Question about Planet Audio VX1502 Car Audio Amplifier
Planet audio amplifier
The gold cover off the tip of one of the rca cables is stuck in the jack on the amplifier
  • 631 Answers
There are several options.
Take the jack out of the board, disassemble it and remove the tip of the plug.
If the tip of the plug is in the top slot, pull the sleeve off of the jack and remove the tip of the plug. When you press the sleeve back into the jack, bend the tab inside the jack up so it will remain firmly in place.
Use the output jacks as the inputs. It's very likely that they're in parallel. The only difference being a low value resistor (will have no effect on the signal) in series with the output jack.
Posted on Mar 29, 2008
SOURCE:
What can be connected to te audio output jacks on the back of this set?
You didn't include make and model TV; so only generalized answers are possible.
Typical RCA phono jacks like those shown in the blue box of the stereo amplifier below:
25998201-ac5bgneb45fvu53muoueauti-3-0.jpg will accept cables to connect to other audio devices. The audio RCA jacks are color coded RED (right) and WHITE (left) for low level stereo signals. Some have YELLOW jacks for Standard Definition video, ORANGE jacks for AC3 Digital audio and newer amps have HDMI jacks.
Connect the TV's audio OUTPUT jacks and a stereo pair of unused audio INPUT jacks on the amplifier with cables that have ends that match each. Turn on the stereo & TV and select the input on the amplifier that matches the stereo pair of inputs you used to connect to the TV. Adjust the volume to hear the audio over your stereo system's speakers.
Use the HDMI or AC3 sources for superior audio - including 5.1 (or better) Dobly Digital when possible. Otherwise, a standard 2 channel stereo program will be heard.
I hope this helps & good luck!
Dec 08, 2015 | Televison & Video
Sennheiser hookup to noncompatable Samsung DLP TV
Ok if I understand what you are saying. You are going from your TVs audio jack into an amplifier TEAC AG-V8050 and then into the Sennheiser T1250 unit? This is done to amplify the sound so your wife can hear the TV via Infared into headphones I am guessing. The connections would have to be as follows. TV RCA jack (Installed by someone to TV audio Output section, most likely the speaker) to the Amplifier TEAC AG-V8050 via RCA cable then from the Amplifier via RCA cable to the Sennheiser TI 250 IR Transmitter. The transmitter then takes the audio input and turns it into a digital signal which is transmitted via IR to headphones which your wife is using. First of all the amp TEAC AG-V8050 is not needed. what happend here is the person doing the installation took sound off of a preamp to avoid having to deal with the TV volume control. This works but it makes matters harder. So here is how you troubleshoot this problem: 1) Disconnect the amplifier and plug the RCA jack of the TV into the RCA jack of a set of amplified Mono headphones. (This is to determine if sound is coming from the TV) If not the problem is in the TV audio section and you will need to take it to a TV repair shop. 2) If audio is coming through the headset the trouble is in the amp or the sennhiser unit. To test the sennhiser unit: plug the sennhiser into the audio out of a VCR and listen in the headphones for sound. If you have sound, the sennheiser is good and the problem may be in the amplifier, but if you do not have sound the the sennheiser is bad. 3)Connect the audio out of the VCR into the audio in of the amplifier and plug the output of the amplifier into the sennheiser which tested good with just the VCR alone. If no sound is present then the amp is your culprit. Once you find out which component is the problem, I would suggest finding a rapair shop here on FitYa to repair your unit or having an electronics technician come to you to fix the bad component. This should help, Thank you, Shuttle83
Sep 07, 2007 | Televison & Video
I want to connect an iPod to my Marantz SR 5600, what type of cord do I need?
You need a jack-2cinch (differen name is jack to 2 RCA) cable. Jack goes to your iPod's phones output, cinch/RCA to amplifier (connect it to CD or DVD analog section at the back). While playing set volume to 50% to avoid distorted sound. This way you can connect any MP3 player to your amplifier.
May 08, 2011 | Marantz Audio Players & Recorders
Amp comes on but music plays for 30 seconds then crazy feed back noise.one of rca jacks feels loose are they replaceable
Yes they are can be replaced. If you meant the RCA female sockets on the amp then it needs that the amp is taken out and the RCA terminals soldered -- it can be poor joints. If not you can de-solder and change with a new one.
If this is the RCA main socket then the wire can be **** off and a new RCA jack of good quality can be soldered, taking care to keep the shield and main line with a good solder point.
Feb 05, 2011 | Phoenix Gold Tantrum 600.4 Car Audio...
I need to set up my TV (without HDMI), amplifier, dvd recorder and Skybox so that I get the best sound - so using the amplifer.I really need a diagramatic picture
No diagram needed: just connect the video RCA connector (yellow) from the player and the box to the tv using 2 separate cable plugged in separate AV entries, and the audio RCA connectors (white and red)  using 2 separate audio cables to 2 RCA joiners like http://www.amazon.co.uk/Euronetwork-RCA-phono-adaptor-Gold/dp/B000ENC20E
and plug those in the audio connectors of the amplifiers - keep the same color all the way.
Jul 24, 2010 | Yamaha Televison & Video
What size RCA jacks do i need for my Audiobahn A8005DN amp?
The standard Size will work great!! Preferably gold plated RCA cables sound the best.
Jun 04, 2010 | AudioBahn A6005DN Car Audio Amplifier
Hum sound when plug in. if i touch the input jack the hum sound disapear.
The best way to test your sound problem is to buy another pair of patch cables/RCA cables and try those, most likely you have a ground loop in the RCA cables, basically you are creating a ground when you touch it.
Dec 04, 2009 | Fishman Audio Amp Temp - Green Amplifier...
No rcas inputs on amp
Hello sting_ya_sco,
The ACAP501Q has 2 sets of of RCA jacks. The first set is input and 2nd preamp outputs. The jacks are factory covered with plastic protectors. Just pull the protectors off and plug in the cables.
Hope this helps.
Jul 25, 2009 | AudioBahn A2002T Car Audio Amplifier
Broken RCA / phono jack - where to find new part?
You can buy Panel mount RCA (Phono) jacks at Radioshack, I think a 4 pack is less than 5 bucks, That should take care of your problem.
Good Luck,
Stay Classy
B.
Mar 03, 2009 | Jl Audio 1000/1 Car Audio Amplifier
RCA INPUT JACKS
did it work well before?is it new? try moving the rca's and se if you hear any thing?
Jun 30, 2007 | MA Audio HK802SX Car Audio Amplifier
Planet Audio VX1502 Car Audio Amplifier Logo
71 people viewed this question
Top Planet Audio Car Audio & Video Experts
Robert Rankin
Miguel Luiz Martins
Are you a Planet Audio Car Audio and Video Expert? Answer questions, earn points and help others
