the tension wheel is clear of any broken threads and is on the correct setting. It may have been threaded wrong. The hand wheel not turning sounds like the bobbin area is jammed also.
Jun 10, 2009 | Singer 8280 Mechanical Sewing Machine
Threading Memory Craft 8000
Hold the thread taut between your left hand and right hand. Pull it through #1(all these spots are numbered on your machine) and press down on the thread with your right index finger to guide the thread through #1. Keeping the thread taut, continue to pull the thread through the rest of the guides with your left hand until you reach the needle.
sewman7
Dec 21, 2008 | Sewing Machines
Cant find a manual or thread machine properly.
Submit a new question providing details on manufacturer and exact model, click here to submit a new query.
Nov 15, 2008 | Sewing Machines
Janome Travel Mate - Model 4612 - Need InstructionManual
JANOME MY STYLE 16S INSTRUCTION BOOK WANTED: I have just purchase this second hand sewing machine. Does anyone have an instruction manual to sell or copy? Will pay for expenses. Contact me first on frenchy31@optusnet.com.au. Thank you. Maureen
Sep 21, 2008 | Sewing Machines
Sewing Machines Logo
83 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
