Question about Miele W1903A Front Load Washer
Washing Machine not running the cycle.
I am having a problem with the Washing machine running the cycle. When I run it on Quick Wash the light blinks on Main wash/ rinse and will not move on. I have tried leaving it to finish on it's own but the machine will stay on this cycle for over 1 hour. I have had some problems with having put the clothes through a second spin cycle recently because the first one left the clothes dripping wet. Not sure if this is connected to the first problem. Any advise is appreciated
  • Miele Master
  • 1,830 Answers
What make and model is your washing machine?
Posted on Jun 07, 2017
SOURCE: going through normal wash cycle but stopping when it gets to the rinse and spin.
have you had the the control prgrame board tested as mine was doing the same thing and the engineer said, that my control panel was faulty ! hope this helps
Posted on Apr 17, 2007
  • 16 Answers
SOURCE: Miele Premier novo washing machine
Flashing rinse light is a drive fault. No motor action. If it's an earlier model it would be the motor brushes. Later model will be the electronic which controls the motor.
Posted on Feb 08, 2008
IFIXALL
  • 868 Answers
SOURCE: Spin Cycle Fails on Washer
This solution is 100% correct, change the : wax motor &control board.I'll be happy to guide you through this if you need me to.
Posted on May 26, 2008
  • 100 Answers
SOURCE: dripping wet clothes
will be an UNBalanced load, maybe there was not enough clothes in the load so in that case the drum would not be able to distribute the load evenly so gave up on the spin, hence wet stuff!
Posted on Jan 28, 2009
  • 1122 Answers
SOURCE: Clothes way too wet after washing
your washer is not hitting high speed spin thats why the cloths are still wet,bad transmission,sorry-mike
Posted on Jun 03, 2009
My mass 6 Bosch washing machine is locked up and was blinking in red light letter F what do I do
"Sd" - (Excess suds)
F8 followed by E1 - (water supply error)
F9 followed by E1 - (drain pump system error)
F5 followed by E2 - (door will not lock)
F7 followed by E1 - (motor drive error)
"rL" - (remove load)
Washer making error beeps - Door has not been opened and closed for at least 3 cycles
Washer beeps when HOLD TO START is touched - Door not closed
F# E# code other than as described above appears in display - System Code Error
"nt" (interrupted) - Cycle was paused or cancelled
Clean Washer LED flashing at end of wash cycle - The washer has run 30 wash cycles and is indicating a reminder to run the Clean Washer cycle https://removeandreplace.com/2015/05/05/washing-machine-error-codes-front-and-top-load
Sep 21, 2017 | Bosch Washing Machines
I have an Aqualtis 9l29i washing machine. It is working fine but the wash cycles are all ridiculously long.Put it on the quick wash yesterday,three hours later still washing!! Suggestions please?
1. Front load machines always have much longer cycles.
2. The machine you have has a time saver mode on most cycles.
3. Check with your local Ariston reps on the time various wash cycles should take with your model if this is not specified in the user manual, which it normally would be.
4. These are notoriously bad over priced machines which will give you trouble early in ownership and are expensive to fix. For half the price you can buy a good top loader that will give you at least twice the trouble free years of use and not run ridiculous wash cycle times.
Jan 03, 2016 | Washing Machines
A GE stackable washer/dryer that is stuck on spin?
Good Day,
your machine is normal is washing cycle?
if yes.do the same
for the fully automatic washing machine mostly have drain pump, please check the filter of your drain pump, if clog your drain pump of some hair pins,cotton buds or coins or any small item,that the cause of water stuck,and it will long time draining or totally not running the drain pump.and its cause of stop of cycle of washing machine in rinse time or spin time,because after washing the pump must be on to remove water before start the next cycle.
Nov 02, 2013 | Washing Machines
Mu washing machine is getting stuck on the rinse cycle. There is no error code coming up, just all of the light blink with the exception of wash and spin. I have unplugged it overnight and it didn't help....
Look under it for a diagnostic manual
You got codes or something there if it blinks
May have a bad control board
Need that service manual to start your testing
Sep 13, 2013 | Kenmore HE2 Plus Front Load Washer
Have just bought a zANUSSI fjs 1225 W. Have run one cycle ( quick wash, 40 degrees, cotton) and the fabric conditioner was not drained away. Is this because it was a quick wash? V disappointed as I need a...
zANUSSI fjs 1225 W. Have run one cycle ( quick wash, 40 degrees, cotton) and the fabric conditioner was not drained away This video will show you how to keep your soap draw clear and how to service the parts Please remember to subscribe to our YouTube channel for all appliance tutorials a 4 THUMBS rating is appreciated for answering your FREE question. And don't forget to like us on facebook
Feb 15, 2011 | Zanussi FJS1225W Front Load Washer
Stops mid cycle. Light flashes, cant get it to move on so have to start all over again
Hi there.
I have the same problem with my machine. Whatever program I select, the machine runs fine until it reaches 54 mins of the cycle remaining. To overcome the problem just to select a cycle that will not stop mid cycle, select a program which is less than 54 mins. I think the 40 degrees and quick wash select is the one to run with. The cycle is 45 mins, obviously less that 54 mins. The LED timer will display the cycle time. No problems with this cycle whatsoever. Not the total solution, but at least you're able to complete a cycle. After it's completed, I also run the spin program at 1200rpm. I hope this helps.
Regards, Ian.
Nov 22, 2010 | AEG Lavamat 72640 Front Load Washer
Bosch classixx 1000 washing machine - stops on spin
Washing machine stops at the spin cycle - light flashes. Have to drain water out manually. Happened last week and was then able to run an empty rinse cycle. Machine worked normally for another week. Same problem today but have had to drain water manually from the drum after trying an empty 90 wash and rinse cycle (both stopped on the Spin and flashed). Any ideas? Thanks. x
Apr 29, 2008 | Bosch Classixx WVF 240S Front Load Washer...
Beko wma 1715s
The Child lock is in the on mode lol.....
Press and hold the two buttons quick wash and anti crease or
pre wash and extra rinse for 4-5 seconds ...Note the pre wash blinking light will go off and your machine will be ready to use again. the pre-wash blinking light indicates that the child lock has been activated......
Jan 05, 2008 | LG WM1814CW Front Load Washer
Miele W1903A Front Load Washer Logo
75 people viewed this question
Top Miele Washing Machines Experts
Gerry Harvey
Gerry Harvey
mpservices
Are you a Miele Washing Machine Expert? Answer questions, earn points and help others
