Question about Sony KP-61V80 TV
Can someone please direct me to a free service manuals that's actually free.
Every time I start my 99' 61 tv the fuse blows and I'm going to try to fix it myself. I found a round pin size burn in one of the traces near the power source and tried to solder it but it didn't help. I need the manual so I can at least get an idea of what to look for. thanks
  • 129 Answers
Good day.
With regards to your problem, try to isolate the issue first. the fuse blows? this means that something is shorted in the power supply circuitry. Could be the regulator IC, diodes or capacitors.
You can likewise download the diagram you need through the links posted on fixYa.com
For further assistance, please post the result of your findings.
chris
Posted on Mar 28, 2008
97 blazer trans fuse shorted out truck won't start
In many instances one of the solenoids for the lockup converter or other wise will short out inside the transmission and since they are usually direct power you will get a surge back through the line and it can blow fuses. I have had them blow the fuse to the stereo which is direct wired to maintain memory for the stations and clock. Trace the lockup wire, disconnect it, replace all blown fuses, check for all locations and then try starting the motor. If it runs then you need to have someone service the trans and change the solenoid that is shorted. This will not be able to be done at a quick lube shop, it must be a transmission shop or automotive shop.
Sep 14, 2014 | 1997 Chevrolet Blazer
Polk sub DSW2000 fuse blows each time you switch it on.... How do i fix it or any circuit drawings or service help....Thanks for all replies
Sounds like your fuse is rated too low, try a heavier fuse or search Retrevo Manuals.com and you may find a manual.
Dec 16, 2013 | Polk Audio PSW10 Subwoofer
2011 Honda CBF125 keeps blowing 10 amp fuse
Hi, Anonymous before diagnosing your blown fuse issue, check the bottom of your seat, if it's metal and comes in close proximity to the positive battery post you need to take the necessary steps to ensure there is no contact (electrical tape, thick rubber insulation, hammer a dent in the seat bottom etc.) You are going to need a wiring diagram from your service manual, a test light, an ohmmeter and plenty of extra fuses.
If you turn on your ignition switch and immediately blow a fuse you have a hard/dead short and is usually easy to find. With a test light connected to the hot side of the blown fuse holder start stabbing the wire/s that leads away from the fuse holder and towards the ignition switch, you test light will illuminate validating the short. When the test light fails to illuminate you have passed the short and need to back up until the test light illuminates, then look in the immediate area for the short.
If you driving down the road for 30 minutes or 15 miles and blow a fuse you have soft/flying short and may take some time and patience to find.
If the main fuse/circuit breaker constantly blows/trips while riding you probably have a faulty battery terminal connection. Check battery terminals for damage or corrosion, check battery cables at "BOTH" ends for loose, corroded, or broken connectors, "INSIDE" and outside the cable harness, perform connector wiggle test and check cables with an ohmmeter if necessary. Any other fuses that constantly keep blowing while riding are usually caused by a loose or corroded ground wire in the circuit, which means you have to check, inspect, test each and everyone with an ohm meter set on a low ohm scale 100 ohms or less . Simply touch one lead to the ground source and the other lead to the battery negative terminal, a reading of zero indicates a clean solid ground. Any number reading or infinity indicates a poor ground and needs to be repaired. Poor or weak grounds require excessive additional amperage to complete the circuit which in turn blows the small amperage fuse.
For more information about your issue and valuable "FREE" downloads that you will need for viewing or printing please click on the blue links below. Good luck and have a wonderful day.
10 amp gauge fuse keeps blowing
Honda Motorcycles Fault Codes Motorcycle Manuals PDF http://www.sea-for-you.com/service/service-manual-cbf-125.pdf
http://www.partsfish.com/page/oem-parts-for-honda
Honda CB Owners Manuals
Nov 23, 2013 | 2011 Honda CBF125
Where is fuse for air conditioning in 1997 bmw 528i
Try manualslib.com ....
is quite outstanding... Recommend one of the MANY BMW forums...and 1002 pages of SERVICE mnnual
BMW 5251 Service Manual
For FREE Schematic Drawings and TSBs
(Technical Service Bulletins) go to
BBB Industries... REGISTRATION is REQUIRED
BBB Industries Premium Alternators Starters Power Steering Products
ALSO...
You can get PRETTY hefty prices buying AUTO-FUSES
ONE AT A TIME... i urge you to look at the handy fuse kits avaiilable on eBay or AMAZON (very reasonable)
KITS. ... (LIKE)
Amazon com Bussmann NO 44 ATC Blade Fuse Tester Puller Kit Automotive
BUT... Please do figure out which fuses you need before purchasing...
Amazon com Standard ATO Car Blade Fuse Assortment 100 Pieces 2 3 5 7 5 10...
Hope this helps...
Carnac the Magnificent
Dec 25, 2017 | BMW Cars & Trucks
I got a 2005 XT660X Motard style. My 10amp fuse, labelled EFI, keeps blowing when I hit the start button. Replaced the 'Rec Def' as someone else recommended and it ran good for a day. Now...
Hi, Carpejugulum before diagnosing your blown fuse issue check the bottom of your seat if it's metal and comes in close proximity to the positive battery post you need to take the necessary steps to ensure there is no contact (electrical tape, thick rubber insulation, hammer a dent in the seat bottom etc.) also you are going to need a wiring diagram from your service manual a test light, an ohmmeter and plenty of extra fuses. If you turn on your ignition switch and immediately blow a fuse you have a hard/dead short and is usually easy to find. With a test light connected to the hot side of the blown fuse holder start stabbing the wire/s that leads away from the fuse holder and towards the ignition switch, you test light will illuminate validating the short. When the test light fails to illuminate you have passed the short and need to back up until the test light illuminates, then look in the immediate area for the short.
If the main fuse/circuit breaker constantly blows/trips while riding you probably have a faulty battery terminal connection. Check battery terminals for damage or corrosion, check battery cables at "BOTH" ends for loose, corroded, or broken connectors, "INSIDE" and outside the cable harness, perform connector wiggle test and check cables with an ohmmeter if necessary. Any other fuses that constantly keep blowing while riding are usually caused by a loose or corroded ground wire in the circuit, which means you have to check, inspect, test each and everyone with and ohm meter set on a low ohm scale 100 ohms or less . Simply touch one lead to the ground source and the other lead to the battery negative terminal, a reading of zero indicates a clean solid ground. Any number reading or infinity indicates a poor ground and needs to be repaired. Poor or weak grounds require excessive additional amperage to complete the circuit which in turn blows the small amperage fuse.
For more information about your issue and valuable "FREE" downloads that you will need please click on the blue links below. Good luck and have a wonderful day.
keeps blowing fuses
Blown Ignition Fuse
YAMAHA XT660R Service Manual
OEM parts for Yamaha
Yamaha XT660R Owner Manual
Sep 15, 2011 | 2005 Yamaha XT 660 X
Samsung LN40A530P1F LCD TV keeps blowing main power fuse when i turn set on it blows right away i have replaced fuse many times. Also when back was off i noticed a arcing as fuse blows at a component just...
http://www.samsung.com/us/support/detail/supportPrdDetail.do?menu=SP01&prd_ia_cd=&prd_mdl_cd=&prd_mdl_name=LN40A530P1F
If a fuse blows like that there is a major problem, inside. I suspect that what your are seeing is the inrush thermistor, and they exhibit this under great load. I would explect that this fault maybe in the actual PSU. Due to the lack of service manual support, i would get a quote for repair from an authorised service center.
Jun 22, 2010 | Samsung LN40A530 40 in. LCD TV
1. after 10 minutes of the engine starting, the
Try this website for resolving car problems by downloading a FREE service manual for your vehicle. This is not an owners manual but a factory mechcanic's manual.
http://ezinearticles.com/?Find-the-Free-Auto-Repair-Manual-You-Need-Online&id=92717
May 01, 2010 | 1995 Oldsmobile Aurora
Blowing ignitor [cdi]
Hi, Gemmaj_p123 what is your ignition fuse doing, if your blowing CDI's then I would look for a short coming from the CDI on it's way to the coils, cracked or worn or chafed wiring for this scenario you will need your service/owners manual if you can't find the first and best tool you ever bought for your Kawasaki, despair not, for a mere zero $0 you can download another one.
Help fuse blows bike dies bad CDI
ignition fuse keeps blowing
Kawasaki Ninja ZX 6R Service Manual
OEM Parts for Kawasaki
Kawasaki Ninja ZX 6R Owner Manual
Apr 11, 2017 | 1999 kawasaki ZX-6R Ninja
Blown fuse
Most likely there was a power event (surge, brownout, ect) that caused the power supply to fail in the TV causing the fuse to blow. you will need to have someone come and look at the unit and give you an estimate. If you keep putting fuses in and blowing them you could actually be causing more damage.
Mar 10, 2008 | Televison & Video
Sony KP-61V80 TV Logo
73 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
