Question about Hotpoint HSS25GFP Side by Side Refrigerator
My icemaker stopped working. The power light won't even come on. Now my water dispensor stopped also. Just replaced the filter.
    Problem Solver:
  • 13 Answers
Check on the power input first,may be the plug switch is blown so the is no power to run the system.if power is on press the fridge on buton
Posted on May 11, 2010
Kenmore sidebyside no water or ice replaced valve and icemaker still nothing
The first thing I woulb check is the water filter itself. Water comes into the machine via the water valve, and from the valve it goes to the filter and the to its respective area, dispensor or ice maker. It's a very rare case that both the ice maker and water in the door stop working at the same time other than the filter being bad,
May 10, 2012 | Kenmore Side by Side Refrigerator
Water will not come out of the door dispenser
have you replace water filter ..... an easy test go to back of refrigerator where waterline goes int fridge and revers wires for icemaker and water dispensor and now use water dispensor it should put water into icemaker that will tell u that the switch to dispensor is working and you have a bad watervalve needs replacesed
Feb 03, 2011 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Ice and Water Dispenser on door stopped working
Sounds like the dispensor board has lost communication with the main control board . The part number for the main board is WR55X10942 . This is the board behind the refrig , behind the small 8 X 10 panel . It runs about $ 150.00 . I have never found a bad dispensor board . The main board is easily replaceable .
May 26, 2010 | GE GSS25LGM Side by Side Refrigerator
The ice maker stopped making ice. Any solutions?
A lot of filters ( not all ) do not even access the ice maker . Only the water dispensor . If your water dispensor is working fine , then you need to replace the dual water inlet valve behind the refrig . This is the piece the wall water line connects to . It is called a dual valve because there are 2 coils on the valve . 1 for the ice maker and 1 for the water dispensor .
Oct 23, 2009 | Kenmore Refrigerators
I have a G E. modle GSS22UFMD WW .SIDE BY SIDE. I,M NOT GETTING WATER TO DOOR,ICE MAKER. I PUT NEW FILTER IN THAT DID NOT HELP. I UNHOOKED WITERLINE UNDER FRONT DOORS NO WATER IN LINE,WHEN I TAKE WATER...
Did the icemaker and water dispensor quit at the same time ? Your model has the 2 lines coming from the top ( filter ) behind the refrig . One line to the wall water line to filter and the other coming down to the water valve . Do you have the filter bypass piece that came with the refrig ? Use it to test . Remove the back panel . If both stopped at the same time , check the connector that the wires connect to . With 2 connectors on each solenoid , those 3 or 4 wires go to a seperate plug in . Check this plug in . If wireing seems ok , remove the larger tubing from the valve by pushing in on the white ring and pulling the tubing out at the same time . Press the water dispensor , and see if water comes out of the valve . If it does , (you said you disconnected the tubing below the freezer door and no water came out while activating the water dispensor ) then the tank at rhe bottom of the refrig section behind the crispers , is frozen . To thaw , use a hair dryer with the light bulbs in the refrig section , unscrewed slightly . This is only for the water dispensor . For the icemaker , disconnect the smaller tubing , while someone else , turns the icemaker on and off several times to see if the valve momentarily opens each time the icemaker is turned on and off . I think the water valve wiring plug , has something to do with this because I have never found a G E where both quit at the same time without it being that plug ( 2 times ).
Aug 30, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Our Maytag icemaker stopped making ice suddenly after we changed the filter. It dispenses water only.
Does the water have a good flow ? Did you try putting the old filter back in ? Never change the filter just because a little red light comes on . Only replace when the ice cubes get small or the water dispensor flow gets slow . I have found new filters that were bad . Distributors make a lot of money for filters just because of that little red lite . Not just maytag , but all other brands also . Try pouring about 1/2 cup of water into icemaker . If it dumps the cubes but doesn't fill , replace the water valve . If it doesn't dump , and holds the cubes for a long period of time , replace the icemaker . Also , you may need to clean the coils of dust , lint , etc....
Aug 20, 2009 | Maytag MSD2732GR Side by Side Refrigerator
It stopped making ice but cold water option works fine. No clogs visible. Changed cold setting to 7 from 5. Nothing worked. just took out water filter, but can't see how that was the problem.
Put the filter back in . Pour about 1/2 cup of water into icemaker . If it dumps , then replace the water inlet valve . If it doesn't dump and the ice stays in the icemaker , replace the icemaker . Also , make sure the coils are clean of dust etc... Reset the controls back to normal or you could create water freezing in door (dispensor) .
Aug 04, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Icemaker not working after installing new filter
I have a Kenmore 106.56542400 icemaker stoped working ,water line is cleared not getting water to icemaker
Jul 02, 2009 | Kenmore 56549 / 56542 / 56544 / 56546 Side...
GE side by side refrigerator: water/ice dispensor
I bought a brand new smartwater replacement filter and after a very short time, my water stopped coming through the door.. took out the new replacement filter and inserted a brand new one .. problem solved.. apparently some of the g.e. smartwater filter replacement cartridges don't have the high enough two plastic inserts which are attached to them at the top of the filter when you screw them on... if you have taken your cartridge in and out a few times, i think it wears down the plastic so it doesn't fit properly and won't put up whatever it is supposed to push up to make the water come through.. I personally think this is a g.e. problem with the replacement filters...
Jan 31, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Hotpoint HSS25GFP Side by Side Refrigerator Logo
143 people viewed this question
Top Hotpoint Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Sal DeAngelo
Are you a Hotpoint Refrigerator Expert? Answer questions, earn points and help others
