Question about Dell OptiPlex GX270 PC Desktop
Dell Optiplex GX270 Dual Channel DDR Feature
I have Dell Optiplex GX270 with 2 X 512Mb (400MHz) DDR1 RAMS. In the mobo spec it says that this mobo supports Dual Channel DDR-1. Where should i put stcks to avail this feature?
Socket1-3 or Socket1-2
nilesh
    Genius:
  • 3,587 Answers
1 and 3
Posted on Mar 28, 2008
Dell optiplex GX270 reconnect disk drive D:
if you have two partitions on your hard disk drive that means that D partition is dead! If you have two separeted hard disk drives C and D check the flat and power cables, check the jumpers on hard disks, switch the possitions of the jumpers on drive D to SLAVE position!
Oct 06, 2012 | Dell Optiplex GX270 Desktop Computer -...
There is no problem whatsoever, I just would like to have the disposal of a practical user's manual for desktop computer DELL GX270. The only documentation I was able to lay my hands on is a printed...
If I understand correctly, you are looking for the user manual for the GX270 line of optiplex just in case the need arises. Please see This site for the Dell issued manual in a nice web format.
May 16, 2011 | Dell Optiplex GX270 Desktop Computer -...
Need specifications for Intel PM-865G1 mobo
Specifications
CPU
• Supports Intel® P4 Northwood/Prescott/P4 Extreme Edition processors.(PCB v1.1 only)
• FSB 400(Northwood only)/533/800MHz
• Supports up 3.2GHz and higher speed
Memory Speed/CPU FSB Support Matrix
FSB\Memory clock DDR266 DDR333 DDR400 800 MHz YES YES* YES 533 MHz YES YES NO 400 MHz YES NO NO
• Intel® 865G Chipset
- Supports 800/533/400MHz Intel NetBurst micro-architecture bus.
- Integrated graphic controller.
- Supports PC2100/PC2700 /PC3200 memory.
- Supports AGP 8X/4X at 0.8V (AGP 3.0) or 4X at 1.5V (not support 3.3V) interface.
• Intel® ICH5 Chipset
- AC'97 2.3 interface
- 8 USB 2.0/1.1 ports
- 2 channel Ultra ATA/100 Bus Master IDE controller
- SMBus 2.0 support
- 2 serial ATA Host Controllers
- Integrated LAN controller
• Support 100(Northwood only)/133/200MHz
• Support 400(Northwood only)/533/800MHz Intel NetBurst micro-architecture bus.
• Supports two 64-bit wide DDR data channels.
• Available bandwidth up to 3.2GB/s(DDR 400) for single-channel
mode and 6.4GB/s(DDR 400) for dual-channel mode.
• Supports four unbuffered DIMM of 2.5 Volt DDR SDRAM.
• Supports up to 4GB memory size without ECC.
• One AGP slot supports 8x/4x at 0.8V (AGP 3.0) or 4x at 1.5V (3.3V is not supported).
• Three PCI 2.2 32-bit Master PCI Bus slots.
- Supports 3.3v/5v PCI bus Interface.
• One CNR slot
• Dual Ultra DMA 66/100 IDE controllers integrated in ICH5
- Supports PIO, Bus Master operation modes.
- Can connect up to four Ultra ATA drives.
• Serial ATA/150 controller integrated in ICH5
- Up to 150MB/sec transfer speeds.
- Can connect up to two Serial ATA drives.
• AC'97 link controller integrated in ICH5
• 6 channels software audio codec C-Media 9739A
- Compliance with AC97 v2.2 Spec.
- Meet PC2001 audio performance requirement.
- Can support SPDIF Out via 3-pin SPDIF bracket only.
• Intel 82562EZ
- Integrated 10/100 Ethernet MAC and PHY in one chip
- Supports 10Mb/s and 100Mb/s auto-negotiation operation
- Compliant with PCI v2.2, and LAN on Motherboard (LOM) standard
Apr 27, 2010 | Intel Motherboard
Gx270 dell During istall of OEM XP I get blue screen codes 24,8,&
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0cm 5.4pt 0cm 5.4pt; mso-para-margin:0cm; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} 41f927c.jpgd3990ed.jpgALL these systems suffered from defective capacitors caused by bad manufacturing at the component factory. I have put here a pic or two for you to see what defective caps look like. Call Dell and ask them. I some case a while back they were doing a free motherboard replacement. The problem causes a whole raft of errors to occur from blue screens to "thermal event error" and the only thing that fixes it is to have the motherboard replaced. Hope this helps you
Kind regards from London
Mark
Aug 25, 2009 | Dell Optiplex GX270 Intel Refurbished...
Replacing existing DDR RAM
Well this that you can use PC3200 DDR 1GB then those you mentioned above ... and let me tell you there is only bus speed difference between ..
Jun 23, 2009 | MSI 865P Neo (MS-6742-020) Motherboard
Ram issue with compaq presario 5000 G1 Series
as you can see from the information below there are different requirements for RAM to work stable in your system . Most importand are the RAM VOLTAGE , SPEED , and Configuration of chips. you will need to consult the manual for qualified RAM requirements. Some RAM will work but not very stable. make sure the voltage supplied by your system is enough for the RAM. If you are running DDR RAM in dual channel mode, the ram needs to be the same size also. DIMM modules for the HP computer must meet the following requirements
  • The number of pins on the DIMM must match the socket type.
  • DDR memory requires a 184-pin slot and 1.8 operating voltage.
  • DDR2 memory is not compatible with DDR1 memory and requires a 240-pin slot and 2.5 operating voltage.
  • Synchronous dynamic random access memory (SDRAM): Only use DDR type SDRAM memory if the computer came with DDR-SDRAM.
  • SO-DIMM modules for the HP computer must meet the following requirements
    • SO-DIMM memory requires a 200-pin slot.
    • DDR2 SO-DIMMs are not compatible with DDR1 DIMM and DDR2 DIMM memory modules.
    • With a computer running at a system bus of 533 MHz or 667 MHz, use a PC2-4200 (DDR2 DIMM 533) type.
    • The following requirements must be met for the DDR memory to function in dual channel mode:
      • Same density (256MB, 512MB, etc.)
      • Same DRAM chip technology (x8 or x16)
      • All either single-sided or dual-sided
      • Matched in both Channel A and Channel B memory channels
Oct 22, 2008 | Compaq Presario 5000 PC Desktop
Memory Upgrade
ask for ddr1 ram of 1 gb.also take your old ram which is at present in your pc to match the locks with the new ram.
it will cost u near to 50$.
thanks.
Sep 18, 2008 | Intel D101GGC Motherboard
I can't find the Timing for Crucial PC3200 DDR 400mhz
Sorry to run dual channel memory both stick MUST be the same
Aug 19, 2008 | Intel Motherboard
Memory
Hello.
Of course it would be a great improvement, but unfortunatelly you can't install DDR2 in DDR slots, they are different and even if you could make it fit they have a big difference in architecture.
i'm sorry, it wont work.
Regards
Jul 13, 2008 | Gateway GM5084 PC Desktop
Memory
Hi
OptiPlex GX270 can be small form-factor, small desktop or small mini-tower. The DIMM slots and therefore maximum memroy capacity depends on the form factor. Double check our OptiPlex GX270 and find memory info below.
Memory Type
333MHz (PC2700) or 400MHz (PC3200) DDR SDRAM
Memory connectors/DIMM Slots
small form-factor: 2
small desktop: 4
small mini-tower: 4
Memory capacities Supported
128MB, 256MB, 512MB, or 1GB non-ECC
Minimum memory
128 MB
Maximum memory
small form-factor: 2 GB
small desktop: 4 GB
small mini-tower: 4 GB
Mike
Apr 13, 2008 | Dell OptiPlex GX270 PC Desktop
Dell OptiPlex GX270 PC Desktop Logo
457 people viewed this question
Alun Cox
