Question about Sony Alpha DSLR-A100 Digital Camera
Sony DSLR-A100, error code 0x5b
My sony camera sometimes does not take a picture. The error code is 0x5b. I need to turn power off to cancel the error code.
Please advise how to solve the problem.
Thanks,
  • 3 more comments
  • Anonymous Apr 27, 2008
    My camera is doing the same thing. Took it back where we purchased it and were told that it sounds like the in-body stabilization. Have to contact Sony to get it repaired.
  • Anonymous May 23, 2008
    I just experienced the same problem with my camera this afternoon, 0x5b. I switched the "Super Steady Shot" feature off, then on again, and my camera seems to be working normally again, but as you I very curious of the camera error code as well.
  • toblen Jun 29, 2008
    I have this problem too. On my a100 it happens every time i don't use minimum aperture value.
  • abourayan Aug 08, 2008
    I have the same problem
  • destiny323 Sep 26, 2008
    i have the same problem. i've tried messing with all the different settings, doing two different resets... all to no avail.
    i spoke with sony a few minutes ago, and it seems the only solution is to send it in and get it repaired for $228 by one of their subcontractors.
    the rep told me this type of error (mine looks like 0x58, but she said that error doesn't exist and the 8 is actually a B... i still don't see it) but anyways, she told me this type of error is a problem with the "aperture programming."
    i asked if it was common among people with this type of camera, and she couldn't give me a straight answer either way. i asked if there was any guarantee after it's fixed that this won't happen again, and she said there is a 90-day warantee after the repair... (woohoo). i asked if anyone had any idea what would trigger this error... she said the technicians would be able to tell.
    i had my camera for 14 months, and this happens. i take meticulous care of it.. it's never banged around, exposed to temperature extremes, etc. i've never had a problem like this with any other camera. i can't take any photos, and i can't figure out why this even happened in the first place... and neither can sony. this is SO annoying.
Same here. My camera gives me the same error code unless I shoot with the largest aperture/smallest F-number.
Posted on Aug 30, 2008
Sony DSLR-A100 eroor 0x58
Well, the good news is that there's probably no fault with the camera itself. It could be something as simple as the CF card being pushed in the wrong way. A look through the user manual will likely help you get to the bottom of your issue:
Sony Alpha DSLR A100 manual
Aug 13, 2014 | Sony Alpha DSLR-A100 Digital Camera
Does the error happen each and every time you take a snapshot, or only with some? As you are letting us know, have a look around the user manual to see if it can be of any help:
Sony a100 wont turn on
If the battery is charged, try replacing the battery first. Also try turning on the camera with the charger plugged in. If neither helps, you will probably need to have the camera sent for repairs, but you can still try checking out the user manual for helpful information:
Nov 11, 2013 | Sony Alpha DSLR-A100 Digital Camera
Sony dslr a100 shaking and making noise
ISO speed is too high, low an iso as possible go to the menu, and read your owner manual very well, and fix it.
God bless you
Sep 22, 2012 | Sony Alpha DSLR-A100 Digital Camera
Camera error code =0x5b
Usually error codes (maybe not 0x5b) are lens comunication problems and can be fixed by removing the lens and reattaching and make a power reset.
If the problem still persists a service may be required.
Good luck
Jul 01, 2011 | Sony Alpha DSLR-A100 Digital Camera
Mi camara da herror de las Naciones Unidas Herror code = 0x59
On my Sony Alpha 100 I keep getting this error 0x59 when I press the shutter button. It takes the picture but I have to turn the camera off and then back on to use it again
Oct 23, 2010 | Sony Alpha DSLR-A100 Digital Camera
Aperture Error
This blog will clear up what is going on with the camera and you can send it to them to fix also. www.teleplancamerarepair.com
Their blog steps you through explaining each step.
http://www.teleplancamerarepair.com/camera-repair-blog/post/0x5b-Error-Code-in-a-DSLR-Sony-A100.aspx
This blog also clearly lays out the F-stop definition.
Sep 26, 2008 | Sony Alpha DSLR-A100 Digital Camera
Error 0X5b
Такая же фигня. Фотал нормально. Отключил автофокус, потому что фотал летящих птиц. Две фотки сделал и на третьей выскочила ошибка Camera errop code 0x58 . Выключение и вытаскивание аккумулятора не помогло. Вкл/выкл. автофокуса тоже. Не знаю, что делать. Завтра понесу в сервисный центр сдавать. :( Грустно.
Aug 08, 2008 | Sony Alpha DSLR-A100 Digital Camera
Error 0x57
The 0x5b error code indicates that the amount of light passing through the aperture lens is not being controlled by the F-Stop selected. error can be fixed. check out quote at www.teleplancamerarepair.com
Another thing that happens when this error is present.
When you raise the camera up to horizontal position and try to take a picture and you get the error code and again it shuts down.Tthe system is being saturated with high light levels indicating the AV drive unit which is not doing its job and controlling the aperture of the lens. This can be fixed.
Jul 11, 2008 | Sony Alpha DSLR-A100 Digital Camera
ERROR CODE 0x5b
This error message is an indication that a problem may have occurred with the aperture assembly in the camera. To resolve this issue, service will be required.
Feb 03, 2008 | Sony Alpha DSLR-A100 Digital Camera
Sony Alpha DSLR-A100 Digital Camera Logo
1,509 people viewed this question
Top Sony Cameras Experts
james laughton
james laughton
Are you a Sony Camera Expert? Answer questions, earn points and help others
