Question about Canon PowerShot S1 IS Digital Camera
Help No image in the viewfinder or on the lcd screen when in shooting mode. Have amber light rather than green. In playback mode images appear on lcd screen. Was working fine the last time I used it and have changed the batteries to newly charged. Have also reset to default settings.
  • Shogunner Mar 30, 2008
    Thanks t00nz! I called the tech support # for Canon and that is exactly what they said, free fix and free ship both ways.
  • Canon Master
  • 4,738 Answers
This sounds like it might be a defective CCD imager. If so, Canon should fix this for you for free, including free shipping both ways. This is regardless of your camera's warranty status. Please check the following two links for more info:
http://camerarepair.blogspot.com/2007/11/canon-digital-cameras-showing-black.html
http://www.usa.canon.com/consumer/controller?act=PgComSmModDisplayAct&fcategoryid=225&modelid=13390&keycode=2112&id=29819
Applicable cameras include:
A40, A60, A70, A75, A80, A85, A95, A300, A310, S1 IS, S60, S200, S230, S330, S400, S410, S500, SD100, SD110, IXUS V2/300/400/430/500, IXY Digital 200a/300a/400/450/500
Posted on Mar 29, 2008
  • CameraR
    CameraR Mar 30, 2008
    Now don't get too excited, but if you read the comments in the first link, you'll notice that lately S1 IS owners have been receiving S5 IS back in return. This is due to the absence of needed parts to repair the S1 IS. At the same time, don't be disappointed either if the parts shipment finally came in and you only receive your fixed S1 IS. After all they did repair it for free :-)
No image is captured by the screen itself (LCD screen works but completely dark).
Did you try pressing the display button several times? in both viewing mode and record mode? Cycle through all display modes, s you get used to the button, so it does not trow you off when it happens again.
Feb 16, 2015 | Canon Cameras
No image on LCD screen
It sounds like you're receiving partial information on the LCD screen and that the image sensor isn't sending information to the screen.
If you know the sensor is working by recording some video on an SD card and being able to view the recorded video on your PC, then there is a disconnect between the LCD and the image sensor.
If you are not recording video to your SD card and only get black images or no files, the image sensor is damaged.
If you are recording video, but no image appears on your LCD for internal viewing/playback, you can try a firmware update if one is available from www.insigniaproducts.com, but this is a discontinued item so there's not much available for support.
Hope this helps!
Apr 25, 2010 | Insignia NS-DCC5HB09 High Definition Flash...
S1IS canon camera
Apparently the vendor-supplied CCD image sensor used in this Canon digital camera may cause the following malfunction: When the product is used in recording or playback mode, the LCD screen and/or electronic viewfinder may exhibit either a distorted image or no image at all.
To determine if the CCD (image sensor) is working properly, follow these steps:
1. Insert a memory card with known good images on it into the camera.
2. Power the camera on to the Playback mode.
3. Press the DISPLAY (DISP) button to enable the LCD panel, and observe
the LCD.
a. If the images are displayed properly, please proceed to step
four.
b. If the images are not displayed, or a "NO IMAGES" message
appears, please ensure that the memory card contains known good images.
c. If the card contains known good images, and the issue persists
with a second memory card, the camera will require service.
4. Switch the camera to the Camera mode. You may use any shooting mode
(i.e. Auto, Manual).
5. Press the DISPLAY (DISP) button to enable the LCD panel.
6. Point the camera at a well-lit scene and observe the LCD and/or
viewfinder. If the scene the camera is pointed at appears on the LCD
and/or viewfinder, the CCD is operating properly. If the LCD and/or
viewfinder remain black, the camera requires service.
Effective immediately, and regardless of warranty status, Canon will
repair, free of charge, products exhibiting the above-mentioned
malfunction if the malfunction is caused by the CCD image sensor. Canon will also cover the cost of shipping and handling in connection with this repair.
Regards.
Dec 01, 2009 | Canon PowerShot S1 IS Digital Camera
LCD has gone blank
Hi this is tech crazy
Based on the information you have provided, it appears that you may have
encountered this issue. To determine if the CCD (image sensor) is
working properly, please follow these steps:
the LCD.
four.
Hope this solution helps you a lot
Please rate me on the above said solution
Feb 04, 2009 | Sony Handycam DCR-HC21 Mini DV Digital...
NO PICTURE ON LCD SCREEN OR VIEWFINDER
model # is required for me to help you.
Sep 09, 2007 | Canon DC10 DVD Camcorder
Lcd screen does not display viewfinder image
That is normal. Didital SLRs are different in this respect from digital compacts .
Sep 02, 2007 | Canon EOS 400D / Rebel XTi Digital Camera...
Trouble with lcd screen
Have you tried it with another card? might help to narrow it down. Post back
Jun 09, 2006 | Fuji FinePix F401 Digital Camera
LCD Monitor on ,and the Electronic Viewfinder turned off
If you turn on the back LCD, the electronic viewfinder will remain on while in a shooting mode. There is no setting on the camera to use only the back LCD monitor while shooting. If you playback images in the Play mode, only the LCD monitor will turn on. However, if you press the Monitor button while in the Play mode, than the back LCD monitor will turn off. The image will display only in the viewfinder LCD.
Sep 04, 2005 | Olympus Camedia C-730 Digital Camera
LCD monitor and electronic viewfinder
Sep 04, 2005 | Olympus Camedia C-725 Digital Camera
LCD Monitor on and the electronic viewfinder
Sep 04, 2005 | Olympus Camedia C-720 Ultra Zoom Digital...
Canon PowerShot S1 IS Digital Camera Logo
88 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
