Question about Sony VPL-CS7 Multimedia Projector
SET UP GONE ON NEXT USE
For no known reason the setup is now gone when we get ready to do another presentation. Now we have to go through the menu and reset the brightness, etc, everytime we do another presentation. Have never had this problem before, we use the same computer, connection, screen, location, etc.
  • pro24 Apr 03, 2008
    Good thought and I should have been clearer as we use same computer, same everything but it only happened in the last few weeks. We set it back to normal with the menu and then next time we use the setting is gone. Thought maybe a lithium battery is in it but don't see one in the owners book.
  • 563 Answers
Hi there
Do you at any stage plug in other PC's to this unit - because that sometimes throws off the settings ?
Posted on Apr 02, 2008
Why is the oven bell not ringing when it reaches the set temperature.
If the temperature reached at it operating temperature and oven display doesn't showing how much time left for ready screen then most probably its IO board gone.
I have seen many cases like this, and replacing IO Board fixed the problem.
Please rate my work
Thanks
Sagar
Sep 19, 2014 | TurboChef TORNADO Electric Oven
How do we get the picture back full screen when it will not show the menu because it is only showing the lower half of the screen for some reason
HELLO.
Sounds like one of the buffer boards has gone.
BEFORE YOU TAKE MY ADVICE PLEASE BE AWARE VERY HIGH VOLTAGE INSIDE, IN SOME SETS 2,000 VOLTS DC.
you will need to turn set off for 2 hours before any work is carried out.
as you look at the back on the bottom are 2 or 3 sets of long thin boards, one of them is gone.
either change one at a time or the whole lot.
hope this helps.
Panasonic TH 46PZ80B Half picture with distortion Diagnosis and Repair
Jun 21, 2014 | Maxent MX-42VM10 42 in. HD-Ready Plasma...
Mitsubishi WS55315 rear-projection has gone dark
Yes, they have other than convergence circuit problems----very few issues or troubles.
You should test the shops by asking if they have the 4 digit code number for this model for the OPTION MENU---set has 3 hidden menus and OPTION menu will allow a hard reset of entire set---the other two menus are adjustment and convergence menus.
If some shop has no idea what the option menu is----pass them.
Mar 24, 2012 | Mitsubishi WS-65315 65" Rear Projection...
During post I get the message " Alert! failed to detect one or more drives" How do I turn this alert OFF?
Turn your computer off.
Turn your computer on.
When you see: press <blah> to enter BIOS SETUP,
press the <blah> key.
Use the arrow-keys to navigate through the BIOS SETUP menu
to the "DISK DRIVES" (or something like that) item, and press ENTER to select that item.
You probably have one disk-drive "manually" defined that either:
* no longer physically is present or connected,
* no longer is responding to queries
Set that device to 'AUTO' or 'NONE'.
Save/Exit from BIOS SETUP, and restart your computer.
The message should be gone.
Dec 28, 2010 | Computers & Internet
Truns off by self
Check sleep timers make sure you have non set in the menu or setup if not the timer inside is gone south on you and will need repair.
Apr 23, 2009 | Dell W2606C 26 in. HD-Ready LCD Television
No signal
From the menu select setup,
 then select tuning band, make sure that is set to AIR not CABLE, next select AUTO CHANNEL SEARCH. If any signals are present it should find them. Let me know what you find, I am also an expert in OTA over the air tv reception. Please rate this solution. lone99star
Jan 12, 2009 | Vizio L6 20.1 in. HD-Ready LCD Television
Divergence not working on RCA HDTV monitor 52" D52W26
sound like the common fl231 fuse problem. consult the fl231 problem article under the tips and tricks section. this is probaly the simplest most inpensive repair on this set
Jan 10, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
Convergence problem
If the convergence is out on that set you most likely do not need to make an adjustment the circuit will need to be repaired. There is a stk on the convergence amp board that needs to be replaced. A good tv shop will run you somewhere between $300-$500 to do the repair
Oct 28, 2008 | RCA P56923BL 56" Rear Projection...
Convergence
by the convergence menu i would assume you mean in the customer setup menu. although i have seen this at the shop on newer itc222 i guess it can happen with older sets...is the convergence gone...is it red green and blue.. if not it might be cut off in the service alignment menu...if that is true. how did it get cut off. has the set been worked on?
Feb 09, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
Sony VPL-CS7 Multimedia Projector Logo
Top Sony Office Equipment & Supplies Experts
shaun taylor
Jaime Hernandez
Are you a Sony Office Equipment and Supply Expert? Answer questions, earn points and help others
