Question about KitchenAid KGST307 Gas Kitchen Range
How to i relace the glass window on the oven door
  • KitchenAid Master
  • 43,501 Answers
Most of the time the replacement is really not that hard...here is a tip that I wrote about that...
Range/Stove/ Oven Door Glass Replacement
http://www.fixya.com/support/r4391163-range_stove_oven_door_glass_replacement
The very bottom link on this tip will help you with getting the part online...
heatman101
Posted on May 11, 2010
How can oven door glass be cleaned?
The window is comprised of two pieces of tempered glass with a metal band seal around the outside. Because the metal and the glass have different rates of heat expansion, material expelled by baking items finds its way past the seal and in between the two pieces of glass. As a practical matter, it is better to live with the dirty window than to risk destroying the oven door to remove and clean it. Besides, if you were able to remove the window assembly how would you remove the metal seal, separate and clean both pieces of glass, and reassemble?
Apr 05, 2016 | Ovens
Ariston oven window pane out
Take a look at http://ovendoorglue.co.uk/fix-oven-door-glass/ whish should help explain how to remove the oven door, take off the fascia and glue the inner glass.
Oct 28, 2012 | Ovens
On my frigidaire gallery series oven, how do you clean the glass of the oven door window (between the inside and outside)?
Below are instructions on how to take your oven door apart to remove any stains that may be caught down in the door vents.
Tools needed: good Phillips head screwdriver or small quad bit driver.
A. Open Door remove 2 screws and washers on door lining at door hinge area.
B. With door in broil stop position lift door assembly off hinges.
C. Lay door on table, position so that handle hangs freely over edge of table
D. Remove 2 screws and washers that secure handle to lining assembly.
E. Remove 8 screws that attach textured steel door wrapper trim to lining assembly 3 at top, 3 at bottom, 1 on each side
F. Lift door lining up and out of wrapper trim assembly.
G. Lay lining assembly on table with wool shield/inner part of lining facing up.
H. Remove 2 glass clamps via 2 screws per clamp. These clamps attach innermost clear glass to wool shield.
I. Lift out center clear glass from wool shield, this glass just lays onto the wool shield and is held in place by the glass/ clamps in item H.
J. Clean each glass with appropriate cleaner, Windex, bon ami, fantastic, etc
K. One glass that remains in door lining assembly can at this time be cleaned without further disassembly the lining assembly.
L. Reassemble in reverse order.
Aug 16, 2012 | Frigidaire 30" Self-Cleaning Freestanding...
Broken glass on oven door how to replace it
Here is a tip that I wrote about the oven door glass replacement...
It is not that hard...
heatman101
Feb 04, 2011 | Maytag MGR5775QD Gas Kitchen Range
Cracked inner oven glass window
heatman101
Jan 16, 2011 | KitchenAid Ovens
The glass outer glass on my oven window broke can it be repaired? It's a Thermador Model# CT227NPRS Serial# 98020093
heatman101
Jan 05, 2011 | Ovens
Describe your dacor rsd30 new oven door Problem - the glass is broken in the window
heatman101
Nov 26, 2010 | Dacor Preference RSD30 Gas Kitchen Range
NEFF microwave
Normally you have to separate the door panels (as shown in the attached photo) and then you'll see the previously hidden screws you need to remove.
Or you can watch a YouTube video (not a video I made) here that demonstrates how it's done.
We're happy to help and we appreciate your thoughtful rating of our answer.
Jul 03, 2008 | Neff Microwave Ovens
Dirty oven window
Try to remove the door. For the Kitchenaid, thereis a hinge on each side with a latch that flips up. Once the door is removed, remove all screws and you should be able to get at glass. Be very careful, the Kitchenaid had four panes of glass.
Jan 08, 2008 | Whirlpool GBD307PRS Stainless Steel...
Oven Door Inner Glass Replacement
can you gals get me the complete model # off the stove and i will look up the parts diagram & exploded view.
Nov 20, 2007 | KitchenAid KGST307 Gas Kitchen Range
KitchenAid KGST307 Gas Kitchen Range Logo
198 people viewed this question
Top KitchenAid Kitchen Ranges Experts
Colin Stickland
Colin Stickland
Dan Webster
Dan Webster
Are you a KitchenAid Kitchen Range Expert? Answer questions, earn points and help others
