Question about Nokia 6233 Cellular Phone
Changing front housing cover of Samsung U600
Trying to replace the front housing myself. I was sent a prying tool. Not sure what to do. Have you had any luck?
  • roland manders Jun 03, 2008
    i have a nokia 6233, and my power adapter has snapped off in the phone.i need to know how to dismantle the phone so i can remove the offending piece of the adapter.
    President:
  • 1,017 Answers
Go to this website to view/download a PDF of the service manual.
http://www.formymobile.co.uk/Dismantle/6233servicemanual.pdf
Posted on Mar 29, 2008
Replacing cracked screen
Insert your plastic pry tool into the seam in the side of your touch and run it along the length of the device to release the back panel from the front.
If your replacement screen did not come with a plastic pry tool, then a small flat-head screwdriver will also work.
Remove the square battery from the motherboard in the front housing by running the pry tool along the sides of it and gently pulling up.
Remove the small piece of black tape from the bottom of the front housing to expose three screws.
Remove the three screws using your small Phillips-head screwdriver. Remove the small screw near the top of the battery connector ribbon as well.
Remove the metal cover from the bottom of the front housing with the plastic pry tool.
This will expose the ribbon that connects the screen to the front housing and motherboard.
Flip the screen-connector ribbon up and gently pop it out. Then remove the two screws at the top of the front housing and disconnect the one other screen-connector ribbon.
This will release a thin metal board at the top of the housing that guards the screen. Pull the metal board out carefully.
Remove the 16 small screws from the side of the screen.
Once the screws are removed, the LCD screen will be free of the housing.
Gently remove the screen and replace it with the new one.
Replace the screws and reassemble the iPod touch the same way you took it apart.
video http://www.bing.com/videos/search?q=how+to+replace+an+ipod+4g+screen&view=detail&mid=3843F00F64220E3352823843F00F64220E335282&first=0&qpvt=how+to+replace+an+ipod+4g+screen
Nov 05, 2013 | Apple iPod touch
Having problems to separate the front axle from the tranny on dodge grand caravan se 2000
The axle shaft that goes into the transmission has a groove near its end with a circlip-a loose ring-in the groove. The circlip also sits in a groove inside the case. This is to keep the axle from trying to slip out the transaxle.
To get the axle out easily, shops use a fork tool around the inner CV housing, on a slide hammer-pops them out easy. A similar method is to use a pry bar or large screwdriver. Slip it in between the CV housing and the transaxle case-and give it a sharp push or shove- it will usually pop the axle out of the groove. Then the axle comes right out. Only thing you have to be careful of is not let the pry bar rest on the axle seal around the shaft. That may destroy the seal. Also be careful not to let the pry bar break the tranny case. I've done this on many cars without damage, but you could always rent the slide hammer, probably the forked tool also.
Some transaxles have a stub shaft out of the transmission, and the axle's inner CV housing has a female end that slides over the stub shaft. This set up has a roll pin through the CV housing and the stub shaft, securing axle to stub shaft. On this kind you drive out the roll pin with a punch. I'm pretty sure your caravan has the axle going into the trans. case, with the circlip on the shaft. They just get popped out. When installing, you can hear the circlip snap when it fits into the groove inside the case.
Hope this is clear enough for you to understand, kinda rushed right now. Good luckl.
Sep 23, 2013 | Separate type GPS radar detector machine...
IPod touch-shattered screen, thou can still be used.can u replace the front screen?
yes it is but you will need some certain tools
video
hope this helps
http://www.ebay.com.au/itm/New-Touch-Screen-Digitizer-Glass-Replacement-iPod-Touch-4th-4-4G-Gen-White-/330783433649?pt=LH_DefaultDomain_0&hash=item4d043aa3b1
Au $11.54 + postage Au $2.95 worldwide
im not sure if this is the right one you need
you could get this on Ebay if you dont have an account you will need to create one
https://scgi.ebay.com/ws/eBayISAPI.dll?RegisterEnterInfo
Add Email adress
Add Bank Acc
Add Credit Card
also add your postal adress
also add a paypal account
when you get to the paypal login page at the bottom you will see new to paypal sign up tab
paypal to create an account
paypal registration password ,bank card /credit card,phone numbers home/mobile ,email adress and a postal adress
be very specific when you type in the search
always ask questions? before you make a purchase and keep the email/s for security reasons if the item arrives and its not as described
you will even see the pictures of your item so you cant make a mistake and get them home delivered
hope this helps
Oct 10, 2012 | Audio Players & Recorders
Is there a c clip in the front driver side holding the half shaft in on a 05 ram 2500 diesel. Trying to replace universal!
There is a spring-type C-clip on the end of the CV housing spline shaft. Disengage the CV joint from the axle housing by using a pry bar between the CV joint and the axle housing. It can be pretty tough to get it to let go. I have found it helpful at times to place the end of a pry bar on the back of the CV housing (as good as I can) and smack it with a BIG hammer. Putting it back in is not nearly as hard.
Jul 09, 2011 | 2005 Dodge Ram 2500 Truck
How to repair front crankshaft seal leaks oil
Need to get at the crankshaft seal, usually by removing the crankshaft pulley and using a seal remover to take out the old seal, then put a new seal in.
Here are some instructions on how to do the 'rear' seal:
Rear Main Seal Removal & Installation 2.4L, 3.3L & 3.8L Engines To Remove:
  1. Remove the transaxle and flexplate. CAUTION
    Make sure not to damage the crankshaft sealing surface when removing the oil seal.
  2. Insert a flat-bladed pry tool or equivalent through the dust lip at an angle.
  3. Carefully pry the oil seal out of the engine. Pry against the chamfered edge of the crankshaft, do not damage the sealing surface of the crankshaft or an oil leak may occur.
To Install:
CAUTION
Smooth any burr or rough edge on the crankshaft with 400 grit sandpaper to prevent seal damage during installation.
NOTE: When installing seal, no lube on seal is needed.
  1. Place special tool 6926-1 seal guide or equivalent on crankshaft.
  2. Place the seal on the guide. Make sure the seal lip is facing the crankshaft and the guide tool remains on the crankshaft. Rear crankshaft seal installation (2.4L engine shown, 3.3L & 3.8L engines similar) chry-03-24-827.gif
    CAUTION
    Do not drive the seal into the block past flush. An oil leak may occur.
  3. Drive the seal into the block using a seal driver or special tool 6926-2 and handle C-4171 until the tool bottoms out against the block and the seal is flush.
  4. Install the flexplate and transaxle.
3.0L Engine To Remove:
  2. Remove the oil seal with housing from the rear of the engine block.
  3. Remove the oil seal from the housing.
To Install:
  1. Clean the sealing surfaces on the seal housing and engine block.
  2. Use a commercial seal installer to install the seal in the seal housing.
  3. Apply a light film of motor oil to the seal lip.
  4. Apply silicone sealant to the oil seal housing sealing surface and install the housing with seal on the engine block. Tighten all bolts to 104 in. lbs. (12 Nm).
  5. Install the flexplate and transmission.
Dec 31, 2010 | 1997 Plymouth Voyager
How do you replace the transmission seal?
YOU HAVE TO REMOVE THE FRONT DRIVE AXLES.YOU NEED TO BUY THE SEAL REMOVING TOOL PRY SEAL OUT TRANSAXLE AXLE HOUSING. GO TO ANY AUTO PARTS STORES THEY WILL HAVE ONE.YOU CAN USE A LARGE SOCKET DRIVE TO DRIVE IN THE NEW SEALS BE SURE TO LUBRICATE SEALS WITH TRANSMISSION FLUID.BEST TO BUY REPAIR TO SHOW AND TELL YOU HOW TO REMOVE THE FRONT AXLES.
Aug 24, 2010 | 1999 Oldsmobile Alero
HOW TO CHANGE REAR BRAKE LIGHTS 1999 QUEST?
I don't know this van but many tail light assembly's have a couple of screws you remove then a couple of snap clips. So after you remove the screws you gently pry the assembly off with a slim pry tool.
Feb 24, 2009 | 1999 Nissan Quest
Bottom center pulley
at the front of the transmission housing, there is an access plate that you can remove and place a LARGE flat blade screwdriver or pry-bar into the teeth of the fly wheel and jam it against a bolt in the housing. loosen the crank bolt (counter clock-wise). get a Y shaped "harmonic balancer puller" and follow the directions with the tool. good luck!
Jan 09, 2009 | 1992 Buick Century
How Can I Take Apart My Samsung SCH-u740?
Go to http://lsidave.com/Popups/Samsung.html if you have not found directions yet and good luck!
Jul 26, 2008 | Samsung SCH-u740 Cellular Phone
you should take the phone toa professional mobile center and have them replace it for you.
Jun 03, 2008 | Nokia 6233 Cellular Phone
Nokia 6233 Cellular Phone Logo
49 people viewed this question
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
