Question about Moen 3175 Legend One Handle Shower Faucet With trol Pressure Balancing Valve....
What could be causing a high pitched screeching sound when I turn on my single handle shower?
    New Friend:
  • 81 Answers
If you haven't turned the main back on, this could cause the sound.
Re supply the water to the lines.
Posted on May 10, 2010
How do I put seats and springs in a glacier bay Aragon three handle knobs
How to Repair a Glacier Bay 3 Handle Tub and Shower ...
www.faucetinstructions.com > Glacier Bay Faucet Instructions
My three Handle Glacier Bay Tub Shower Faucet Makes a High-Pitch Squealing ...The Glacier Bay tub faucet screw-cover buttons will not stay on the handles. ... Sealthe flanges to the shower wall with a high-grade anti-microbial kitchen and ...
Nov 07, 2015 | Plumbing
2006 Chrysler sebring High Pitch Noise Screeching Sound
The belt is slipping or the compressor and/or clutch is bad.
If the compressor won't turn freely with the engine off, it may be locked up which will make the belt screech.
Jun 27, 2012 | 2006 Chrysler Sebring 2.7
Getting hot water when shower valve is first opened.
If I understand correctly, you have single handled shower faucet.
Normally there is a wait for hot water to arrive at faucet.
But now hot water is already at shower faucet.
Single handled faucets have a mixing area inside valve where hot and cold come together before going into sink.
This mixing valve can have crossover where the hot and cold can pass through to each other even when faucet handle is off. When single handle faucets get old, this can happen.
How it happens:
For example another faucet is turned on inside house, and pressure differential between hot and cold causes hot water at shower handle to pass through mixing area and into cold water line.
So if another faucet has been run, then that lets hot flow to faulty single handled shower faucet.
To confirm this is the problem: turn on other faucet and put ear against shower faucet to listen for moving water.
This condition may also signal there is a water leak.
The problem is not harmful, but will draw cold water into water heater each time, and is energy wasteful.
Replace faucet or have plumber repair problem.
Feb 19, 2011 | Price Pfister Single Lever Handle Faucet...
I have a single handle Danze shower. I can't turn on the water. The handle just turns all the way around.
sounds like handle is not engaged....pull handle...may need allen wrench...after handle is off see if you can turn water on with pliers...should go from right to left...if that works...install handle and tighten with allen wrench....handle should set from off area...see if handle is stripped out or not on proper...if need new handle...pick up at lowes or plumbing supply...good luck
Jan 16, 2011 | Danze & Single Handle Tub And Shower...
Turning on hot or cold water I get a loud screeching noise and very low pressure. If I keep turning the handle, I can get rid of the noise, but still low pressure.
It sound like you have sediment blocking your valve, faucet airiator or shower head (depending on what you're using). FYI: if it turns out to be defective all Moen faucets and showers have a life time warantee.
Jun 12, 2010 | Moen 3175 Legend One Handle Shower Faucet...
Screeching sound only when trying to record using LiveCam! and my
Sounds like you have another microphone connect at the same time as your camera mike and it is causing the feed back.
Or the second thing that could cause the feed back is that you have your speaker volume turned up to high.
Hope this is of some help. Bud
Sep 21, 2009 | Logitech Webcam
Turns on then gives a High pitched Screech then shuts down even after totally unplugging it and reconnecting it blinks on then Screeches then turns off rinse repeat
are you talking about just the monitor of the computer as a whole? if you are talking about the computer then, there is something loose inside the case, which is causing the high pitched sound.
Jun 27, 2009 | Gateway FPD1960 19" Flat Panel LCD Monitor
Kohler 30 year old single handle shower valve - cold water only
Is this a dual handle or single handle? if it is a single handle
turn the valve 180 degree. if not, then check the cold water supply line.
Jan 02, 2009 | Home
High pitched screeching/broken handle release
For the handle problem, detent lever part #2030052 and costs $4 to $5. A bearing in the motor is what is making it sound bad, part #2032211 and will cost around $60. You could try bissell.com or call them. They can at least let you know who has Bissell parts near you.
Mar 25, 2008 | Bissell CleanView 3596 Bagless Upright...
Moen 3175 Legend One Handle Shower Faucet With trol Pressure Balancing Valve.... Logo
294 people viewed this question
Top Moen Plumbing Experts
john h
Don Numinen
Don Numinen
Mike
Are you a Moen Plumbing Expert? Answer questions, earn points and help others
