Question about Dell 5100cn Laser Printer
Developer drive assembly
The printer doesnte print in color just black. Could it be that the developer drive assembly needs to be replaced
That's what you need a developer drive assembly, I've replaced several of these with exact issues. After replacing the part printer prints color.
Posted on Jun 05, 2010
Hi, i have problem with my hp color laserjet 5550 printer.it saiys printer error 59.c0
59.XY A printer motor error has occurred.
(X=C=developing disengaging motor rotation error)
(Y=0=no color/black)
Developing disengaging motor error
1. Reconnect the connectors J16 for the developing disengaging motor and J1100 for the DC controller PCB.
2. Replace the developing disengaging drive assembly.
3. Replace the DC controller PCB. Calibrate the printer after replacing the DC controller.
Jul 29, 2011 | Office Equipment & Supplies
I want to know what the problem 59.CO message on my printer Laserjet colour 5550 and how to get it solved
59.XY PRINTER ERROR
(C)= developing disengaging motor rotation error / (0)= no color/black
Jul 13, 2011 | HP LaserJet 5550 Printer
Pages come out pink only when printing in colore
The magenta developer is bad.
The developer drive on this printer rotates in both a clockwise and a counter clockwise direction to turn the developers.
When printing black, ( i cant remember which direction it turns, ) only the black developer turns.
When printing color, the developer drive turns the opposite direction, engaging ALL 4 developers.
( the developers are the multi colored bars you see when you remove the image drum unit.)
This is why you do not get the pink output when printing only black.
your choices are to set the printer to only print black and white. ( you can do this in the printer properties for your print driver). or you will need to replace the magenta developer.
Feb 07, 2011 | Dell 5100cn Laser Printer
The copies are dirty, with black long tracks!
I would suggest either a fuser problem, If all Colors affected, or the Black Toner Cartridge. The Below chart may help isolate which component is malfunctioning. Repetitive image defects Measurement Component 24.7 mm (0.97 inch) Developer sleeve (Print Cartridge) 26.7 mm (1.05 inches) Charge roller (Print Cartridge) 32.9 mm (1.3 inches) RS roller 37.7 mm (1.48 inches) Transfer roller (ETB) 54.5 mm (2.15 inches) ETB rollers (ETB) 56.6 mm (2.22 inches) Fuser sleeve (Fusing Assembly) 62.8 mm (2.47 inches) Pressure roller (Fusing Assembly) 75.4 mm (2.97 inches) OPC (Print Cartridge)
Jan 13, 2011 | HP Color LaserJet 2600n Printer
Colours are faded despite all toners at 25% or
If there is black "dust" all over the developer (behind the image drum assembly ) you need to replace the developer; that is uncoated toner prevenitng transference of colored toner.
Jul 30, 2010 | Dell 5110cn Laser Printer
Canon ir 1600 my copier print copy image is very poor
iR1600 are special machine that needs a little bit more care.
First, clean the laser unit and optics ( beneath copy glass too ). Then use some polisher and polish the developing cylinder and clean/replace developer cylinder blade.
Use GENUINE CANON DRUM UNIT and GENUINE TONER.
Jul 02, 2010 | Canon Office Equipment & Supplies
Printing noises - no ink transferring
Sounds like you may need to replace the developer drive assembly. This is the motor and gear assy that drive the color developers. it is located on the right side middle, 3 screws hold it in place. be careful when replacing to not over tightened screws.
Apr 09, 2009 | Dell 5100cn Laser Printer
Color Faded
This sounds like a typical Developer Drive failure. The Developer Drive for color is different that the black developer drive. This is why black can print fine, but colors are faint or non existant. see below,a recent bullitin about this exact issue from Dell. ( the ROS, is the printhead, and is located behind the 4 developers.
5100cn Printer
Print Quality Issue
1. Problem: - Color images are extremely faint or not produced, but black images are produced without any problem.
Resolution: - Replace Developer drive assembly (H6702) and clean ROS Window/Glass.
If you chose to persue this repair, you can probably find a replacement developer drive by doing either a google search for the part number listed ( H6702 ) or an ebay search for the same. We can also provide you with removal and replacement instructions.
Good Luck
Oct 19, 2008 | Dell 5100cn Laser Printer
59 C0 error on hp color laserjet 5550
59.C0error on hp color laserjet 5550 dtn
can you please suggest a solution for the above error on my printer urgenty
Apr 10, 2008 | Office Equipment & Supplies
Dell 5100cn Laser Printer Logo
364 people viewed this question
Top Dell Office Equipment & Supplies Experts
jasbo
jasbo
Electro Med Services...
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
